N2mb boost box Help - Page 2 - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 11-18-2012, 10:30 AM   #16 (permalink)
badboydneon's Avatar
Member Number: 63272
Make sure your vacuum lines to the wg are tight and aren't leaking causing overboost. And make sure the diaphragm/seal is installed properly. I had this issue.
2004 Black SRT-4-
Mopar Stage 3 with the works
2003 Silver SRT-4-
BW s200sx-rs-56 .63ar
1997 Black 1G, 2.4 built and turboed-project
Any1 local in need of PCM flash...hit me up
badboydneon is online now   Reply With Quote
Old 11-19-2012, 05:31 AM   #17 (permalink)
emanuelcurly's Avatar
Member Number: 79089
I would try a different spring. If u don't have any vacuum leaks. I had a problem with my 14psi spring from agp out of the box. When you got the car tuned what spring were u using or did u start having issues out of the blue?
Gtx3076r Tuned by Turbo666
335whp on 93@ 24psi
405whp on e85@ 27psi
Best et 11.7@ 122.10!!!
emanuelcurly is offline   Reply With Quote
Old 11-19-2012, 05:10 PM   #18 (permalink)
Member Number: 82349
When I put everything at 0 this is how it ends up after I pulg back into it?
nsrt4 is offline   Reply With Quote
Old 11-19-2012, 05:14 PM   #19 (permalink)
SRT of the Month
underSRTarmor's Avatar
Member Number: 32888
This is my setting
over boost to 29
Gain 1
Spring 7.5
Learn 3
Old 11-19-2012, 05:17 PM   #20 (permalink)
Quote: Originally Posted by underSRTarmor View Post
Set over boost to 20
Gain 0
Spring 0
Learn 0
Tried it even put a 9 psi spring in still spikes like crazy hits 23-30
Old 11-19-2012, 05:19 PM   #21 (permalink)
SRT of the Month
I edited my post. Sorry
Old 11-19-2012, 06:21 PM   #22 (permalink)
Why does it always change my learning rang?
Old 11-20-2012, 05:06 AM   #23 (permalink)
Even when u set ur boost points back down to where u want them? The boost box overrides them to that?
335whp on 93@ 24psi
Old 11-20-2012, 10:25 AM   #24 (permalink)
Yes when I set SP LR and gain to 0 this is how it ends up after I drive it?
Old 11-20-2012, 01:27 PM   #25 (permalink)
I hooked a line right from the turbo to the wastgate and this is what I got..
I dont think my guage is off that bad?
Old 11-20-2012, 01:29 PM   #26 (permalink)
SRT of the Month
what set up you have?
Old 11-20-2012, 01:50 PM   #27 (permalink)
6266 with tial 38mm I just tried another guage and its doing the same thing?
Old 11-20-2012, 01:58 PM   #28 (permalink)
SRT of the Month
what wg spring?
is a 38mm big enough for a 6266?
does it have 2 holes in the wg? i use the bottom with my boost box on my apg wg
is the wg pressure to close or pressure to open? if it has 2 port its both i think..
Old 11-20-2012, 02:02 PM   #29 (permalink)
what wg spring?
It has a 10psi spring in it
2 ports Im using the side port because there is othing in the top one?
Old 11-20-2012, 02:30 PM   #30 (permalink)
SRT of the Month
if you remove the line off does it boost 10?
http://www.tialmedia.com/documents/w..._wginstall.pdf
