Summary: New England SRT owners gathered at Trick Engineering Hampstead, New Hampshire on Saturday December 3, 2005. Two SRT4’s were used as test platforms, an 2003 stage 2 car and a stock 2005 stage 0. Data presented was gathered through the output of the engine ECU and captured using an AutoTap scan tool. Data captured by the scan tool was in .CSV format and then imported into Microsoft Excel, extrapulated and saved in .XLS format for publication.
FACTS
Date: December 3, 2005
Time: 8:00 – 3:00 pm
Test Platform: 2003 Stage 2 SRT4
3" o2 housing and 3" side exit no cat
Iridum plugs gapped at .032
AGP WGA set to around 20-21 psi peak
Lorenzo TB 60mm with adapter
Devils Own Water injection (windshield washer fluid) Spraying from 16psi>up
Intercoolers Tested: AGP, CCA, CTI, MOPAR and SPARCO
DYNO: DYNO MAX 2000 “Pro”
Data was captured throughout the power range, 1st gear through 4th gear with peak engine RPM reaching approximately 6000. Adequate time was allowed for the engine to cool down between runs.
CONCLUSIONS
Included are the output graphs showing the results of Air Intake Temperature (Fahrenheit) and Engine Speed (RPM) across the power band. The five intercoolers available for testing were tested on both of the test platforms.
You'll note that the stock MOPAR performs poorly on the modifyied stage 2 car with air intake temp spiking to 93 degrees.
One amomilie I'll make note of is the AGP Race I/C temperature. You'll notice that after each pull the air temperature rises while all of the others drop. I can't explain that. But on the other hand, it does recover and start to drop when the next pull begins.
On a personal note, there are many factors to take into account when selecting and sizing an intercooler for your car. While these results may serve as a guide in your selection, you'll have to be the judge for what's best for your application.
NOTE: See thread FMIC Shootout Efficiency Chart Intake Air Temp/Engine Speedfor a quick view of the results.
2005 Import Wars Slick Class Champ New England Dragway 2006 SRT Nationals Champ Heartland Park Topeka Kansas 2006 Class Winner Englishtown New Jersery 2006 Top Eliminator Englishtown New Jersery
2003 Flame-Red SRT-4 BEST TIME:11.51 Best MPH: 122 Best 60': 1.673 MODS: Darrell Cox Racing Built.
It took awhile but its done. I'm still tweeking it the comments and conclusions. An Admin needs to make this a sticky along with the "FMIC Shootout Efficiency Chart Intake Air Temp/Engine Speed" thread.
niceinfo AGP is the best as of now, i think the new ED should be tested for flow and temps and check diff
--------Dyno#s update 4/01/05--------
stock turbo spike 21 psi and drop to 15 to red line
307 whp/370 wtq
-----------Dont remerber the date --------------
last dyno i will spray on stock turbo
410 whp/435 wtq Now its running harder
---------------Bigger turbo in 24psi--------------
ran like a champ for 2 days then the motor messed up, now debating wa to get any suggestions
you guys are the best thanks so much for doing this.
05 flame red
mods: limo tint AGP CAI,bleeder, Mopar noise maker, Strut tower brace and XM Satelite Radio, thats all right now.
FOR SALE PM ME FOR MORE INFO
hey guys just wondering, how much power will the agp fmic help me, my mods are stage 2 no toys. needs wings dp, intake. and im spiking 20 then 16 at red line,, what should i spark my plugs at
its not going to gain you power but ir will help keep the power over long runs and high temps. If your running the stock fmic on stage 2 your heatsoaking aka reaching your intercoolers threshold to efficiently cool air going into the engine, and a few runs on a hot day will soak a stock fmic rather easily. Looking a your mods i would recommend you look into getting a better than stock FMIC and you will see a difference.
Hey what about i have two intakes. I have a AEM Short RAm and a K&N TYphoon CAI. I think the k&N gets more hp but its illegal in my state, would anybody know if I Put the CARB sticker from the AEM on the K&N and took off K&N stickers?
