Just done the 93 Octane tune with DSP! - Dodge SRT Forum
post #1 of 69 (permalink) Old 02-16-2010, 04:07 PM Thread Starter
7angofragger's Avatar
Quoted: 0 Post(s)
Just done the 93 tune on my 2003 with only an AGP cold air intake and a TurboXS RFL BOV. Its 27 degrees Fahrenheit here... I went out and mashed second and third gear, and it stuck at 16PSI... didn't spike any higher, or fall down. Just stayed right at 16. Does this sound right? It sure feels better then a MBC set to 16
People to listen to on here
Turbo666
Blackbird_R/T
Stowaway
NorthNJSRT4
Duster360
03/Stage 2/DSP/TEIN/SPEC/ZEITRONIX
PWERKS/RPF1s/245-40 Pilot Super Sports
Full Prothane Bushing Kit/MOOG/HOTCHKIS Sways
7angofragger is offline
post #2 of 69 (permalink) Old 02-16-2010, 04:09 PM
rector07's Avatar
Quoted: 0 Post(s)
I take it you are on pcm boost??
rector07 is offline
post #3 of 69 (permalink) Old 02-16-2010, 04:14 PM Thread Starter
Quoted: 0 Post(s)
yep... everything is stock.. stock wastegate, stock 03 injectors. just the 93 oct flash.
Turbo666
Blackbird_R/T
Stowaway
NorthNJSRT4
Duster360
post #4 of 69 (permalink) Old 02-16-2010, 04:14 PM
prevrexowner's Avatar
Quoted: 0 Post(s)
Wow, that's odd. I used to spike 20, settle around 15ish or so (with stock wastegate).
prevrexowner is offline
post #5 of 69 (permalink) Old 02-16-2010, 04:19 PM
getnpsi's Avatar
Quoted: 0 Post(s)
72 or 27 degrees? Big difference in air charge there. It IS 72 degrees F here today BTW
getnpsi is offline
post #6 of 69 (permalink) Old 02-16-2010, 04:22 PM Thread Starter
Quoted: 0 Post(s)
im 99% sure its beacuse of our cold weather. off the 93 tune, i was going straight to 12psi. a couple months ago i would spike 14 and hold 12.
from what i understand (correct me if im wrong) the computer measures the readings between the MAP and TIP sensor. since the air outside is more dense, being thats its colder, its getting the same amount of power running colder air. so the PCM is just limiting the boost...
right?
Turbo666
Blackbird_R/T
Stowaway
NorthNJSRT4
Duster360
post #7 of 69 (permalink) Old 02-16-2010, 04:23 PM Thread Starter
Quoted: 0 Post(s)
yeah... 27... cold as balls... i hate this weather... COMMON SPRING!
Turbo666
Blackbird_R/T
Stowaway
NorthNJSRT4
Duster360
post #8 of 69 (permalink) Old 02-16-2010, 04:27 PM
SRTrent's Avatar
Quoted: 2 Post(s)
Yes it limits boost depending on the weather. Do you have a wideband at all? With just the 93 tune it leans it wayyy out. I'm talking into the 13's. And yeah it's cold as fuck out here lol.
298whp/405wtrq dynodynamics
stock turbo, bolt on's, E85, DSP, M&H's on Welds
60' 1.804
330' 5.007
1/8 7.701 @ 91.45 quickest 1/8: 7.61 @ 91
1/4 11.996 @ 114.7
R.I.P. 40 roll
SRTrent is offline
post #9 of 69 (permalink) Old 02-16-2010, 04:30 PM
intriguing's Avatar
Quoted: 0 Post(s)
typical boost levels for the 93-canned tune
you're on track with the 15-16 PSI.. mine is about there with it being 20 degrees outside.. I just installed mine a week ago with the canned tune as well
intriguing is offline
post #10 of 69 (permalink) Old 02-16-2010, 04:37 PM Thread Starter
Quoted: 0 Post(s)
are you serious!? i don't like 13's.... i have a wideband, but its not installed on the car at the moment..should i put it back to stock?
Turbo666
Blackbird_R/T
Stowaway
NorthNJSRT4
Duster360
post #11 of 69 (permalink) Old 02-16-2010, 04:56 PM
SRTrent's Avatar
Quoted: 2 Post(s)
I would either take the tune off for now until you put the wideband on or I'd go about 35% rich from 6-7k, 35% rich from 5-6k, 18% rich from 4-5k and leave the rest.
60' 1.804
330' 5.007
1/4 11.996 @ 114.7
R.I.P. 40 roll
SRTrent is offline
post #12 of 69 (permalink) Old 02-16-2010, 04:57 PM
D-ROK's Avatar
Quoted: 0 Post(s)
like.....install your wb
D-ROK is offline
post #13 of 69 (permalink) Old 02-16-2010, 04:59 PM
SRTrent's Avatar
Quoted: 2 Post(s)
like... I heard SRT's in Cali are slow
60' 1.804
330' 5.007
1/4 11.996 @ 114.7
R.I.P. 40 roll
SRTrent is offline
post #14 of 69 (permalink) Old 02-16-2010, 05:01 PM
adecanmin's Avatar
Quoted: 3 Post(s)
At least do some data logging first. I would think if you're into the 13s during wot you would get some significant knock. If that is the case add fuel or retard timing to get knock under control.
Adrien
adecanmin is offline
post #15 of 69 (permalink) Old 02-16-2010, 05:02 PM Thread Starter
Quoted: 0 Post(s)
balls... well i guess ill revert back to the factory tune... ill try to put my wideband on tonight... i hate this f'in weather...
Turbo666
Blackbird_R/T
Stowaway
NorthNJSRT4
Duster360
User Tag List
Linear Mode Linear Mode
