Old 10-25-2009, 09:47 PM   #1 (permalink)
StReeTz166's Avatar
Member Number: 72312
Default Got some cash to spend, Upgrades?
I have an '04 Stage 3R w/ Toys and am looking to buy some upgrades. I'm somewhat new, so excuse some of the simple questions. I have made a small list of parts that I thought might help add some more performance. Any other suggestions are more than welcome.
-AGP Wastegate Actuator with 19psi springs
-AGP Big Turbo 02 Housing
-AGP Hardpipe Kit
-PTP Mopar Stage 3 SST
-AEM Wideband
-DSP Tune
Also, I believe I have the Mopar Blow-off valve Conversion kit (the plate). What would I need in order to run an aftermarket blow-off valve?
StReeTz166 is offline   Reply With Quote
Old 10-25-2009, 09:53 PM   #2 (permalink)
Member Number: 36585
since a wb is on your list i assume you dont have one, make it your first choice....you cannot use an agp o2 on the stg3r, what exhaust are you using? the bov will not yield performance gains only help with surging. also, no point in looking into a stg3 sst if you havent gotten the full potential outa the stg3 as it sits..turn the boost up, check afr's and go from there.
just-a-neon is offline   Reply With Quote
Old 10-25-2009, 09:58 PM   #3 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
wb and agp wga. later a ptp 47lb wheel
AGP S256 FS
Old 10-26-2009, 06:10 AM   #4 (permalink)
SRT-4runner's Avatar
Member Number: 68134
Trader Rating: (36)
meth!
Vtec Slayer
SRT-4runner is offline   Reply With Quote
Old 10-26-2009, 09:58 AM   #5 (permalink)
Member Number: 52541
Meth, wastage, and wideband and crank up the boost
___________________________
2003 Solar Yellow - DSP, Meth & Boltons
dabezt1 is offline   Reply With Quote
Old 10-26-2009, 12:49 PM   #6 (permalink)
morgantj13's Avatar
Member Number: 47175
coolingmist meth kit!
morgantj13 is online now   Reply With Quote
Old 10-26-2009, 01:18 PM   #7 (permalink)
StReeTz166's Avatar
The boost is controlled by the toys. Is there a way to crank it up even more manually?
Old 10-26-2009, 03:10 PM   #8 (permalink)
marakka's Avatar
Member Number: 33071
Trader Rating: (108)
I've got a sale going on on strut tower bars right now.....
Max
PAYPAL - info@performanceautowerks.com
www.performanceautowerks.com
www.werksracing.net
AEM Factory Authorized EMS Tuner
SCT Factory Authorized Tuner
Diablosport CMR Tuner
marakka is offline   Reply With Quote
Old 10-26-2009, 04:05 PM   #9 (permalink)
StReeTz166's Avatar
I have front and rears. Thanks for the heads-up!
Old 10-26-2009, 04:12 PM   #10 (permalink)
lyncoo's Avatar
Trader Rating: (92)
just tune it
Old 10-26-2009, 09:29 PM   #11 (permalink)
need4speed2345's Avatar
Member Number: 59269
wideband, meth, dsp to tune it for meth= tons of power
03 SRT4-|Delta 44 Turbo|3 Inch CTI Turbo Back Exhaust|NOS Sniper Kit 50 shot|Coolingmist trunkmount Meth Kit|MBC 24PSI|MPx Front mount|750CC DW|AGP External Wastegate|378/402
93 Civic Hatch-STOCK D16 high boost build in progress
need4speed2345 is offline   Reply With Quote
Old 10-27-2009, 11:43 AM   #12 (permalink)
MOPARfulSRT4's Avatar
Member Number: 62481
You need to pour some V-Tak into that bitch!
A Neon w/ PVO upgrades!
MOPARfulSRT4 is offline   Reply With Quote
Old 10-31-2009, 06:45 PM   #13 (permalink)
shit for 2k he would be whoopin 99% of the srt's if he worked on a single cam d series VTEC
Old 11-01-2009, 10:04 PM   #14 (permalink)
Hmmmm, dunno about that. I doubt a 1. something liter engine could beat 99% of SRT-4s with $2,000. It'll definately need to be rebuilt because I know those econo-engines cannot hold much power. Then it'll need to be boosted then supporting mods need to come into play and that alone is WAY more than $2,000.
Old 11-01-2009, 10:17 PM   #15 (permalink)
local car with less than 2k in mods.
YouTube - SPEEDFACTORY 10 SECOND SOHC D16Y8 CIVIC
now its in the 9's with more money in it. He was running a ebay .57 trim on his orginal build and put down over 400whp and peaked at 6xx then disentagrated a piston.
Page generated in 0.16623 seconds with 13 queries
