» Tire Upgrade Garage
Old 02-27-2007, 09:44 PM   #1 (permalink)
necal9's Avatar
Member Number: 46270
Wink Intake Air Temp. Hard Pipe, BOV?
I just installed my Greddy Type S BOV and hard pipe. The hard pipe did not have a slot or anything for the intake air temp sensor so im throwing the code 0113. When i throw the code i also get fuel cut at only 16 PSI.
How can i install the sensor in the hard pipe? Thanks
necal9 is offline   Reply With Quote
Old 02-27-2007, 09:47 PM   #2 (permalink)
Member Number: 17276
Trader Rating: (29)
uhhh....drill a hole in the pipe and get a grommet from ur old pipe and put it on there and then put the sensor in.
Quote: Originally Posted by mo'ssrt4
i am a free slut.
SilverSerfer is offline   Reply With Quote
Old 02-27-2007, 10:20 PM   #3 (permalink)
Checksum's Avatar
Member Number: 19673
and leak like a old wooden rowboat!
get a threaded temp sensor, drill a hole, weld a nut, screw it in nice and tight!
Checksum is offline   Reply With Quote
Old 02-28-2007, 11:19 AM   #4 (permalink)
vegasDSM's Avatar
Member Number: 726
contact agp...
get the threaded sensor... drill/tap.... cut/splice/solder the wires... you'll be set...
F this forum and it's bullshit ads......ekool has jumped the shark
www.myspace.com/vegasdsmr<--vids....................
http://www.WebPeople.us
http://www.WebPeopleVideos.com
vegasDSM is offline   Reply With Quote
Old 02-28-2007, 02:49 PM   #5 (permalink)
necal9's Avatar
Default Thanks guys
Thanks for all the tips. I will be getting a threaded sensor so i can be sure that i wont be leaking. Thank again
Page generated in 0.14845 seconds with 11 queries
