N2mb boost box Help - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 11-12-2012, 04:08 PM   #1 (permalink)
Member Number: 82349
Default N2mb boost box Help
I have had my boost box for about 2 years and it has always spiked over what I set it at and I can never really get the boost to a stable psi?
nsrt4 is offline   Reply With Quote
Old 11-12-2012, 05:19 PM   #2 (permalink)
SRT of the Month
underSRTarmor's Avatar
Member Number: 32888
Play with the learning psi and the gain
Old 11-12-2012, 06:11 PM   #3 (permalink)
I have tried it all.
Old 11-12-2012, 06:13 PM   #4 (permalink)
SRT of the Month
Are all ur connections soldiered?
Autoguide.com App
Old 11-12-2012, 06:21 PM   #5 (permalink)
yes. You only need the two solenoids right? I have a resistor in the other one to keep my engine light off.
Old 11-12-2012, 06:24 PM   #6 (permalink)
SRT of the Month
More than that there are like 6 wires all need to be connected and soldiered.
Autoguide.com App
Old 11-12-2012, 06:38 PM   #7 (permalink)
Turbo666 Installed the Boost box and I have checked it everyting is good. No matter what I set my learing range at it always goes back too 3772.
Old 11-12-2012, 06:50 PM   #8 (permalink)
SRT of the Month
put the gain at 1
put you spring pressure at what wg you have ie fm=8 put the learning at 3 and see if that holds...
Old 11-13-2012, 04:14 PM   #9 (permalink)
I set it like that all gears set to 0 with 15psi spring and my boost is jumping fron 19-23
Old 11-14-2012, 09:25 AM   #10 (permalink)
emanuelcurly's Avatar
Member Number: 79089
Try running the boost box on the manual method.
gain, spring, and learning to 0. set ur over boost to whatever u want it to be. Then set ur boost points by adding whatever psi to ur spring pressure. if ur going for 25psi and ur spring pressure is 15psi then just add 10.0 in the boost setpoints box. I would also recommend running a smaller spring. I run a 9psi spring and im tuned to 27psi without any issues. Good luck bruh.
Gtx3076r Tuned by Turbo666
335whp on 93@ 24psi
405whp on e85@ 27psi
Best et 11.7@ 122.10!!!
emanuelcurly is offline   Reply With Quote
Old 11-14-2012, 07:32 PM   #11 (permalink)
I have tried it all boost is still all over the place? I know have code p0033 come on.
Old 11-14-2012, 08:23 PM   #12 (permalink)
SRT of the Month
Check to see if the tip solenoid it still T'ed with the wg line
Old 11-15-2012, 02:54 PM   #13 (permalink)
So I ran a line from the wastgate to turbo and the boost was still 19-23 so Its not the boost box.. My guage might be junk!
Old 11-15-2012, 03:39 PM   #14 (permalink)
SRT of the Month
Wow why so big of spring?
Big turbo right?
I'm on the stock 8 psi spring from AGP 27 psi all day!!
Old 11-17-2012, 03:34 AM   #15 (permalink)
T4EaterJonny's Avatar
Member Number: 54334
Here's mine but my gain is at 3 now.
It'll hit like 22.8 then hold 22.2 to redline on the scangauge. ( stage 3 turbo )
ah. I forgot... This was a "Problem" screenshot that n2mb solved for me. My spring pressure kept resetting itself to a high numerical value because my gain was at 1. When I set the gain to 3 my spring pressure stayed the same at 10 or 11 lbs
Flowers
05SRT4 stage 3<>88 XR4Ti w/T5 swap
07R6<>94 XR600R plated S2k?
T4EaterJonny is offline   Reply With Quote
