Old 03-05-2006, 09:49 PM   #1 (permalink)
srt4fun80's Avatar
Member Number: 34189
Trader Rating: (102)
Default *****Dyno Numbers and Sheets*****
Trying to get a sticky on this that will be highly moderated so please follow the rules:
This is a section to gather Dyno Numbers, Dyno Sheets and mods done to accomplish your numbers. Please do not ask questions about what people have done, or what their a/f's were or egt's, or anything of the such. You can post this information with your sheet and numbers should you want to. You also don't need sheets to post your numbers, but please no b/s.
The only posts in this thread should contain the above stated. This will be a good place for people to come look what mods have been done to accomplish what numbers and what kindof tuning. Hopefully answering some peoples questions about what mods will get them what. From CAI to Big turbos. So please include your mods with your numbers....Thanks guys, now let's build the list
Here are links to other dyno sheets on the forum:
Other Official Dyno Thread: INFO: Official SRT Dyno Sheet Thread
GT35 Dyno Thread: GT35R Turbo owners? Post ur dyno and setups here .
50 Trim Dyno Thread: 50 Trim Turbo owners? Post ur dyno and setups here .
dynoed car today
Finally Tuned-New Dyno Results!!!!!
after extensive tuning and help from Nivo and Vector, new Dyno#'s!!!
dyno finally
Dyno Numbers From 4-1-06
STG3 Dyno confusion.........
NX-Intercooler sprayer works dyno proven!
Semi-Successful Dyno Run
Dyno results
dyno numbers on the swap
My DYNO Videos
First Time On the Dyno
My first dyno! (S1/Intake/Exhaust/FMIC)
Dyno Day.. results and Question.
weird dyno numbers
went to dyno today.
Another gt 3076 on dyno, Wg re-routed
Update on Hahn 20G dyno #'s
Dyno Numbers
Dyno @Tag Not Sure if i should be happy?
Dyno Results for Lorenzo 60mm TB
New gt-40 dyno numbers....!!!
Stage 2 dyno numbers
dyno the car not sure if i should be happy
Dyno Results
dyno run result (56k beware!)
Dyno Run
Dyno results are in! need help.
***Stg3 Dyno Update*****
latest dyno
New S3R dyno #s.
AGP turbo dyno 382 whp
Hella disapointed with 50 trim dyno!
Dyno Numbers
05 srt-4 dyno results
ummm.....dyno numbers finally!
Dyno Graph... :) 3076R on Pump Gas 21.5psi
New dyno #'s
used my school dyno today
Stage 3r dyno with links
The Dyno numbers are in!!!
My day at the Dyno
Dyno #'s
Got my Dyno #'s in!
Stage 3 dyno
Got a baseline dyno today...
Stage 3 installed *Dyno Inside*
New dyno numbers
500 HP SRT-4 Dyno Run...
My Dyno Numbers
Dyno Graphs Stage 0 and Stage 1-2 in 1st gear
DYNO: dbb 50 trim 507whp/529wtq
Kinetic Motorsport GT3076R Dyno Video
srt4fun80 is offline   Reply With Quote
Old 03-06-2006, 12:05 AM   #2 (permalink)
SRTPWR41's Avatar
Member Number: 27683
Trader Rating: (12)
Well i dynoed at 287 HP with 363 TQ but the owner of the shop said everyone was dynoing about 10-20 HP less,cuz it was a pretty hot day so i would have to say iam at 300,but 287 is what the sheet said
Mods list:
S2 w/toys
Maxxfab 3" Downpipe (no cat)
Mopar cat-back
ported stock turbo (not clipped)
ported stock throttle body
AGP WGA boosting 22-23 PSI w/bleed
Check valve
HKS SSQV w/hardpipe
AEM Short ram intake
Thats pretty much it for power mods,but i also got Avid solid MM and a Catch can thats about 40 HP right there. J/K
"You must show NO MERCY......Nor have any belief what so ever in how others judge you......For your GREATNESS will SILENCE them ALL!!!" -Warrior-
SRTPWR41 is offline   Reply With Quote
Old 03-06-2006, 12:46 AM   #3 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (28)
dyno sheets and mods is what it says. show your sheets
reed32 is offline   Reply With Quote
Old 03-06-2006, 12:58 AM   #4 (permalink)
Member Number: 19544
stock 2004 Drop in filter
uncorrected STD but the temps in the dyno were 60F
2003 Black Cobra Convertible. (DD) 455rwhp/465trq
2004 Silver SRT-4 (sold)
2004 Sonic Blue Lightning Stock, 356hp/426ftlb
Unoid is offline   Reply With Quote
Old 03-06-2006, 06:27 AM   #5 (permalink)
Kason23's Avatar
Member Number: 34502
Trader Rating: (13)
05 with just a spring mod...You can see where he asked me to punch it so early damn spikes
New Set up: AGP 44LB S3D Kit
21/22psi -- 382whp/416wtq
Best ET With SST Set-up
12.6 at 110 with a 2.01 60ft
320whp/360wtq
Old 03-06-2006, 07:22 AM   #6 (permalink)
milkman102299's Avatar
Member Number: 25193
Trader Rating: (15)
dont have sheet but look at mods/numbers in sig
12.72@110 1.92 60' capitol raceway 205/50/17 faulken ziex tires 11-18--6 stock turbo
je 8.5-1 pistons .020 over-eagle H beam rods
agp standard 50 trim @23psi pump 28psi race
Greddy Profec B.-MSD DIS 2-SAFC II
PTP charge pipe
PTP 750cc-exhaust depot cold side pipe w/hks ssq
3inch intake-msd coil-stock CPU
side exit
Boomba Fuel Rail/AGP return line
Walbro 255-Dynotune 75 shot.
