Old 12-14-2006, 10:33 PM   #1 (permalink)
Chino7385's Avatar
Member Number: 30157
Trader Rating: (21)
Default Installed DCR Oil Modifier today**PICS**
I put in my oil mod today and tooks some pics while i was at it. Took the coil and wires off. Disconnected the pcv line. Then took off the valve cover (Nine 8mm bolts). Took off the cam sensor (Two 10mm bolts).
Got the cam cap off (one 8mm and two 10mm bolts). Tapped it gently with a screw driver handle to get it loose.
Installed the oil modifier.
Cleaned up the valve cover and gasket of old silicon.
Cleaned the head of old silicon and torqued the cam cap.
Put new silicon on where Aaron from RealTune said to put some and in the corners where the old silicon was. Put the valve cover and cam sensor back on.
Done! Just put the coil and wires back on and the pcv line.
I let it sit for an hour and a half while i rerouted some lines and removed the red line, capped where it was. Started the car and let it idle for about 10-15 minutes, no leaks. Drove around for a while, no leaks. Did a few runs, no leaks. Mid-high end there was noticeable gains. Best mod ive done under $100.
For those not sure what the oil modifier is, heres an explanation by Aaron at RealTune. Look at post #10
Alright Aaron. Lets talk Oil modifier
*98 Neon R/T:Too Many mods
*00 Celica GT-S:I/E,STS,S-Tech's,S2k Antenna
*04 SRT-4:AGP 50Trim Kit,S1,S2 Inj,S-AFC2,AEM Wideband,Turbo XS HPBC,PTP Direct Fit,PTP UHP-HKS SSQV,PTP 180 T-Stat,PTP CV,Maxxfab Magnaflow 3" TBE ,CoolingMist W/I 50/50 Mix M5 Nozzle,DCR Oil Mod,AEM SRI,MSD Wires,Bwoody MM's,Maddog 72%,Aeroforce Pro,255 Pump and Rewire,K-Sport CO's
Not installed: DSP, Redstar Return Line,
Chino7385 is offline   Reply With Quote
Old 12-14-2006, 10:33 PM   #2 (permalink)
ninja5611's Avatar
Member Number: 21261
Trader Rating: (13)
nice work
ninja5611 is offline   Reply With Quote
Old 12-14-2006, 10:39 PM   #3 (permalink)
supermech21's Avatar
Member Number: 42969
Trader Rating: (72)
very good...im planning on doing this mod in the next couple of days....so you reused the old gasket and just put RTV over it or permatex whatever you wanna call it...i noticed where you pointed out to put some sealant (arron neon said) mine is leaking their too...how long did it take to drop in?
Old 12-14-2006, 10:41 PM   #4 (permalink)
Chino7385's Avatar
Trader Rating: (21)
Installing this tomarrow.
Check valve is on the way in the mail.
Old 12-14-2006, 10:46 PM   #5 (permalink)
Chino7385's Avatar
Trader Rating: (21)
I took my time, bumping to some music. Took me about 25-30 minutes and then waited an hour and a half for the silicon to dry alittle. Had ZERO leaks after a few runs so it should hold. Yeah, i reused the gasket. It was still in good conditon. Just make sure you get the old silicon off.
Old 12-14-2006, 10:47 PM   #6 (permalink)
SilveRT-4's Avatar
Member Number: 20330
Trader Rating: (26)
Make sure to remove that filter in the middle. Even on it says not to be used with synthetic oils.
Blue EVO IX
Tanabe Exhaust / Cone Filter
2004 Srt-4 .50 trim
*traded in*
SilveRT-4 is offline   Reply With Quote
Old 12-14-2006, 10:49 PM   #7 (permalink)
Chino7385's Avatar
Trader Rating: (21)
^thanks, i didnt even see that.
Old 12-14-2006, 10:50 PM   #8 (permalink)
SilverBullet's Avatar
Member Number: 28
Nice work! I'll be doing this sometime soon.
Mods:
- Mean-looking Headlight Stickers (Pat#D0507845)
- Red and Blue buttons
- MaxxFab SEE
- Zipties (and lots of it)
My other avatar.
SilverBullet is offline   Reply With Quote
Old 12-14-2006, 11:49 PM   #9 (permalink)
Cruiserdude's Avatar
Member Number: 2849
Yeah, its not needed since you won't be reusing that oil (we hope ). BTW, that's the exact same separator I used for my $20 CC, works great.
Trying to determine exactly what the DCR oil modifier is exactly? Sorry, call me stupid, but I somehow didn't catch it.... Sounds pretty sweet, though!
Praying for HemiDakota, hang in there!
MODS:Stage 2 w/ toys, BDJ's 3" SEE, Maxxfab 3" O2 housing, PTP WGA 22-17, Psi-fi CAI, 55mm TB, 30psi gauge, Mopar sway bars, Psi-fi LCA's, MM inserts, MPx MM bolts, Mopar BOV, $20 CC, Mopar STS, T-Bolts, PTP checkvalve and heatshield
Wish List: Walbro 255, wideband, DSP, FMIC, coilovers
Cruiserdude is offline   Reply With Quote
Old 12-14-2006, 11:56 PM   #10 (permalink)
OrAnGe-SrT4's Avatar
Member Number: 29828
Trader Rating: (30)
May I ask what kind of oil you are using? It looks to me as if your spark plug seals are leaking, gaskets don't look torn so I'd recommend putting RTV on the seals there to.
OrAnGe-SrT4 is offline   Reply With Quote
Old 12-15-2006, 12:07 AM   #11 (permalink)
Trader Rating: (72)
thanks chino, awesome write up....im gonna do mine on sunday
Old 12-15-2006, 12:13 AM   #12 (permalink)
Chino7385's Avatar
Trader Rating: (21)
Yeah i did notice that their leaking. I wasnt sure if i should use the red rvt i had. Ill probably take the valve cover off real quick tomarrow and take a closer look at the seals. As for the oil, i just got the car a moth and a half ago and the dealer said the oil had been changed when they got the a month before. I checked the oil and it looked to be regular non-synthetic oil. Ill be changing it this weekend with mobil one.
Old 12-15-2006, 12:56 AM   #13 (permalink)
Chino7385's Avatar
Trader Rating: (21)
Na, i dont think ill be reusing the oil lol. I put a link on the bottom of the first post. Theres a explanation to what the oil modifier is. Look at post #10 on that link btw.
Old 12-15-2006, 03:14 AM   #14 (permalink)
Member Number: 2849
Sweet, looks good. My bad, don't know how I missed that link down there, haha.
Old 12-15-2006, 01:26 PM   #15 (permalink)
Chino7385's Avatar
Trader Rating: (21)
It wasnt there when you asked about it. I put there afterwords.
Page generated in 0.19870 seconds with 13 queries
