Intercooler doubts - Page 4 - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 12-08-2012, 05:37 PM   #46 (permalink)
toofast82's Avatar
Member Number: 76443
Having had the stock fmic, spearco dfmic and an mpx fmic on stock turbo, i'd just get a bigger fmic honestly if your going to run pump 91-93oct. If you plan on running e85 or water/meth all the time, then the stock fmic will be plenty fine as the e85 will keep combustion temps cooler than pump gas and the water/meth will cool the air right before it reaches the throttle body
During 3rd and 4th gear pulls the air charge temps would go WAY above ambient on stock fmic.
On spearco dfmic, they would still heat up about 35-45* above ambient, much better than the stock fmic though
And on the mpx, temps stay pretty close to ambient, maybe 10* more on very hot days.
toofast82 is online now   Reply With Quote
Old 12-08-2012, 06:10 PM   #47 (permalink)
Member Number: 31038
Quote: Originally Posted by Turbolag87 View Post
It was next day at the track lol. Can't get better that
Fixed boost leaks with new intercooler install. :P
04 Neon SRT-4
Mopar S3, DSP, 888cc injectors, Dusters tune, Walbro 255 w/ S3 fuel system. NO rewire. e70 397whp/398tq 128k miles
99 Neon Sport Coupe
MPG Daily
2.0 DOHC, 5spd
s3*ps2 is offline   Reply With Quote
Old 12-09-2012, 12:13 PM   #48 (permalink)
Rhunter's Avatar
Member Number: 36794
Quote: Originally Posted by SoloSrt View Post
Hhhmm, maybe I should get a BFMIC before a 3" TBE?
Seriously through, I see that it isn't a "useless" mod on a stock turbo car. To each their own. I personally would do many other things first.
Fucking THIS!!!!!!!
Nunca Levanta!
EL RALFO RACING.COM
"A Lotta turbo, Small motor, and a GO pedal!!!"
Old 12-09-2012, 12:46 PM   #49 (permalink)
Lav
Lav's Avatar
Member Number: 79804
Well I am still on stock turbo and other than going E85 or meth i think ive done just about all I can do on stock without going big turbo which I dont have the budget for right now .
Tuned DSP
Bigger injectors
straight pipe exhaust
blablablabla those are the main performance mods , im working on getting a return line set up and look into E85 since it seems like a better option over meth .
As far as the IC goes seems everyone has had different results with BFMIC on stock turbos >__<
Lav is offline   Reply With Quote
Old 12-09-2012, 01:35 PM   #50 (permalink)
glhs837's Avatar
Member Number: 215
Quote: Originally Posted by jay05acr View Post
^in all honesty I think direct fit's are worthless.... Crash bar in this piece of shit isn't going to save anyone
Sorry, Jay, but you are wrong. The crash bar has a very important roll in the overall performance of the front crumple zone, and replacing it some welded up bar stock is nothing but using a piece of toilet paper on a machete cut.
That thing is a seriously engineered piece of HSS whole purpose is twofold. One is to crush and absorb crash forces directly, lengthening the time the impact takes, but more importantly, it redirects that crash energy into the front subframes, who's job it is to stretch out that impact time and change sharp impacts over a short time into less peaky forces over more milliseconds, reducing injury overall and helping the airbags keep your ass alive.
Why a crash beam is a good thing.
Old 12-10-2012, 08:15 AM   #51 (permalink)
Turbolag87's Avatar
Member Number: 6491
Lol
F&F Stage III 47lb turbo
+1 Race head, Race ported IM
BC 2 cams
Ext WGA
Meth Injection
11.4@125mph (old times, stock head and cams) 26psi
Turbolag87 is offline   Reply With Quote
Old 12-11-2012, 10:41 AM   #52 (permalink)
intshadeofblue's Avatar
Member Number: 84599
Testing intercoolers objectively requires a four-groups design: before and after with the old intercooler, and before and after with the new intercooler. Without looking at all four data values, you either miss out on establishing a baseline for comparison, or you miss any performance changes. Either way, you'll have no way of telling how the new intercooler affects the way your setup runs. For $180 shipped, the CXRacing Direct Fit is probably the best value for the dollar - performance gains may be minimal (although in most pump gas applications, heat soak will be reduced enough to justify the expense), but at least you won't be out $600, nor will you experience a 5psi pressure drop, as you would in the event you had invested in a BFMIC that doesn't measure up. For big turbo pump gas applications, the CXRacing DF will probably not be satisfactory. I'm buying this intercooler for my bolt-on stock turbo and putting it in next month.
