Help: replaced PCV valve, still whiteish smoke after a hard pull - Dodge SRT Forum
post #1 of 19 (permalink) Old 01-07-2008, 03:53 PM Thread Starter
New Member
Tripl3black_SRT-4's Avatar
Quoted: 0 Post(s)
so after i make a hard pull, my car always pours out a decent amount of smoke a few seconds afterward. doesnt really do it much after a 2nd gear pull, but after a 3rd gear pull it pours out quite a bit, and it smells something fierce i know its not coolant because my coolant level always stays the same, and these fumes smell like burning oil. im thinking that either my turbo seals are going, or maybe the head gasket. my car has a stock turbo, only 49,000 miles. what do you guys think it is? btw this problem is non-existent under normal and somewhat spirited driving conditions
OBJECTS IN MIRROR APPEAR TO BE LOSING
Tripl3black_SRT-4 is offline
post #2 of 19 (permalink) Old 01-07-2008, 04:29 PM
New Member
StockSRT-4's Avatar
Quoted: 0 Post(s)
do you have a check valve?
05 Stage 2 Orange Blast
AEM CAI
Koyo Radiator & Mishimoto Slim Fans
CBD Air Induction Hood & Eyelids
Tein S. Techs
eBay MBC & CF Tails
17" ADR w/Chrome lip
StockSRT-4 is offline
post #3 of 19 (permalink) Old 01-07-2008, 04:31 PM Thread Starter
New Member
Quoted: 0 Post(s)
no sir, but i do have a properly fuctioning oil catch can though
post #4 of 19 (permalink) Old 01-07-2008, 04:44 PM
New Member
StockSRT-4's Avatar
Quoted: 0 Post(s)
oh did u check your oil to see if its a tad frothy?
You might have been building boost in your case & that can blow seals or cause blown head gaskets (white smoke) especially after a hard pull.
AEM CAI
Tein S. Techs
eBay MBC & CF Tails
post #5 of 19 (permalink) Old 01-07-2008, 04:57 PM Thread Starter
New Member
Quoted: 0 Post(s)
the oil in the catch can is really creamy and light, but i heard its like that in the winter months. last time i changed my oil (a month ago) looked fine, plain, black, runny lol. but on the valve cover, isnt it ok to cap that nipple going to the intake? i have it capped on the cover and on the intake. is this ok?
post #6 of 19 (permalink) Old 01-07-2008, 05:02 PM
New Member
KlugSRT-4's Avatar
Quoted: 0 Post(s)
FUCK NO! Do not do that!
LLk
KlugSRT-4 is offline
post #7 of 19 (permalink) Old 01-07-2008, 05:06 PM Thread Starter
New Member
Quoted: 0 Post(s)
omg wtf! the guy that put my downpipe and o2 in capped it and said itd be ok... when i thought about it it didnt make sense. what does that line actually do, the one coming from the head? does it vent pressure from the crankcase/ block?
post #8 of 19 (permalink) Old 01-07-2008, 05:09 PM
New Member
KlugSRT-4's Avatar
Quoted: 0 Post(s)
Yes. It vents just like the PCV Valve does. But it is not restricted like the pcv valve is. Its so when you are under boost it vents out the boost that is trapped in your crankcase. IMO it is more important then the pcv valve side of it. Under boost your PCV valve is closed and with that plugged there is nothing letting it out besides your dipstick and a couple other places you dont want it to.
I really hope the guy that you had put it on isnt a mechanic or anything. If he is dont go back to him please.
LLk
post #9 of 19 (permalink) Old 01-07-2008, 05:12 PM
New Member
StockSRT-4's Avatar
Quoted: 0 Post(s)
yea I guess but u gottathink thats just pushing more air back into the case when your under boost if u don't have a check valve.
I have never seen oil in a catch can creamy in my car even in winter ( just checked it again) It may happen idk just in my experiences. White smoke is generally coolant burning up, could be other things but generally coolant(blown headgasket, cracked block etc) if its happening right after a hard pull you probably have a worn headgasket. Thats not always the case though. You said you don't lose any coolant?
Have you checked the resevoir fill line or just take off the cap on the thermostat housing? Because it pulls/pushes coolant when it needs it.
Check your oil dipstick see what the oil looks like. Drain some of your coolant and look if there's oil in it(it will be colory rainbow shit u know what I mean ifbu ever see it spilled on the floor)
I had these same symptoms In my prelude and sure enough it was a blown headgasket!
AEM CAI
Tein S. Techs
eBay MBC & CF Tails
post #10 of 19 (permalink) Old 01-07-2008, 05:17 PM
New Member
KlugSRT-4's Avatar
Quoted: 0 Post(s)
The bold is dumb. the PCV Valve is a check valve. So it is not pushing any boost into your engine. People run check valves just incase your catch can is leaking or a hose, etc. But the pcv valve is closed when under boost.
The milky oil in the catch can is completly normal. Water with synthetic does that.
LLk
post #11 of 19 (permalink) Old 01-07-2008, 05:18 PM
New Member
StockSRT-4's Avatar
Quoted: 0 Post(s)
yea that vent is also for emissions purposes, it vents unburnt fuel back into the intake to be reburnt.
AEM CAI
Tein S. Techs
eBay MBC & CF Tails
post #12 of 19 (permalink) Old 01-07-2008, 05:19 PM
New Member
KlugSRT-4's Avatar
Quoted: 0 Post(s)
hahahahahaha What? Thats called a EGR. Has nothing to do with anything we are talking about.
LLk
post #13 of 19 (permalink) Old 01-07-2008, 05:20 PM
New Member
StockSRT-4's Avatar
Quoted: 0 Post(s)
yeamy b I take that back but the point is u don't want pressure in your case, if it did happen to blow out the dipstick there would be oil everywhere u don't want it!
AEM CAI
Tein S. Techs
eBay MBC & CF Tails
post #14 of 19 (permalink) Old 01-07-2008, 05:25 PM
New Member
KlugSRT-4's Avatar
Quoted: 0 Post(s)
True. Best case it vaccum in the case all the time. The only way to do that is to have your pcv valve hooked to your intake manifold after the throttle body. The pcv valve, is a check valve. You only need another check valve if you are running high boost and/or catch can that could leak. The vent on the right needs to be hooked into the air intake for the turbo. so when you are under boost the pcv valve is closed, not letting anythin in or out. The only thing that is under vaccum is the air intake for the turbo and that is where the vent on the right side needs to be hooked up to.
LLk
post #15 of 19 (permalink) Old 01-07-2008, 05:38 PM Thread Starter
New Member
Quoted: 0 Post(s)
ok i fixed the capped off nipple on the intake/valve cover. i put a straight piece of hose in between them, as it came from the factory. what gets me is this guy makes and tunes 50 trim kits for our cars, fuel return line kits, etc etc etc... what the f***!!! though! that always seemed weird b.c. i knew it was a vent of some sort. wow. well my car never burned anything before this happened. now with this hose in place, if i still have smoke coming from my pipes after a pull, then someone is gunna get a nice little visit from me
User Tag List
Linear Mode Linear Mode
