#16 (permalink) |
![]() ![]() Join Date: Mar 2005
Member Number: 25514
thats why youre leaking boost. look up DCR's thread on "these engines need vacuum all the time". you should hook your breather back up to the intake. the PCV will leak a bit when you blow into it, but when on the car with the v/c vac system set up correctly it should recirculate and not leak. hook your vc back up to the intake.
They still leak and its not the way he has it hooked up that is causing the leak to happen, the factory PCV system leaks, its as simple as that. I also want to add, that if you have a vacuum on you intake side of the turbo (CAI or SRI) you had better check your filter. There is no way the intake should create enough vacuum to cause any noticiable differnece in the crank case evacuation. I have tested this and with the proper clean filter and at WOT running full boost the intake doesnt make .2 worth of vacuum. Now with a dirty filter (different car) we did see 1.5 inches of vacuum, but that is not good for the turbo or the performance of the car. You should never ever see vacuum on the turbo inlet side of your system, it means you have a restriction somewhere.
To make a purchase please go to www.pt-performance.com Shop hours: 10am to 7pm Mon-Sat Shop numbers: 253-277-3843 253-653-3843 Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4 DSP or Trinity tunes send your request to tunes@pt-performance.com For all other questions send them to ptperformance@comcast.net "We build street cars you drive at the track, not race cars you drive on the street" Last edited by ptperformance; 06-28-2009 at 02:53 PM. |
| Sponsored Links | |
Advertisement |
#17 (permalink) |
Im only agreeing with one thing here. I dont belive that grainger stuff is POS. I work around that stull at the time. The only thing I agree with is the high cracking pressure on the grainger on I have. I would have bought PT's, but I think there price is very high for a CV. I dont need the 90* piece on it or the rubber hose, and I have the barber connector already, I just need the CV. 40 for a part like is way overpriced IMO. ....Never would crap on PT, but I would like to hear an unbiased opinion
There was an indepent test that was performed on these about 4 years ago, search function and you should find it. The results were tested against 2 other check valves and ours killed both of them hands down. I understand that you don't need the other parts, but we designed this CV for the masses, we have to buy them 100 at time in order to get the price down to the $40 that we sell them at, if not I have to pay $22 each for the valve alone, not including brass, hose, zip ties, assembly and testing each and every unit after they are assembled. Trust me, there is not a huge profit margin on these like people thing there is.
To make a purchase please go to www.pt-performance.com Shop hours: 10am to 7pm Mon-Sat Shop numbers: 253-277-3843 253-653-3843 Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4 DSP or Trinity tunes send your request to tunes@pt-performance.com For all other questions send them to ptperformance@comcast.net "We build street cars you drive at the track, not race cars you drive on the street" |
#18 (permalink) |
![]() ![]() Join Date: Jun 2008
Member Number: 64878
I understand that you don't need the other parts, but we designed this CV for the masses, we have to buy them 100 at time in order to get the price down to the $40 that we sell them at, if not I have to pay $22 each for the valve alone, not including brass, hose, zip ties, assembly and testing each and every unit after they are assembled. Trust me, there is not a huge profit margin on these like people thing there is. Definatly understandable. Mabey if you had something like a group buy going on, Id be in.(hint hint, wink wink) Im sure people would line up in one.
Metal Werkz - For Sale: New Custom Aluminum Door Sills and Radiator Shrouds!!!!!! Click here for my site.
#19 (permalink) |
![]() Join Date: Oct 2006
Member Number: 47689
try this one the one i have is like this
Pneumatics & Hydraulics > System Components > Pneumatic Check Valves > Valve,Check,1/2 In : Grainger Industrial Supply
click>>>myfloridasrt
NorthNJSRT4 is a worthless pos mod and who should not be listened to and likes to delete posts and lock threads for no reason . and needs to ![]() |
#20 (permalink) |
Pneumatics & Hydraulics > System Components > Pneumatic Check Valves > Valve,Check,1/2 In : Grainger Industrial Supply they never say the crack pressure of the valves though.
#21 (permalink) |
click on add info # Valves open at less than 1 psi with maximum operating pressure of 400 psi. # All-brass bodies with filled Teflon(R) poppets and stainless steel springs. 1/8" (F)NPT tapped port for pressure switch unloader connection. Maximum temperature: 400 DegreeF.
#22 (permalink) |
![]() Join Date: Jun 2005
Member Number: 30144
Pneumatics & Hydraulics > System Components > Pneumatic Check Valves > Valve,Check,1/2 In : Grainger Industrial Supply looks like a winner to me, i might snag one of these soon. -Keegan
#23 (permalink) |
-Keegan it has the volume but with the fittings on it may be 6 in long but it can hide under the intake manny
#24 (permalink) |
Looks good to me. and in case anyone was wondering. The specs say opens on less than 1psi, but our gauges are in In/mg, So according to this site Pressure units converter | Convert to units measures. 1lbs = 2.04 inhg. Just divide the vacuum in half to convert to lbs. So that CV seems fine.
#25 (permalink) |
![]() Join Date: Aug 2005
Member Number: 33121
I run a grainger CV and have been for the past 3 years. Never had 1 problem with it. The one i have does not look like either of the links here. But its big. If i remember right mine ran me about $20-25 and that included the 3/8" threaded ends for each side.
#26 (permalink) |
Any clue on that part no.?
#28 (permalink) |
That looks exactly like the PT one. Hmmm
#29 (permalink) |
no i dea on the part number on mine...i just walked into grainger and said give me the strongest one you got...this things big! but i see the one above is a 1/4"ends...mine are much bigger coming in at 3/8" and fits the fuel line i ran perfectly which is 3/8"
nice to have one of these down the street from me! |
#30 (permalink) |
I just called the company. Its 10$ a piece. They need a min order of 40$. So guys, if we can get 4 guys who want them I can place the order. It looks exactly the same as PT's and a 1/4 of the price.
| Thread Tools | |
| Display Modes | |
