#61 (permalink) |
![]() Join Date: Sep 2003
Member Number: 3797
Yes, that is the weakness of the stocker. The DFFMIC is better, but for stock turbo guys you can live with a little heat soak. Most people aren't going to do back to back pulls and what's the difference between 240 and 250whp, they are still both slow. If you want just a little bit more, but not the most you can get, go with the DFFMIC. If you stay stock turbo and never go bigger, this will be ok. When you get tired of being slow and go big turbo, then you will wish you had a BFMIC in the first place. I just think, if you are going to spend all the money and time, do the BFMIC and get it over with. I had the old style AGP race on my stock turbo car. There were no performance problems or lag. Here in the heat of the summer where it never gets under a 100 degrees for three months, it helped a lot with performance. It made it all the way until I was pretty maxxed out on the stock turbo. I found an ED super beast and sold the AGP. If I was getting one today it would be one of the cast end tank BFMICs no question.
2003 SRT-4 Silver, AGP GT3076R on E85 DD!
Was 478hp/508tq ----> Now ??? 2002 Camaro SS M6, going N/A... |
| Sponsored Links | |||
Advertisement | |||
#62 (permalink) |
![]() Join Date: Aug 2008
Member Number: 66615
I got my time in my sig with this CX Racing intercooler. Track times don't lie. All the quickest stock turbos had BFMIC.
Dodge Neon SRT4 SRT 4 Intercooler 03 06 36 5x11 25x4 | eBay I think it makes a positive difference when you are running 20+ psi on the stock turbo.
11.837@118.5 - stock turbo no N2O
Kickin Wing Racing Last edited by DetroitSRT; 12-13-2012 at 09:01 AM. |
#63 (permalink) |
![]() Join Date: Mar 2012
Member Number: 88443
Dodge Neon SRT4 SRT 4 Intercooler 03 06 36 5x11 25x4 | eBay I think it makes a positive difference when you are running 20+ psi on the stock turbo. I was actually looking to get that same intercooler if I wasn't happy with the CX racing direct fit, can you post a datalog or show temps of results on the CX racing BFMIC.? Also how much boost are you running?
#64 (permalink) |
![]() Join Date: Nov 2009
Member Number: 76443
Can someone running a 4" thick dfmic post a log or give some numbers on the charge temps on a pull?
I ran the spearco dfmic(3" thick) for some time and yes it definitely lowered the acts a lot more than stock, basically cut the temps if half of how much they would heat up on the stock intercooler, but doesn't keep temps near as close to ambient as my current mpx bfmic. After install i was able to add 1-2* of timing on 93oct throughout the powerband due to having cooler charge temps Last edited by toofast82; 12-14-2012 at 12:41 AM. |
#65 (permalink) |
I'm real happy with the intercooler. It's cheap. Seems to perform real well for the price. Only downside is you have to bend a few things for it to fit properly. On the plus side you don't have to modify your bumper. Not sure if I have a recent log with temps recorded. The car is in storage for the winter. I'll probably have to get back to you in the spring. 25psi
Kickin Wing Racing Last edited by DetroitSRT; 12-14-2012 at 10:00 AM. |
#66 (permalink) |
![]() Join Date: May 2011
Member Number: 84599
I installed the CXR Direct Fit yesterday. It's not a direct fit actually, so you will have to get creative with it. Power tools may be required if you're unlucky. Haven't had the chance to get on it yet, but if I'm disappointed, I'll let y'all know.
'05 Silver - DD - 74xxx miles
E85 stock turbo - traction in 3rd is overrated (Tune courtesy of the wizard known as Nigel/Turbo666) Looks like stock, goes like stink Hopefully getting 1/4 times before finishing grad school, but after getting slicks... |
#67 (permalink) |
Fresh Meat Moderator
![]() Join Date: Dec 2009
Member Number: 76568
How is the direct fit.......not a direct fit? I know some people have had to bend the radiator core support in but that is nothing.
Shouldnt need power tools either.
![]() Diablo CMR tuner ~Dan~ 2004 Black Neon SRT4: E85 stock turbo SOLD ![]() 310HP 436TQ 2004 Eblue Neon SRT4: E85 5558 Built motor ![]() XXXHP XXXTQ |
#68 (permalink) |
![]() Join Date: Nov 2007
Member Number: 59274
I run the cx racing direct fit too. For the install, I removed the two side radiator support brackets. I flattened the hood latch support center bracket somewhat; the half below the crash bar, being careful not to damage fins on the radiator. This is easier if you make a few strategic snips in the thin metal of the bracket and bend outward. Next I used three or four washers on each bolt. The success here is that the rear of my IC doesn't touch or rub anything, and my hot side was no harder to install than on a factory IC. I had read where some people say it was direct fit but that's just not possible without most of what I did. After this little prep it fit, well, direct.
'05 SW ACR S3
#69 (permalink) |
I didn't need power tools because I wasn't unlucky. It went in all right. Got on it this morning and it ran great. Lost about a degree of knock throughout most of the powerband. That's all I really wanted out of a $180 intercooler.
#70 (permalink) |
![]() Join Date: Jan 2007
Member Number: 50159
How is the temp rise?
#71 (permalink) |
Temp rise is a little slower than with the stocker. The difference is not awesome, and certainly nowhere near BFMIC territory, but at least it makes a difference and now I won't get heat soak after two pulls in 4th. To be frank though, if I ever do go big turbo, I'll probably rip off the front bumper again and go BFMIC. This is definitely an intercooler for stock turbo people, however, and I feel as though I got all I wanted or expected for less than two bills.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
