#16 (permalink) |
![]() Join Date: Mar 2012
Member Number: 88443
Iv had good results with my CX racing direct fit, my normal cruising temps are about 5-7 degrees above ambient and wot are about 12-15, temps drop VERY fast back down to normal temps within 30 seconds I'd say which means there's no sign of heat soak unlike the stocker which would take minutes to cool back down. I could also take a datalog for you.
| Sponsored Links | |||
Advertisement | |||
#17 (permalink) |
![]() Join Date: Aug 2011
Member Number: 85871
I'm also running the cxracing intercooler stock turbo no problems. Can't wait to put my big boy pants on and need a tunergeeks intercooler.
2003 Solar Yellow
12.79 @108.23 |
#18 (permalink) |
![]() Join Date: May 2004
Member Number: 11361
its been years, and i'm a big fan of my cx intercooler (big one with cast end tanks)
agreed, bend the center support -- and maybe a little sheetmetal trimming / washer for spacers
Build Thread:http://www.srtforums.com/forums/f451...w-123k-612933/
PCM=S0, DSP rescaled, 3bar map/tip injectors= Siemens 80# (ebay $200) built motor, 8.8:1 weisco, eagle-h, strap & windage S3R DCR manifold ($500) w/evo8 turbo (ebay $150) - 20G/47# ebay ($200) Evo 8 WGA 24x12x4 w/cast ends - CXRacing (ebay $200) DataLogger DataQA, $25 Wideband UEGO (ebay $150) vette rims 275/40/17 needswing v5 SouthBend S3 |
#19 (permalink) |
![]() Join Date: Dec 2005
Member Number: 36794
Ok a couple to things I would like to coment on regarding this thread and shitty Ebay inter-coolers.
- Just because you still "hold" boost using a shitty inter-cooler does not mean it's as good or better than the stocker. In most cases, when using a shitty ebay brand, you hafta turn up the boost a bit to equal the same pressure you had with the stocker. - The way we make more power in an engine is by improving the amount of "flow" to and through the engine right? We change out the exhaust, the head, the intake manifold in order to gain engine effiency (spelling?) which results in more HP. Why would you put anything in the mix that would be detrimental to flow? - So in closing, you want as little compromise in flow (but still provides a reduction in temp), as possible. The stocker is not that bad and unless you flog you car without mercy or going big turbo, I don't really see a reason to change to a different IC. disclaimer: This is my opinion, not a fact.
#20 (permalink) |
Member Number: 88421
I would stay stock unless there is a problem with yours. My stock one got shoved into the a/c compressor when previous owner hit something and broke a chunk out of the hot side pipe. I shoved the hose on farther and tightened the clamp to seal it up but after a while the hose would migrate back and make a big boost leak, so I ended up buying a cheapy intercooler off ebay to fix the leak.
Anyway I didn't notice any changes in performance between when my cars stock one was actually sealing and when I put my ebay one on so I was satisfied. If it ever fails I'm getting a good one though, probably a nice fat DFIC.
#22 (permalink) |
![]() Join Date: Oct 2006
Member Number: 46682
- Just because you still "hold" boost using a shitty inter-cooler does not mean it's as good or better than the stocker. In most cases, when using a shitty ebay brand, you hafta turn up the boost a bit to equal the same pressure you had with the stocker. - The way we make more power in an engine is by improving the amount of "flow" to and through the engine right? We change out the exhaust, the head, the intake manifold in order to gain engine effiency (spelling?) which results in more HP. Why would you put anything in the mix that would be detrimental to flow? - So in closing, you want as little compromise in flow (but still provides a reduction in temp), as possible. The stocker is not that bad and unless you flog you car without mercy or going big turbo, I don't really see a reason to change to a different IC. disclaimer: This is my opinion, not a fact. Yeah, pretty much this. You may not think you are losing pressure, but but you place a restriction like an EBay BFMIC in the way, it is a restriction. Period. Why? Because it does not flow the same amount of air as the stocker. It's been years since I've seen it, but someone did an amazingly good flow vs efficiency test on all sorts of intercoolers. eBay crap ones, Spearco, stock, the gamut. You boys need to find it. It's somewhere. I've read it and heed it because it is real bench flow numbers, and those don't lie.
