#1 (permalink) |
![]() Join Date: Mar 2004
Member Number: 8662
The Before Runs are 001(Stock Fuel Pump) and 002(255LPH Stock Wires), the after run is 004(255 Rewired). The only change made was the rewire, all runs performed on the same day.
Lambda first: ![]() Now power, Same runs. ![]() Please keep in mind, I did NOT change any boost or timing settings, this is pure apples to apples. Thought this might be helpful for those guys that want to KNOW what the rewire will do for you. N-Joy Oh yeah, here she is on E85 with the stocker on DIEFUCKER! (27.3 PSI) ![]() NachO
VOTE FOR ME! AUG 2010 SRT of the Month!
http://www.srtforums.com/forums/f389...thread-576826/ DD -09 STi | Track Car. 2004 E-blue; Mods and pics: CLICK S259@ 25psi:614/567 -6/10, E85 - Meanblueberry. ![]() Last edited by NachO_SRT; 06-03-2009 at 12:09 AM. |
| Sponsored Links | |
Advertisement |
#4 (permalink) |
![]() Join Date: May 2009
Member Number: 72878
Now where's the run with the AFR corrected?
![]() We want to see the gains, heh.
__________________________________________
: 1965 Chevelle SS with 502 So I'm good with wrenches an NA, but learnin' all this electronic stuff... so give me a break and not bust my balls too much at first! ![]() 2003 Black SRT-4 with <25k miles... No mods as of yet. |
#5 (permalink) |
Member Number: 8662
![]() We want to see the gains, heh. I have those results: ![]() This was Runfile 011 - 7 runs after the baseline 004 run posted earlier in this thread. NachO
http://www.srtforums.com/forums/f389...thread-576826/ DD -09 STi | Track Car. 2004 E-blue; Mods and pics: CLICK S259@ 25psi:614/567 -6/10, E85 - Meanblueberry. ![]() |
#6 (permalink) |
Wow, I laid those over each other, and that's some impressive gains. From 10-60hp in the 2.3k -5k rpm range.
#8 (permalink) |
![]() Join Date: Aug 2006
Member Number: 45182
NachO Did you happen to record the boost readings from each run?
This path assumes they knew what they were doing, which isn't necessarily the case"..........RB Racing Duster360 tunes through TDS,,pm turbo666 for details. FREE TUNE checking!! |
#9 (permalink) |
Member Number: 8662
I have those, however they are in my data log archive, I'll have to dig them up, my upkeep and naming convention SUCK. sorry. I'll see if I cant find the log. NachO
#10 (permalink) |
I'll see if I cant find the log. NachO The AEM log files will work
#11 (permalink) |
Member Number: 8662
I was impressed to say the least. I've got a dead nuts Tuner, he's used to EVO's and Supra's, and is try'n to get me to bite on a PRO-efi PRO-128 set-up. I'm tempted. I dunno if anyone noticed, but the E-85 graph is "smoothing 0" Tell me thats not DEAD nuts tuned. You should drive it, I just got back from Heartland Park for a Touring Club day and it F'n ruled. Topping 4th on the front strip was insane. I turned -6, -8, and -10 second laps today over my old best lap. (shhh we're not supposed to be timing on touring club days) It's on point. for sure. I've got a few more of these Dyno graph info threads to post up as I organize them. NachO
#12 (permalink) |
![]() Join Date: Jan 2009
Member Number: 70589
That didn't really prove that lower Hp with 255 needs a rewire, The walbro flows about 40% more fuel with the power that it is given over stock. You run more fuel into the engine change the boost and you make more power adj the fuel to around 12 a/f and your max ing out the engine. I have only a few mods larger 62 trottle body,680 injectors adding a 255 would give me 40% more fuel over stock without a rewire with a rewire the walbro would flow maybe another 15%-I doubt i need that much fuel ,so it just isn't needed. Add bigger injectors like a 750 would be a different story-the extra fuel might be needed,might not either. I noticed a very good mod might be the s3 reg/filter. I will end up doing a rewire,but right now the car isn't getting enogh fuel at even idle, so i am putting in a New reg/filter and 255 on wedsday that should solve the fuel problem I have now, I hope, but maybe its really the reg/filter thats the problem not the fuel pump at all -even the stock on could be enogh. But your info does make it into the fact file because you have some facts in ther-not enogh though-you put the walbro in without testing it by its self with out a rewire!
#13 (permalink) |
![]() Join Date: Dec 2007
Member Number: 60369
![]() 255 was run without the rewire
04 Eblue - stocker cept DSP and BFMIC
#14 (permalink) |
![]() Join Date: Feb 2009
Member Number: 71108
![]() The only thing i have learned from your thread and this one is that the rewire gives you more fuel with the 255, is more efficient, and your car is less likely to catch on fire. If i use this fuel pump i will for certian upgrade the wireing. Thank you for helping me make a wise decision.
www.neSRToc.org
NewEngland SRT Owners Club |
#15 (permalink) |
I talked to Carl a Walbro engieer at 987-673-7727-because those graphs don't really say much except the walbro was running with a little more power sure it's going to pump a bit more unused gas-he said the pump works on as little as 9v-14volts and at 10.5v the walbro is putting out enogh gas for a 375HP car. the stock wiring according to duster 360 puts out 12.5v enogh for a 450HP engine at idle and almost 13v at 5000rpm-enogh for a 485HP engine. Now you only need less than 10v to run that 290HP engine fuLL of fuel with the stock wiring-the rewire is not needed at all in his car no matter how much you think it does!
| Thread Tools | |
| Display Modes | |
