#1 (permalink) |
![]() Join Date: Jun 2010
Member Number: 79804
Hey all so Ive been reading up on old threads and doing some google fu on intercoolers , ive been seeing that i shouldnt go with a BFMIC since im still on a stock turbo , though I dont know how accurate is that , i was also reading up on AGPs direct fit , and also the CXRacing intercooler which i actually read good reviews on from these forums.
Anyway reason i ask is because my current one looks pretty beat up , lots of dings and bent fins , i dont know how to check if its good or whatever though , i mean i havent noticed anything bad temp wise and i hold boost just fine at 16-17 psi . But it looks terrible from all the rock chips/bugs/etc on it so im scared in the long run its gonna crap out or somethings gonna make a hole in it or something. I DO however have a stock IC i bought from someone here a while back, question is how can I test that everything is good with it before i replace the one I have on with this one? or should I do something like the cxracing one since itll be under warranty? |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
![]() Join Date: Jan 2006
Member Number: 37744
If your staying stock turbo dfmic is the best way to go, cx racing's are 175$ shipped
Go to wikyd-performance.com for all of your srt4 performance needs. Contact jtm0n3y or wonderer86 for more info
http://www.srtforums.com/forums/f416...-parts-639326/ my for sale thread |
#3 (permalink) |
Fresh Meat Moderator
![]() Join Date: Dec 2009
Member Number: 76568
Boost leak test and spray the whole intercooler with soapy water. If you see any bubbles its garbage.
I had a BFMIC on a stock turbo. Didnt notice any issues.
![]() Diablo CMR tuner ~Dan~ 2004 Black Neon SRT4: E85 stock turbo SOLD ![]() 310HP 436TQ 2004 Eblue Neon SRT4: E85 5558 Built motor ![]() XXXHP XXXTQ |
#4 (permalink) |
^your mom had a bfmic on a stock turbo
#6 (permalink) |
The different threads i came across all suggested that since it takes more time to fill or whatever that i would see a loss of power , i mean id like it for looks haha but yeaaaa.
So am i doing the boost leak test WHILE spraying the IC with soapy water or is there a certain procedure of doing this? Also , any way to see if the other IC i have laying around is good or bad without hooking it up? like some sort of way to see if it leaks or whatever? |
#7 (permalink) |
Spray the intercooler. Do a boost leak test. Look for bubbles.
I switched from stock to BFMIC a couple times and never noticed a power loss.
#9 (permalink) |
![]() Join Date: Jul 2005
Member Number: 31038
Cool ill be doing that this weekend then , gonna see what i can dig up on that cxracing ic while im at it too
Hahaha here is my 2 cents on the CXracing intercooler: CXRacing BFMIC Fitiment Issue! Not sure about the direct fit though.
04 Neon SRT-4
Mopar S3, DSP, 888cc injectors, Dusters tune, Walbro 255 w/ S3 fuel system. NO rewire. e70 397whp/398tq 128k miles 99 Neon Highline Coupe MPG Daily 2.0 DOHC, 5spd |
#11 (permalink) |
![]() Join Date: Sep 2005
Member Number: 33687
What all did you have to do to get the cxr direct fit to fit correctly? I read something about bending the radiator support. Also messing with the hood latch support?
S2 w/o toys, AEM intake, 3''maxxfab downpipe, Mopar/Borla exhaust, Agp hard pipes, 180 degree T-stat, $20.CC, sts, Eibach springs.
#12 (permalink) |
You just gotta bend in the center supports.
#13 (permalink) |
![]() Join Date: Oct 2006
Member Number: 46682
Basically you have to weigh the pros and cons. BFMIC might be more efficient (temp drop) but allow less flow (pressure drop). One if the best thing about the stock intercooler is its flow properties. It is a very good flowing IC, so less efficient, but less pressure drop. Sure, your ICTs will rise sooner, but the PCM can adjust for that by jolding more boost to compensate=you still hit your torque target.
![]() 17X7.5 Kosei K-1s / 12.2" Wilwood BBK (Dynalites) / Stage 2 IPP Coilovers / Prothane Polly / AEM SRI / Werks Hard Pipe Kit / DSP / AEM Wide Band / Clutchmaster Stg III / AL Flywheel ET:13.711 @ 101.3 - 2.196 60 Ft Last edited by SoloSrt; 12-06-2012 at 04:50 PM. |
#14 (permalink) |
![]() Join Date: Aug 2010
Member Number: 80981
To test the ones you got with out hookcing them up to the car. Cap one end and put the tester on the other end. Pressure it up. Squirt it down and check for leaks. I had bfmic on stock Turbo still boosted fine same operating. Temp same psi. Still on same one with my stage 3
05 flame red
bw Stage 3 47lb 20g By Mole' daily driven E85 ![]() |
#15 (permalink) |
![]() Join Date: Jul 2009
Member Number: 73847
ebay 4" core BFMIC on stock turbo.... Lowered my IAT's over 30 degrees on the track, and when I put my hand on the "cold side" of the stock intercooler after a pass or 2 it would be HOT, Ebay one, cool as the ambient air.
Also I have logs holding 18-20psi at 6k rpms stock turbo, held 24psi a couple times but it was under 25 degrees outside...... Dont buy into the hearsay.. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
