Leaking Oil Pressure Switch - Dodge SRT Forum
 4Likes
post #1 of 41 (permalink) Old 11-25-2013, 07:45 AM Thread Starter
New Member
CoMbO's Avatar
Quoted: 0 Post(s)
Okay I found out that my OPS is leaking and making a mess around my driveway. Me and my cousin got it on the ramps went underneath took the hard pipe off but nearly impossible to reach in there unclip the sensor nor put a ratchet up there. Can someone please advise if there is a easier way on replacing it literally making a mess. Thanks in advance.
CoMbO is offline
post #2 of 41 (permalink) Old 11-25-2013, 08:16 AM
Quoted: 162 Post(s)
use the how to http://www.srtforums.com/forums/f75/...d-here-189025/
how to for sending unit HOW-TO: Oil Sending Unit
405hp, 450tq
http://www.srtforums.com/forums/f451...w-123k-612933/
PCM=S0, DSP rescaled, 3bar map/tip
injectors= Siemens 80# (ebay $200)
built motor, 8.8:1 weisco, eagle-h, strap & windage
S3R DCR manifold ($500) w/evo8 turbo (ebay $150) - 20G/47# ebay ($200)
Evo 8 WGA
24x12x4 w/cast ends - CXRacing (ebay $200)
DataLogger DataQA, $25
Wideband UEGO (ebay $150)
vette rims 275/40/17
needswing v5
SouthBend S3
fixit is online now
post #3 of 41 (permalink) Old 11-25-2013, 08:23 AM Thread Starter
New Member
CoMbO's Avatar
Quoted: 0 Post(s)
I seen this write up still does not tell me how to remove it. The guy gave up.
CoMbO is offline
post #4 of 41 (permalink) Old 11-25-2013, 08:49 AM
Quoted: 162 Post(s)
the pdf attached to the write up is what i've used.
405hp, 450tq
Evo 8 WGA
needswing v5
SouthBend S3
fixit is online now
post #5 of 41 (permalink) Old 11-25-2013, 06:59 PM
New Member
fivetoez's Avatar
Quoted: 3 Post(s)
You need a 3 ft. long extension & oil psi. adapter socket with a universal.
go at it from the rear of the car looking forward.
I watched the Dealer change mine & it only took em 5 min. on the lift.
_____5TOEZ______ 1967 Cadillac Calais 429 2dr.,.... 1967 Chevelle 4sp. Conv.... ,1978 Dodge 318 "Factory Custom"van.,..... 2004 Dodge Srt-4,Stage1.5(E-Blue) & a couple motorcycles.
fivetoez is offline
post #6 of 41 (permalink) Old 11-26-2013, 08:17 AM Thread Starter
New Member
CoMbO's Avatar
Quoted: 0 Post(s)
How much did the dealership charge you to replace it?
CoMbO is offline
post #7 of 41 (permalink) Old 11-26-2013, 01:29 PM
Quoted: 0 Post(s)
i did mine at my shop on the lift. i just removed the downpipe which is easy on the lift. then you have a bunch of room to work with. it took about 10min total.
emann21 is offline
post #8 of 41 (permalink) Old 11-26-2013, 01:46 PM
r1zzle's Avatar
Quoted: 0 Post(s)
Just did mine like an hour ago, tried going from the top....f-that..... Put it on the lift and used ~10' of extensions lol I didn't take anything but the ops off. Used the ops socket to get it started back then squeezed my hand in there to turn it a couple of times just in case then tightened it down
Sent from
r1zzle is offline
post #9 of 41 (permalink) Old 11-26-2013, 02:23 PM
Mrturbo24's Avatar
Quoted: 168 Post(s)
Pain in the ass to get to
Sent from
Mods: Tial BOV, BC Coilovers, Aem CAI, Aem Wide, dsp 93 tune, 3inch mpx (catless)exhaust, mpx bfmic, 1/3/5 gear extender
Mrturbo24 is offline
post #10 of 41 (permalink) Old 11-26-2013, 06:36 PM
New Member
fivetoez's Avatar
Quoted: 3 Post(s)
Dunno, my buddy is the head mechanic.
...he did it 4 free on his lunch
fivetoez is offline
post #11 of 41 (permalink) Old 11-26-2013, 07:42 PM
TOMTOMR/TSRT4's Avatar
Quoted: 92 Post(s)
Sent from
Yup I thought my ops was bad but it was actually from my mechanic. When he replaced my clutch he must of not realized it but he ripped the microscopic wire from the connector. I got to it from removing the battery and holding the wires out of the way.
Sent from
TOMTOMR/TSRT4 is offline
post #12 of 41 (permalink) Old 11-27-2013, 07:19 PM
crazzinezz's Avatar
Quoted: 0 Post(s)
Did one for my buddy in my garage at home. did it from in behind the engine cradle with ops socket and flex ratchet. Pain in the ass to get at took 30min. Did another buddy's on hoist at work ops socket + u joint + 10" ext again from in behind cradle 10min job.. didnt have to remove any piping or anything else for either.
Sent from
T3/T4 Garrett bb 50 Trim - S2 Crower cams - P&P - Rev oversize valves - 888 Injectors - Fuel return set up - Tial Bov - Tial 38mm WG - 75mm TB - Custom Intake Manifold - Walbro 255lph - 3" exhaust with e-cutout - CAI - ACT Stage 3 clutch - 3bar map + tip
crazzinezz is offline
post #13 of 41 (permalink) Old 11-27-2013, 08:19 PM
bzzt's Avatar
Quoted: 1369 Post(s)
What are you guys talking about?
I did it from the top in 20 minutes.
Remove battery and intake, unhook trans shifter cables, un-bolt shifter cable bracket, un-plug the wire, and put the deep socket on the OPS.
Kind of difficult reaching down there but no special tools required except the deep socket.
2004 Silver SRT-4
Stage I, AEM CAI, UDP, cut balance chain
bzzt is offline
post #14 of 41 (permalink) Old 11-28-2013, 10:40 PM
SRT4Delta46's Avatar
Quoted: 9 Post(s)
Are u guys talking about oil pressure sensor? Because I'm leaking all over beside the oil drain and only thing i see it can be is the yellow sensor?
Sent from
Stock turbo Full Bolt ons E85
Dyno Numbers
93-273hp 342trq 22psi
e85- 314hp 400trq 23psi
Coming soon AGP Borg Warner sx51
SRT4Delta46 is offline
post #15 of 41 (permalink) Old 11-28-2013, 10:42 PM
Mrturbo24's Avatar
Quoted: 168 Post(s)
Sent from
Yeaa
Sent from
User Tag List
Linear Mode Linear Mode
