Old 07-02-2009, 11:48 AM   #1 (permalink)
Member Number: 54437
Trader Rating: (13)
Default I want to go bigger than a 60 trim ...
Hey guys, currently I have a Garrett t3/t4 - 60 trim on my car running 22psi. I am in the process on breaking in the new motor and when done, going to retune it for 32psi on race gas and 26psi on pump + meth. The 60 trim on 22psi without the cams I have now only made me 330whp which I was disapointed with.
I am wanting some suggestions and some next step ideas on what next step up size turbo to get.
I am looking at getting one of the PTPerformance manifolds that are in development to bring the turbo around to just infront of the battery so running a large turbo would not be a problem.
I am thinking of something like a GT40 or simular. Does anyone know of any other company that makes a manifold for the srt-4 with a T4 flange?
My goal is to reach over 500whp on race gas to break into the 11's on drag RADIALS. (Must run street legal tires in the events I run in at the track)
05 SRT. Garrett 60trim "Baby Kahuna", Tial 38mm, Wiseco pistons, Eagle rods, BC S2 cams, ARP headstuds, SPEC stage 3+, AEM EMS, RC750's, tokico illumina 5 way's, Eibach Sportline springs ,Cooling Mist water/meth injection, Mopar exhaust with electronic cutout. Plus much more.
Dasstrum is offline   Reply With Quote
Old 07-02-2009, 03:38 PM   #2 (permalink)
SkittleSrt-4's Avatar
Member Number: 68684
330 whp on 60 trim it don't make sense why so low?
Asian Srt-4 owner 05 Black Srt-4
-Aem SRI
-3" Full Turboback
-maxzone Tails,Mpx shorty Ant.,
-TWM short throw
-Agp billet wastegate(16.5psi)
07 Rally yellow stage 2 cobalt ss(daily driver)( down due to my idler pulley snap off
SkittleSrt-4 is offline   Reply With Quote
Old 07-02-2009, 03:46 PM   #3 (permalink)
rubicon04's Avatar
Member Number: 26253
something is seriously wrong with your new motor or the tune. 330whp at 22 psi is horrid for a 60 trim. Look at the numbers in my sig at 22lbs. I would stay away from ptp products personally. There is no reason to run a turbo the size of a gt40 to just break 500. the 60 trim you have will get you there on race gas. A standard 50 trim can come close to 500 on race fuel. If your set on getting a larger turbo i would look into agp's delta series. A D55 or even D65 would be perfect for your needs and fit just fine while not being fucking lag monster like a gt40
04 black stock turbo- gone
05 white 60 trim -407whp and 389ftlbs at 22 psi on 93-sold
Tk tuned by TIM R.I.P
rubicon04 is offline   Reply With Quote
Old 07-02-2009, 03:51 PM   #4 (permalink)
red04's Avatar
Member Number: 24993
Trader Rating: (49)
I have two turbos in mind for you that work great with a well rounded combination. One made 431 whp @ 18 psi of boost and the other made 503 whp @ 22-23 psi of boost. Both were done on pump gas with very conservative tunes. Feel free to contact us for more info.
Scott @ Forward Motion Inc.
302-658-2829
www.forwardmotioninc.com
Email: scott@forwardmotioninc.com
Paypal Address: scott@forwardmotioninc.com
Owner of FM's GT37R powered SRT4 513 whp 469 wtq pump gas (93 octane) @ 6,000 rpms
11.31 @ 131.74 mph w/ 1.90 60'
red04 is offline   Reply With Quote
Old 07-02-2009, 04:46 PM   #5 (permalink)
bene's Avatar
Member Number: 53801
Trader Rating: (40)
gt35 or a delta 55 would be perfect for 500hp
bene is offline   Reply With Quote
Old 07-03-2009, 07:32 PM   #6 (permalink)
Trader Rating: (13)
Wasn't on a Dynojet, this was on a Dyno Dynamics which read notoriously low compared to what most guys dyno on (dynojet). The car did trap 119 and change on pump gas at 22 psi so I wouldn't say the tune is too far off.
So to reach my goals on the dyno dynamics I'm going to need a decent size turbo, say 37r or maybe the new PTE 6262. I'm still researching options but any suggestions are very welcome.
Old 07-04-2009, 11:04 AM   #7 (permalink)
2004NeonSRT4's Avatar
Member Number: 4577
Trader Rating: (44)
the 60trim should do what you want or close to it. you need to look in other places. and you deff dont need a turbo mani that relocates it to the front. if your bent on changing turbos go with a d55. i say there are many other places/parts and problem to fix first
2004NeonSRT4 is offline   Reply With Quote
Old 07-04-2009, 11:33 AM   #8 (permalink)
Rhunter's Avatar
Member Number: 36794
Very true about the Dyno Dynamics dynometers. the goog thing tho is they provide a usable street tune. I've heard of some cases where dyno jet tunes need to be adjusted for the street. Don't know if that's a fact just what I've read.
From the limited research i've done on Dyno Dynamics, if you add 12% to their readings, you can compare it to a typical dyno jet.
But I don't think a bigger turbo is what you need. If you must have street legal tires look into the mickey thompson DOT legal drag tires.
Old 07-04-2009, 11:37 AM   #9 (permalink)
conroy9940's Avatar
Member Number: 46401
Trader Rating: (114)
at 330 whp on a 60 trim at 22 psi... how much timing? what afr's? probably getting 59034889 degrees of knock as well
honestly, take your car to a good tuner.... drive it to realtune.. 32 psi on a 60 trim is a waste and will only hurt the turbo.
Pittsburgh Penguins 14-8-0 28 points
Old 07-04-2009, 12:46 PM   #10 (permalink)
Trader Rating: (13)
The tuner I use, his name is Mark and owns Fastec in Knoxville, TN. For those that live near Knoxville, they know he is the best tuner in the area. He has rebuilt, tuned, and dyno'd many cars including his drag WRX that put down around 950awhp on the dyno dynamics. So im pretty sure he knows what he is doing. My Air/fuels were around 10.9-11.4 all the way to redline with methanol.
Old 07-04-2009, 01:31 PM   #11 (permalink)
srt4crazy05's Avatar
Member Number: 54763
obviously not if ur car is making 330whp(369whp adding 12%) at 22psi with meth. something is wrong somewhere. if u get a bigger turbo ur gonn slow urself down. a 37r can make 700whp+. u dont need anything like that. the 60 trim can do it but it will be easier with a 35r or a d55. i recommend u take ur car to a different shop to get tuned. if i were in ur shoes i would be pissed off, not trying to find a bigger turbo.
but go ahead and spend more money on a setup good for 700whp when ur tryin to get 500
13.463 @ 103.71mph 3 bolt ons n street tires. stock suspension. mm inserts. no tune
srt4crazy05 is offline   Reply With Quote
Page generated in 0.17725 seconds with 13 queries
