Hot/cold side pipes - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 02-21-2012, 06:54 AM   #1 (permalink)
Roided-srt4's Avatar
Member Number: 78521
Default Hot/cold side pipes
Not sure if this is the right section, but was wondering what was the best brand out there and what is the best BOV to use with it?
Thanks
Yes I like the "EVO" mod, to each his own!
Roided-srt4 is offline   Reply With Quote
Old 02-21-2012, 07:18 AM   #2 (permalink)
Member Number: 8519
Everyone will say that you don't need hard-pipe and you don't need a BOV. But to answer your question they are all pretty much the same i like AGP for hard pipe and if your going to run a BOV get a HKS or a greddy
BWS/EXT Gated & ported MANI @ 20PSI + E85, ACT HDG6, 3" TBE, BFMIC, 255 & 1025's w/Duster rescale... Awaiting Dyno and Return fuel setup...
Spare motor apart now accepting parts..
Casimer76522 is offline   Reply With Quote
Old 02-21-2012, 07:56 AM   #3 (permalink)
Fresh Meat Moderator
Member Number: 76568
Hes on a big turbo.
AGP hardpipes fit nice.
I would personally get a Tial blow off valve though. One of the best performing blow off valves out there.
Old 02-21-2012, 08:24 AM   #4 (permalink)
Ok, thanks now are all blow valves compatible with the AGP hard pipe or just certain ones?
Old 02-21-2012, 08:45 AM   #5 (permalink)
eblue_903's Avatar
Member Number: 76158
Yes they are. U just have to make sure you get the right flange welded on when you order the Hard pipe. There will be a drop down menu to select from while ordering.
E1, AGP SOLID MM, STG 2 INJ, DSP, AGP WG,
best 1/8 E.T. - 8.6 @ 89.9 w/ 2.2 60ft. on street tires
NEW SETUP- AGP 50T 63 A/R., TurboXS RFL, DW 750cc injectors w/o return line, DSP, N2MB boost box,CM Stg 3 clutch, i never use less than 100 oct.
mods awaiting installation- CM direct port meth, CryO2 intercooler chiller and a few other small things.
eblue_903 is offline   Reply With Quote
Old 02-21-2012, 09:06 AM   #6 (permalink)
Ok thanks. I will look into the AGP hard pipe than. Thanks
Old 02-21-2012, 09:07 AM   #7 (permalink)
BTW are the ones from turboneon store junk?
Old 02-21-2012, 11:52 AM   #8 (permalink)
kagekun's Avatar
Member Number: 57941
I wouldnt buy anything from that site, ever.
kagekun is offline   Reply With Quote
Old 02-21-2012, 12:24 PM   #9 (permalink)
Monster's Avatar
Member Number: 48761
Why not?
Old 02-21-2012, 12:44 PM   #10 (permalink)
kagekun's Avatar
Tho some have used them and had no issues.
I personally was screwed over many years back and dealt with some terrible customer service.
I haven't had reason to give them another chance.
Old 02-21-2012, 12:50 PM   #11 (permalink)
Well I guess that is like any company I suppose, I have dealt with the same company one day and then the next you get horrible service. I'm just wondering if the pipes they sell are any good?
Old 02-21-2012, 02:20 PM   #12 (permalink)
eblue_903's Avatar
I've ordered from them a couple times and really had no issues. I think i had one issue with them not sending an item but they corrected it after i called them. However, i really don't like to order from them unless i can't find what i'm looking for elsewhere besides that Modern Performance is the more preferred place to order from. The Ultimate Racing hard pipes i do not know about, I haven't heard of very many people that use them.
Old 02-21-2012, 04:41 PM   #13 (permalink)
Ok, thanks for the feedback.
Old 02-21-2012, 05:47 PM   #14 (permalink)
Rhunter's Avatar
Member Number: 36794
Derek!!
Don't you dare spend money on hard pipes!!! This falls into the if it ain't broke, then don't fix it category.
If you are wanting a different blow off valve, you can get an fitting that you use with your stock pipes.
If you think your stock pipes are flexing, I have a fix that will cost you all of two bucks. Matter of fact we can do it on Thursday. I can also show you the BOV fitting I'm talking about. I have one on my 03.
Nunca Levanta
A Lotta turbo! Small motor! And a Go Pedal!!
Lets re-grow the community! Subscribe to: www.elralforacingmedia.com
Old 02-21-2012, 06:22 PM   #15 (permalink)
Ok, cook but they look so much better than stock pipes doesn't that at least give me like 5 more HP? Lmao
