I just installed my forward motion wastegate actuator and took my car for a test drive tonight and MAN WHAT A DIFFERENCE IT MAKES!! The only thing that seems too good to be true is that my car is spiking at 20 to 22 in third and holding anywhere from 18 to 20. Isn't that a bit too high for a '04 with a stock fuel system at stage 0? I didn't throw any codes that I can think of. How would I know if it did? It didn't backfire either so it doesn't seem to be running too lean. Maybe I should adjust the boost lower. I would like to keep it where it is but I don't want to blow up the motor either since it's my daily driver. What do you guys think?
lower it your running out of fuel the only way to truely know if your safe is with a wideband. I would spike 18psi.
2003 Solar Yellow SRT-4
FFP 47LB Stage 3
Coolingmist Trunkmount Kit with Varicool Controller
MPx 3" Exhaust
AGP Intercooler
AGP CAI
Diablosport Tuner
11.87 - 118.94mph
^^22PSI on HOM (getting kicked out) and no tune
How much part throttle boost do you have? Is it hard to deal with on the street?
It doesn't have any that I am aware of. It's also very streetable but the turbo spools up a lot quicker now. It is a very explosive power but only if you need it. It is hard to adjust right now with the wet pavement where I live. I need a nice dry day to actually see how high I spike and where I am holding at. I turned down the wastegate now so it is spiking around 18 and holding at 15 to 16, which seems to be a good spot to keep it at. I am wondering if I should put the heat shield back on. I decided to leave it off for now because I like the added room in the engine bay.
i would put it back on and take no chances. ive heard to many stories were people melt their reservoirs.thats just imo
Yeah I probably will once I get the wastegate set to where I want it to be. It seems to keep the turbo hotter though. But I guess it saves the reservoir so it's either one thing or another.
FM wga is definately where it's at. i've seen a lot of boost rising solutions and this one takes the cake. there is a bit of ptb, but it's not anyway near as bad as some of the other wga or ebc options. plus you can adjust it w/o taking it off. the heatshield may need to be modded to put back on though. fitment was the only downside of this wga, but it's not that bad at all. if fitment wasn't an issue i'd say it'd be perfect.
That's pretty interesting. Isn't fuel cut at 18 PSI on the stock computer?
There is no fuel cut until you reach redline. However, on stock PCM/ECU if you go over 18.25 psi the computer will pull timing back. Either way it is a loss of power.
Yes the FM WGA is probably the best wastegate actuator out there. I have had mine on since spring and love it. I had the AGP WGA before that and loved that too but wanted something that would spike over 20 psi and hold 20 psi to redline. The highest I could get the AGP to hold was 16-17 if I was lucky. Figured I would take a chance with the FM and if it didn't work I would resell it. I have never looked back since I put the FM WGA on the car. I spike 25 hold 20-22 psi. Love it.
