Quote: Originally Posted by
05BlackSRT
I had the stock wastegate and stock boost gauge and got a greddy profec b spec 2 boost controller..turned the boost up..and the gauge was wrapping around almost to the vaccuum section...well i put a different gauge in there and it showed like 18 psi..so yeah those gauges blow..now i have an agp wastegate and a turbo xs manual boost controller..it spikes about 22psi and holds about 17 on stock everything..and has for probly 20,000miles..and it runs!! lol
If you have the money sitting around and aren't afraid to try something, give the Forward Motion wga a try. I had the AGP wga as well. It was the first wga I tried. It was great a the time. I just hated the how it would drop off so much by redline and the compressor surge and part throttle boost was killing me. babying the car while it was under 3k rpm sucked ass. I talked alot to addictedtosin and figured I would give the FM wga a try. If it didn't work I would just resell it and go back to the AGP wga.
Installed the FM wga when it arrived and never looked back. Runs much better than the AGP, part throttle boost was greatly reduced along with compressor surge. Plus it holds boost much better to redline than my AGP.
AGP: spiked 23 psi and it would fall to 16 at redline
FM: spiked 22-23 psi and it would fall to 19-20 at redline
FM: spiked 24 psi and it would fall to 20-21 psi at redline
This is all on aftermarket boost lines (turbo -> wastegate actuator)
