ok i work at a dodge dealership and we got a motor with a stg 3 and they didn't want the motor soooooo i toke it.it has the turbo/mani,got the fuel rail with injectors and the 3.0 map sensor.i know i need the fuel pump,3.0tip sensor and pcm.is there anything else i need.because i was wondering if i can use a map clamp to replace the stg 3 pcm and get a walbro fuel pump,but i need the tip sensor so if anyone can help me out that will be great.free ftw!!!
I am reporting you to the police. I'm just joking i would have done the same thing. well since you don't have toys make sure you get the non toys pcm.
nooblet, you obviously don't know what you are talkin about so please don't speak unless you are a 100% sure on what you are talking about. thx
to clear up what the nub said, all S3's have the toys programing. weither you ordered it w/toys or without it still comes with the programing, you just need to get a aftermarket toybox like the one n2mb sells.
i personally wouldn't waste my money on a S3 pcm, i would get in touch with agp and speak with them about there sct flash. cheaper and waaaay more effective. and don't use a mapclamp, get a good piggyback such as a afc or a dtec
Ruthless.
TRACTION PWNS ME!!
ANTI-SWEETS CLUB MEMBER # 2
alright coo, i was wondering since i work for dodge is there any flashes i can use on the drb with the stock pcm,probably,but never hurt to ask.also as far as the 3.0 bar tip sensor where can i get those separetly,i couldn't careless about toy's,im installing the injector,fuel rail,turbo/mani and map sensor tommorow can i still run the car like that i know can,but can't do anything crazy.ima get an afc off a buddy,but no time soon.sooo what else should i do that would help.
unless you have a sct flash, ems, s2 or s3 pcm, you cannot run those sensors. your stock pcm will freak out and idle like shit and hold revs. just install the turbo, mani, fuel rail, and if you cannot get your hands on a piggyback, use a mapclamp to pull some fuel with those injectors. make sure you have a wideband to monitor your afr's though.
dont even look into doing a factory dodge flash do what foxracing12002 said to do and look into the SCT flash, or s-afc2, d-tec, or EMS (if you can afford it)
dont go the cheap way and buy a mapclamp.
ok i installed the stg 3 turbo with the injectors or pcm ima boosing low i have the agp wsg.it pulls hard on the higher rpm band it feels lean,so i need injectors stat.i might use a map clamp for now intell i get either a stg3 pcm or a safc.can anyone tell me where the tip sensor located?
u should prolly sell it cause i would NEVER use a map clamp on a stage 3 ur just asking to blow up ur engine. u just got all of this for free and u cant spend 200 bucks on a safc. i would look at getting a wideband and a safc 2 or neo next
ok well first of all i just got a wideband and im not gonna use a map clamp,i still need the stg 3 pcm the safc might as well be a map clamp to pull fuel.
