Old 11-02-2009, 01:58 AM   #16 (permalink)
MOPARfulSRT4's Avatar
Member Number: 62481
Quote: Originally Posted by need4speed2345 View Post
local car with less than 2k in mods.
YouTube - SPEEDFACTORY 10 SECOND SOHC D16Y8 CIVIC
now its in the 9's with more money in it. He was running a ebay .57 trim on his orginal build and put down over 400whp and peaked at 6xx then disentagrated a piston.
Lol, okay, where does it say he only spent $2,000? Pistons are around $200. And a .57 trim turbo kit is was $1500-$2000 not even including the supporting mods.
A Neon w/ PVO upgrades!
MOPARfulSRT4 is offline   Reply With Quote
Old 11-02-2009, 02:08 AM   #17 (permalink)
Member Number: 36825
3inch ehst/larger fmic.
SRT Jeff is online now   Reply With Quote
Old 11-02-2009, 11:14 AM   #18 (permalink)
sponsorSRT03's Avatar
Member Number: 58797
meth(hold HOM all day), Wideband, Mutual funds, and WGA
sponsorSRT03 is offline   Reply With Quote
Old 11-02-2009, 11:53 AM   #19 (permalink)
Bebo's Avatar
Member Number: 46331
shit for 2k he would be whoopin 99% of the srt's if he worked on a single cam d series VTEC
Quote: Originally Posted by MOPARfulSRT4 View Post
Hmmmm, dunno about that. I doubt a 1. something liter engine could beat 99% of SRT-4s with $2,000. It'll definately need to be rebuilt because I know those econo-engines cannot hold much power. Then it'll need to be boosted then supporting mods need to come into play and that alone is WAY more than $2,000.
Honda parts are petty cheap & if he used one of those e-bay turbos (if it held together) the build could total less than $2k. Fortunatly most Honda owners lack both mechanical ability & common sense or else there would be alot of these cheap rice rockets
Quote: Originally Posted by joe r View Post
bare foot,I race naked.
LOL...
joe r
Quote: Originally Posted by Pablo View Post
Try and post some pics if you can.
Bebo is offline   Reply With Quote
Old 11-02-2009, 06:46 PM   #20 (permalink)
need4speed2345's Avatar
Member Number: 59269
i have talked to them in person. Just cause the NEON cost 12234353231312 dollars for pistons and rods doesnt mean they all do. You get vitara pistons and eagle rods with whole gasket kit for under 500, 600 dollar ebay turbo kit with intercooler, and a zex cam 200 bucks. Tuning is on crome(free) and other little misc crap. Now like they said its not the BEST setup but they are pushing the vitara pistons to break (which after a couple passes at 600whp one did) but at 400whp it was running 10's all day long.
03 SRT4-|Delta 44 Turbo|3 Inch CTI Turbo Back Exhaust|NOS Sniper Kit 50 shot|Coolingmist trunkmount Meth Kit|MBC 24PSI|MPx Front mount|750CC DW|AGP External Wastegate|378/402
93 Civic Hatch-STOCK D16 high boost build in progress
need4speed2345 is offline   Reply With Quote
Old 11-02-2009, 06:50 PM   #21 (permalink)
Member Number: 52407
Quote: Originally Posted by StReeTz166 View Post
The boost is controlled by the toys. Is there a way to crank it up even more manually?
Yes, you'll have to take it off PCM controlled boost.
7055 is online now   Reply With Quote
Old 11-02-2009, 07:22 PM   #22 (permalink)
Duh, I said the pistons ran for $200 I know ppl with Vitara pistons. As far as the whole setup, can't see it costing less than $2000 but whatever. I'm no longer a Civic owner so I don't know what vendors are offering anymore for them.
Old 11-03-2009, 10:16 AM   #23 (permalink)
Whatarush's Avatar
Member Number: 75945
Does it honestly matter? 1 car... This country of millions.
Fix your car and have fun.
All this small stuff
Z
Whatarush is offline   Reply With Quote
Old 11-03-2009, 10:24 PM   #24 (permalink)
StReeTz166's Avatar
Member Number: 72312
Thanks for the reply. To accomplish that would I have to remove the toys? or is there a way to disconnect the PCM controlled boost.
StReeTz166 is offline   Reply With Quote
Old 11-03-2009, 11:00 PM   #25 (permalink)
No not at all. The PCM controls boost by varying the amount of boost pressure that goes to the wastegate actuator. All you have to do is rearrange your vacuum lines so it doesn't have control over that anymore. Then you'd basically just run a line from the turbo straight to the WGA with a manual boost controller inbetween and adjust the boost however you want.
Stage 3 PCM may allow for enough boost for your needs though so you may not want to do it. You can turn the boost up by adjusting the WGA to a limited extent without taking it off PCM control.
The disadvantages are that DAB would become useless and you couldn't limit boost in the lower gears. The PCM also wouldn't be able to adjust to changing temperatures. 25 psi in the cold is way more then 25 psi in the heat. Theoretically you'd get more PTB.
There are threads about rearranging your vacuum lines to take it off PCM control. It is simple. You'll also want a WGA with a higher spring pressure most likely. If you do look into all the options before you buy the most expensive WGA. I run my car like this and I like it better personally but I don't care about most of the things that others value from having PCM controlled boost.
Old 11-04-2009, 09:29 AM   #26 (permalink)
A-Town SRT's Avatar
Member Number: 46710
I have an '04 Stage 3R w/ Toys and am looking to buy some upgrades. I'm somewhat new, so excuse some of the simple questions. I have made a small list of parts that I thought might help add some more performance. Any other suggestions are more than welcome.
-AGP Wastegate Actuator with 19psi springs
-AGP Big Turbo 02 Housing
-AGP Hardpipe Kit
-PTP Mopar Stage 3 SST
-AEM Wideband
-DSP Tune
Also, I believe I have the Mopar Blow-off valve Conversion kit (the plate). What would I need in order to run an aftermarket blow-off valve?
I wouldn't bother with more power mods, unless all your looking for is a highway monster. Work with the power you have. Get more of it to the ground. Upgrade the suspension, wheels/tires. Also a BBK kit would be helpful at this point as well. Do those things and you'll have a good all around car.
A-Town SRT is offline   Reply With Quote
Old 11-04-2009, 03:31 PM   #27 (permalink)
StReeTz166's Avatar
You're right I'm trying to get the power to the ground alittle better. I'm definitely buying a 2-step. I have solid engine and tranny mounts, sway bars, coilovers, strut bars and a bbk. Anything else you'd suggest to help hook up?
Old 11-04-2009, 04:56 PM   #28 (permalink)
A-Town SRT's Avatar
Wider wheels and tires if you don't already have them and a TCS (if its still being sold).
Page generated in 0.18138 seconds with 13 queries
