Old 01-21-2007, 07:43 PM   #1 (permalink)
Dusty's Avatar
Member Number: 32662
Default Differnce with a 50trim kit & hahn 20g
Looks like these two turbos are making about the same power (50 trim a little more), just woundering why the hahn 20G is cheaper in price?
s20g -> portfuel -> full supporting mods
Dusty is offline   Reply With Quote
Old 01-21-2007, 07:55 PM   #2 (permalink)
FSRbikr98's Avatar
Member Number: 22973
i believe its because the 20 g is a less expensive turbo, and if i remember correctly it is internally gated.
2004 Flame Red SRT-4
Mods:
Magnacore 7.5 MM plug wires - R.I.P.P. Mods Check Valve - AGP Dogbone motor mounts - AGP Transmission Mount - PT Performance wastegate - PTP 3inch Downpipe - Hallman Professional MBC - Exhaust Depot Hot side pipe - JMB UPP with HKS - CoolingMist Methanol/Water kit - SAFC II and tach driver - Hotchkis Springs - NGK AFX Wideband - 274hp/315tq @ 18psi
FSRbikr98 is offline   Reply With Quote
Old 01-21-2007, 08:03 PM   #3 (permalink)
Dusty's Avatar
That was an easy answer, I just cant decide the way to go 50trim or 20g
Old 01-21-2007, 08:13 PM   #4 (permalink)
jts323's Avatar
Member Number: 30793
go with a dbb from agp and you will never look back plus make more power then the 20g
ACR=A-lways C-rushin' R-ustangs
best mod in the car "driver" lol
canon 50d,50mm 1.8,17-40L,28-135is
jts323 is offline   Reply With Quote
Old 01-22-2007, 07:48 PM   #5 (permalink)
FSRbikr98's Avatar
i agree with the above poster, in engine/turbo/ignition section srt4btu i believe his sn is just maxed his 20g out at the ragged edge and got 425. A dbb 50 trim could do that barely breaking a sweat.
Mods:
Old 01-23-2007, 12:49 AM   #6 (permalink)
irishred's Avatar
Member Number: 35996
i was goin to go 20g but after researching i couldnt find many if any over 400hp (what i wanted at least) so i went 50 trim and i couldnt be happier!! (well maybe if i had DBB 50 trim) i might upgrade to that
irishred is offline   Reply With Quote
Old 03-04-2007, 09:52 PM   #7 (permalink)
bnice01's Avatar
Member Number: 34888
20g will flow 46lbs/min
50 trim will flow 49lbs/min
since we a short revved try to get a turbo that will take advantage of our powerband. this is another reason why dbb 50trims and gt series make more power and have a stronger powerband.
Garage
Self Tuner
Est. HP 400+
bnice01 is offline   Reply With Quote
Old 03-04-2007, 10:59 PM   #8 (permalink)
Silverbullet99's Avatar
Member Number: 36487
unless you plan on building your motor get the hahns 20g. You get great power and you dnt have to worry about getting into trouble with your engine falling apart.
400 WHP or bust
Silverbullet99 is offline   Reply With Quote
Old 03-04-2007, 11:04 PM   #9 (permalink)
Dusty's Avatar
I know that the hahn turbos are both oil and water cooled, not sure if the 50trims are?
Old 03-04-2007, 11:36 PM   #10 (permalink)
Member Number: 31840
standard 50 trims are oil cooled and all GT series and DBB 50 trims are water and oil cooled.
david2345 is offline   Reply With Quote
Old 03-05-2007, 12:04 AM   #11 (permalink)
Nasty_NAS's Avatar
Member Number: 11197
this statement is dumb don't listen to this.. look if you want more power go with the 50.. true if you want to max out the 50 you need a bottom end but if ever want to you don't have to buy a new turbo. the hahn is great too but it is all on you
Agp dbb 50, Agp race fmic, Agp lhp, Dtec,
rc 750s, Crane fire wires, screamin demon coil,
jmb uhp & 3" cai, Tial bov, Twm sts w/stainless knob, DC strut tower bar, Injen turboback
Lca Bushings w/ Rage Delrine, Cooling Mist stage 2
Inovative wideband w/xd-16 guage, Greddy TT
Stewart Warner guages (Boost, EGT & Oil Pressure)
Blue guages w/red line, Megan coilovers, Dcr Bottom end, dcr head comming soon
Nasty_NAS is offline   Reply With Quote
Old 03-05-2007, 09:55 AM   #12 (permalink)
bnice01's Avatar
I have the 20g and its not to bad. like nasty nas said it all on you. I mean there are many 300hp srt's in the 11's. I know I am @ least close to 400 or a tab bit over. Another thing that plays a big factor is the tune. There are some 50trims out there that only put down little over 400 @ 25 lbs. There are some 20g's @ the same boost right there behind them or above. Do the research and determine what you want.
My opinion if I had the money @ the time when i bought the 20g I would went dbb 50trim or gt-3076r FTW
Garage
Self Tuner
Est. HP 400+
Old 03-05-2007, 10:03 AM   #13 (permalink)
sundstrum's Avatar
Member Number: 48899
im gunna go with the gt3076r
sundstrum is offline   Reply With Quote
Old 03-05-2007, 03:24 PM   #14 (permalink)
Scammer
onthedwnlow's Avatar
Member Number: 27125
the 20g is a older model less effective 50 trim
the highest power 20g barely made over 400 and most 50 trims will make 400 on pump gas
the 20g spools slower
the 20g will still use factory intakes
the 50 trim will need a clutch, 20g you could leave the boost alittle lower and keep the clutch
all personal wants
onthedwnlow is offline   Reply With Quote
Old 03-05-2007, 05:16 PM   #15 (permalink)
bnice01's Avatar
all personal wants
-20g will slip your stock clutch trust me @ 17lbs with a nice tune (Hell I seen stock turbo slip clutches)
-20g has made close to 440
-show me a 450+ dyno of a 50trim on pump gas with stock bottom end??
-funny I can reach full boost @ 3300-3500 with my ebc with little to no surge
again how much power do you kids need. look @ my sign that was on 21-22 lbs on 205 street tires. trap speed is good enough for 11's on day. Now I will take off 3-5 mph for dr's or slicks. speed still enough for 11's. now I am @ 25ish spinning to the top of third. Here is a vid to prove it:
http://videos.streetfire.net/video/0...ca0175b549.htm
for the price IMO best bang for the buck. the only reason why I got the 20g is to be different everybody and there mom has a 50trim maybe there little brother too
no hard feelings and I hope no one takes this to heart
Garage
Self Tuner
Est. HP 400+