DCR powershift 2-balance shafts removed
milkman102299 is offline   Reply With Quote
Old 03-06-2006, 07:34 AM   #7 (permalink)
Member Number: 4101
the spikes were due to car spinning the slicks on the dyno! Click on the link in my sig to see mods.
-navin
Project Rooster ! POWERED BY DCR!
My daily driver
cajodhya is online now   Reply With Quote
Old 03-06-2006, 08:47 AM   #8 (permalink)
Member Number: 2243
Well I can tell you this, if you were spinning on the dyno you would have dips in your graph not spikes.
2002 SS Camaro - 630 rwhp ***SOLD***
New car
2004 Black SRT4 w/50 trim - 382 whp @ 21 psi
necrocannibal is offline   Reply With Quote
Old 03-06-2006, 09:51 AM   #9 (permalink)
SRTPWR41's Avatar
Trader Rating: (12)
yea!!! just like mine , look at the green one you can see a gap where the dyno spun and then it started to read again
Old 03-06-2006, 10:51 AM   #10 (permalink)
Member Number: 3410
MODS:
No intake
Kinetic Motorsport DBB 50 trim with WG dump
HP racing 3" turboback exhaust w/ no cat
Stage 2 PCM (going out)
Stage 2 sensors (going out)
RC 750cc injectors
'03 fuel rail w/ schrader valve
Lujan Motorsports Fuel return
Walbro 255 Fuel Pump
Greddy Emanage
Greddy Profec E01 EBC
Mopar Performance plug wires
NGK 4306 plugs gapped at .32
Quickwhips 4" FMIC
ED hardpipes w/ greddy type-s BOV
plus other non performance mods (STS, motormounts, etc..)
Boost set at 22psi, fuel pressure set at 43psi base
Stage 2 PCM was pulling a lot of timing. I'll be going back to stage 0 and i should see a 20-30whp gain.
I have a race ported TB, Spacer and Intake Mani from fullyBuilt on the way as well.
YES, that's my stock clutch slipping on the dyno
Pic of the motor w/o inj cover.
Got PSI is offline   Reply With Quote
Old 03-08-2006, 08:01 PM   #11 (permalink)
Vector's Avatar
Member Number: 4644
Trader Rating: (24)
Quote: Originally Posted by Got PSI
MODS:
No intake
RC 750cc injectors
Greddy Emanage
Quickwhips 4" FMIC
got clutch
Vector is offline   Reply With Quote
Old 03-08-2006, 09:03 PM   #12 (permalink)
r.j-lo's Avatar
Member Number: 4599
507whp/529wtq
mods in signature.
ill get the graph up
r.j-lo is offline   Reply With Quote
Old 03-08-2006, 11:47 PM   #13 (permalink)
cybr's Avatar
Member Number: 31841
Trader Rating: (34)
Sponsored By: ClutchMasters, SnowPerformance, MadDog, 475hp, 468ftlb, 24psi on SAFC/Profec.
Now on the SCT - Waiting to Dyno with RaceGas + 25psi
http://myspace.com/cybr
cybr is offline   Reply With Quote
Old 03-17-2006, 10:46 AM   #14 (permalink)
DaZone's Avatar
Member Number: 1799
S3 no toys
cca fmic
agp cai
Iceman tb
CTI turboback with cat
Mods: S3w/toybox,CTI turboback,Iceman TB,AGP CAI,CCA Fmic, Mopar wires w/NGK Plugs. Turbonetics w/greddy type s bov. also: B&G Lowering Springs, Front&Rear Strut tower bar, Rex motor mount inserts, Progress Rear sway bar. AGP S3 Wg.
18" Exel Chromes w/toyo proxes 4
17" Nexo PX-5 w/ toyo proxes 4
Dynoed with HOM : 358hp and 359tq
DaZone is offline   Reply With Quote
Old 03-17-2006, 11:13 AM   #15 (permalink)
SRTforums Nazi Admin
NIVO88T's Avatar
Member Number: 1109
Default Srtgurl - 2003 Srt-4
ATP GT3071R Kit
Emanage/E01
750 RC injectors
CTI Turbo back - no cat
CTI FMIC
CTI CAI
Nivos return system
26psi
Stock motor
LFS 60mm TB
13lb spring in Tial WG
Externally dumped
SRTGURL's SRT-4 SIte:
www.srtgurl.com
