flashing check engine light? - Dodge SRT Forum
post #1 of 31 (permalink) Old 05-22-2010, 09:35 PM Thread Starter
HUB SRT's Avatar
Quoted: 3 Post(s)
So I'm driving my car and just finish getting it tuned 3 day ago... have had no issues... drive to my grandmas which is 80 miles one way... when driving back with about 15 miles left my check engine light is flashing... car sounds and acts fine... then goes away... I check it with my dsp, no codes... and comes back on again... I do a scan while its flashing and no codes pop up... so now I'm stumpped... I turned the car off and back on and hasn't done it again...
Also when I turn the key off then on (not running) my engine light comes on... the car chimes, then the engine light blinks 10 times, then remains solid...
Any ideas guys?
HUB SRT is offline
post #2 of 31 (permalink) Old 05-22-2010, 09:38 PM
chicken nugget's Avatar
Quoted: 0 Post(s)
no codes are coming up? sounds odd...
Nicken Chugget.
chicken nugget is offline
post #3 of 31 (permalink) Old 05-22-2010, 09:41 PM Thread Starter
HUB SRT's Avatar
Quoted: 3 Post(s)
I know... didn't do this till I got the tune... think I should contact the person that tuned it? Was done via email with the dsp.
HUB SRT is offline
post #4 of 31 (permalink) Old 05-22-2010, 09:47 PM
Quoted: 0 Post(s)
they may need a code to help you out...try an autozone or something that will check codes for free and see if any pop up for there machine.
Nicken Chugget.
post #5 of 31 (permalink) Old 05-22-2010, 09:51 PM
AngrySrt's Avatar
Quoted: 0 Post(s)
sounds like a misfire? thats what is it when im misfiring
2003 srt-4 stage 0 pcm,ATP 60 trim kit,750s,tial wastegate,agp full race bfmic, agp intake, scan guage, mpx extrude honed mani,mpx 62 mm throttle body, ptp charge pipe,agp up pipe with hks bov, aem wideband, 3 in side exit, ipp coilovers and some sportmaxx wheels, dsp tune and all the help in the world from jon at ptp! great guy!
AngrySrt is offline
post #6 of 31 (permalink) Old 05-23-2010, 05:17 AM Thread Starter
HUB SRT's Avatar
Quoted: 3 Post(s)
Idk... I had a bad injector once and thew the misfire code and it blinked, but the engine light stayed and my dsp picked it up. Also the car ran like shit...but the car runs great... gets up to 12o with no easy... we (and the person tuning my car) were dealing with random misfire when the car did a cold start... but he changed the fuel trims and believe bumped up the idle and that seemed to clear it up... I do have new plugs and wires... I have no clue why it did this and won't do it again.
HUB SRT is offline
post #7 of 31 (permalink) Old 05-23-2010, 08:10 AM
Fresh Meat Moderator
Quoted: 3 Post(s)
Blinking check engine light means cat damage is happening.
You have to have a code. The PCM is not retarded, it stored the code if the CEL is on.
Also it doesnt matter that its on with the key on engine off. Thats normal.
tunerlover3 is offline
post #8 of 31 (permalink) Old 05-23-2010, 08:24 AM
Hotrodblack50's Avatar
Quoted: 0 Post(s)
If you do get a check engine light you can turn the key on and off three time and the code will read where the miles are, will be a P#### code. Then you can look it up online. But a flashing check engine light is a mifire which will ruin you CAT and that cost a lot to replace. Good luck!
Hotrodblack50 is offline
post #9 of 31 (permalink) Old 05-23-2010, 10:21 AM Thread Starter
HUB SRT's Avatar
Quoted: 3 Post(s)
Well don't care if it there is cat damage... I don't have one, but wonder why its doing it now.
HUB SRT is offline
post #10 of 31 (permalink) Old 05-23-2010, 11:37 AM
Quoted: 0 Post(s)
How is your downstream O2 sensor plugged in? Do you have a non-fouler?
tmole57 is offline
post #11 of 31 (permalink) Old 05-23-2010, 11:46 AM
BLKDOUTSRT4's Avatar
Quoted: 0 Post(s)
its not just cat damage...it can cause engine damage too....
Originally Posted by Alpha-Omega View Post
....yeah, I'm gay and staying home this time
BLKDOUTSRT4 is offline
post #12 of 31 (permalink) Old 05-23-2010, 11:48 AM Thread Starter
HUB SRT's Avatar
Quoted: 3 Post(s)
The guy I got the tune from, said he could elimante the cat code I was getting... p0420. And I never got that code again. But if it blink cause it thinks there is something wrong with the cat, I'm not going to worry.
HUB SRT is offline
post #13 of 31 (permalink) Old 05-23-2010, 12:03 PM Thread Starter
HUB SRT's Avatar
Quoted: 3 Post(s)
Well I tried this, and its just reads done and the 5 dashes then goes to my mileage.... but is it possible its just on the fritz due there being no cat and with the tune?
HUB SRT is offline
post #14 of 31 (permalink) Old 05-23-2010, 12:07 PM
Hi N Mity's Avatar
Quoted: 1 Post(s)
blinking CEL is not for cat damage, it means that catistrophic(sp) engine damage can happen and engine should be turned off asap. It could be a simple misfire, excess knock, slipped timing belt......etc. It is wierd that it didnt leave a stored code.
Now, with the engine OFF and key ON, the blinking CEL is only normal if you have recently disconnected the battery or removed the ASD relay. It means that the ECU has not checked all the perameters of the emission control systems. You will not be able to pass inspection if the cel is blinking with the key on/engine off. It can take a few hundred miles to reset the blinking cel. It will start all over again if you disconnect the battery.
Hi N Mity is offline
post #15 of 31 (permalink) Old 05-23-2010, 12:12 PM
prevrexowner's Avatar
Quoted: 0 Post(s)
I'm putting money on the coil pack.
prevrexowner is offline
User Tag List
Linear Mode Linear Mode