![]() 17X7.5 Kosei K-1s / 12.2" Wilwood BBK (Dynalites) / Stage 2 IPP Coilovers / Prothane Polly / AEM SRI / Werks Hard Pipe Kit / DSP / AEM Wide Band / Clutchmaster Stg III / AL Flywheel ET:13.711 @ 101.3 - 2.196 60 Ft |
#24 (permalink) |
SRT of the Month ![]() ![]() Join Date: Mar 2005
Member Number: 25206
The stock turbo does benefit from a larger FMIC. Put the stock turbo on a loaded dyno and make a 4th gear pull during a 90+ degree day. IT GETS HOT! I've seen air temps vary as much as 50-60 degrees at 6k in 4th on a stock turbo. Similar mods with the major difference being one had a BFMIC while the other was stock.
In closing a BFMIC does help on a stock turbo.
04 SRT-4-10.18@150.3, and still a lot left in it...
Engine builds, dyno tuning, fabrication, and more available! PM me for pricing and details! Contact me for great prices on your part needs! http://www.facebook.com/BrutalSpeedAndTuning |
#25 (permalink) |
And by Big FMIC, he means my penis!! ![]() I guess a BFMIC would be one of it not the very last thing I would purchase for a stock turbo'd car. I'd look at the CX racing or the ETS direct fit over an ebay crappy IC anyday.
#26 (permalink) |
![]() Join Date: Jan 2006
Member Number: 37744
Ralph runs a Godspeed on his car
Go to wikyd-performance.com for all of your srt4 performance needs. Contact jtm0n3y or wonderer86 for more info
http://www.srtforums.com/forums/f416...-parts-639326/ my for sale thread |
#27 (permalink) |
![]() Join Date: Sep 2011
Member Number: 86347
04 SRT-4: Under Construction
99 9-3: Daily Driver FS Thread: http://www.srtforums.com/forums/f416...5/#post9777568 |
#29 (permalink) |
Fresh Meat Moderator
![]() Join Date: Dec 2009
Member Number: 76568
How did this turn into a ebay vs stock thread? It was about BFMIC vs stock (which is like a weekly debate).
CX racing does not make a bad intercooler and I would not call them a "ebay" intercooler. Sure they have a store on ebay but a lot of companies due now. They are nothing like godspeed which is COMPLETE shit. I switched between a stock and quickwhips BFMIC a lot a couple years ago and did a lot of datalogging. My intake temps were on average with the stock intercooler between 110-140 degrees on a hot summers day. With the quickwhips, 10-15 over ambient was the highest I saw. Car felt a lot better with the BFMIC.
![]() Diablo CMR tuner ~Dan~ 2004 Black Neon SRT4: E85 stock turbo SOLD ![]() 310HP 436TQ 2004 Eblue Neon SRT4: E85 5558 ![]() XXXHP XXXTQ |
#30 (permalink) |
CX racing does not make a bad intercooler and I would not call them a "ebay" intercooler. Sure they have a store on ebay but a lot of companies due now. They are nothing like godspeed which is COMPLETE shit. I switched between a stock and quickwhips BFMIC a lot a couple years ago and did a lot of datalogging. My intake temps were on average with the stock intercooler between 110-140 degrees on a hot summers day. With the quickwhips, 10-15 over ambient was the highest I saw. Car felt a lot better with the BFMIC. Dan I'm speaking of the god speed big fmic. They used to be sold by another company under a different name. Let's be real. 95 percent of guys who purchase a bfmic do it for looks and could care less about pressure drop or power for that matter. I mentioned stock IC because there are better ways to spen your money than on a big fmic. I know a stage 3 car that traps 120 with the stocker. That tells me it does not limit power as much as people think it will.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