'05 Silver - DD - 74xxx miles
E85 stock turbo - traction in 3rd is overrated
(Tune courtesy of the wizard known as Nigel/Turbo666)
Looks like stock, goes like stink
Hopefully getting 1/4 times before finishing grad school, but after getting slicks...
intshadeofblue is online now   Reply With Quote
Old 12-11-2012, 03:36 PM   #53 (permalink)
BLUBYYOU's Avatar
Member Number: 8826
Yeah, pretty much this.
You may not think you are losing pressure, but but you place a restriction like an EBay BFMIC in the way, it is a restriction. Period. Why? Because it does not flow the same amount of air as the stocker.
It's been years since I've seen it, but someone did an amazingly good flow vs efficiency test on all sorts of intercoolers. eBay crap ones, Spearco, stock, the gamut.
You boys need to find it. It's somewhere. I've read it and heed it because it is real bench flow numbers, and those don't lie.
Intercooler Shootout Results.
stage3 44lb+crane 14's+ACT clutch=
BLUBYYOU is offline   Reply With Quote
Old 12-11-2012, 04:12 PM   #54 (permalink)
Member Number: 3797
If you want an intercooler, get one. Not a crappy one, a good one and do it one time. It's been shown that you can do without or with just fine with the stock turbo. If you even think you will come close to maxing out the stock turbo or switching to a big turbo, get the BFMIC (a good one). If you are a chicken liver or feel the need to track your car, get one of the crash bar replacement thingys. Do not waste your money on a direct fit. Go big or forget it.
2003 SRT-4 Silver, AGP GT3076R on E85 DD!
Was 478hp/508tq ----> Now ???
2002 Camaro SS M6, going N/A...
enginjoe is online now   Reply With Quote
Old 12-11-2012, 05:50 PM   #55 (permalink)
Member Number: 88443
Ill post a couple of datalogs on the CX racing direct fit on stock turbo.
40 roll is offline   Reply With Quote
Old 12-11-2012, 05:56 PM   #56 (permalink)
By the way, don't misconstrue my input as hating on BFMICs - they're a great investment for big turbo pump gas cars or cars running very high boost in general. All I'm saying is that they're generally overkill for a stock turbo car that isn't maxed out, and not worth removing the crash bar for when perfectly adequate direct fit intercoolers are out there.
Old 12-12-2012, 02:11 PM   #57 (permalink)
csx321's Avatar
Member Number: 4534
Quote: Originally Posted by BLUBYYOU View Post
If I remember correctly, one problem with the shootout was that there were no cast end tank big intercoolers available to test. I have an ED Beast (which took a long time to finally find one for sale back when I bought it), and I have little doubt that its flow compares favorably with stock.
'04 SRT4, '87 Shelby CSX, '89 Shelby CSX, couple of others
2006 One Lap of America LER Media Crew
2009 Midwest SRT Nationals Attendee
csx321 is offline   Reply With Quote
Old 12-12-2012, 02:37 PM   #58 (permalink)
Member Number: 3797
There was another thread where _Nick_ did a comparison on his stage 3 car with a stock and the AGP DFFMIC. While the AGP was better, the stock IC was ok. He wanted to keep the crash bar and some money, so he sold the DFFMIC.
Old 12-12-2012, 04:46 PM   #59 (permalink)
jay05acr's Avatar
Member Number: 37744
Yea but wasn't he heat soaking like crazy at the track?
Go to wikyd-performance.com for all of your srt4 performance needs. Contact jtm0n3y or wonderer86 for more info
http://www.srtforums.com/forums/f416...-parts-639326/ my for sale thread
jay05acr is offline   Reply With Quote
Old 12-12-2012, 04:56 PM   #60 (permalink)
When he did that datalog he was also pushing the turbo pretty hard and he even said in his thread that the test he performed was probly harder then what most people would push the DFMIC.
