#31 (permalink) |
![]() Join Date: Mar 2005
Member Number: 25570
I thought you weren't suppose to run above 20 psi on pump gas with the Delta 40. I think Jon from AGP told me that. Did he tell me wrong?
I'm running mine off of a stage 3 pcm which runs a little less timing. I get zero knock at 24-25 psi, and a/f is in the mid to high 10's so it's all good on my setup.
AGP S3D /40 lb. wheel- Mopar Stage 3 W/Toys- Maxxfab 3" TBE w/out cat- Mopar STS- Exhaust Depot ic pipes w/ HKS ssq bov- AGP CAI - MSD wires-AGP Dogbone MM- PTP Check Valve- PTP 55mm TB- AGP Race fmic- MPX Crashbar- Megan Racing CO's- Hotchkis Swaybars- ACT Clutch/Flywheel
| Sponsored Links | |
Advertisement |
#32 (permalink) |
![]() Join Date: Feb 2007
Member Number: 50755
Just get the 44, you won't regret it. From what i understood, the 48 will make about 15-20 more hp maxed out, but spools later than the 44. I'm pretty satisfied with what the 44 can do. I dynoed 340whp at 19psi, and 392whp, 419 torque at 23 spiking 24psi. When you're ready to buy, talk to jon about it, i'm sure he will give you the information needed to make your decision..
Hope you don't mind that i posted your vid |
#33 (permalink) |
![]() Join Date: Sep 2007
Member Number: 57700
Not at all ![]() your numbers sound exactly what i want. Did you get the whole s3 kit from agp plug and play? I dont know who jon is.
I got the complete kit that comes with the fuel setup (injectors, fuel pump, sct, etc.)
#36 (permalink) |
![]() Join Date: Jun 2008
Member Number: 64853
what about it? This thread is about the delta 44 we are not talking about the 3076. thanks
SRT-4, A Girlfriends Worst Enemy ![]() AEM sri,AEM wideband,AEM tru boost,QTP electronic cutout,Boomba engine mounts and tranny mount,ARP headstuds,AGP wga,BOV,Gates performance timing belt, engine rebuilt at 46k,17psi,AGP stage 3 or 4 coming soon |
#37 (permalink) |
what do you guys think about having a scan guage for this set up?
#38 (permalink) |
![]() Join Date: Oct 2005
Member Number: 34502
me personally seen no need I just datalog once a week or so.. things are usually always the same imo. But a scan gauge is nice to have to look at right then!
2005 red srt
Old setup AGP D46 432/425 on 25psi with meth New ride in the works |
#39 (permalink) |
yeah i may just get one just in case and that way like you said i know whats going on at all times
#40 (permalink) |
![]() Join Date: Mar 2007
Member Number: 52222
I'm also interested in this setup, but I have a couple questions.
I have a stage 0 pcm, so will I get overboost codes for going over 17psi? A Diablosport or Sct tune would take care of that wouldn't it? I have a Apexi SAFC, and not a dsp, should I ditch the SAFC and buy a dsp? Could you use Stage 2 injectors with this turbo set up if I don't have a return line, at lower psi like 19-21 psi? I'm just trying to be cheap. I will get dc 750s eventually, if I do get this turbo. |
#41 (permalink) |
I dont think the s2's would be enough for that boost level, if you want to keep it cheap, pick up a ptp fpr mod. You can use the safc until you get something better. You will need it to clamp the map signal if you want to run over 17psi on the stock pcm.
Where in az are you located?
AGP Delta 46, Ported intake manifold DCR 55mm tb, ptp 3" downpipe, custom 3" dump exhaust, fuel pump rewire, 255 fuel pump, DW 750cc injectors, Dtec, BC stage 3 cams, DCR oil mod, fidanza gears, aem cai. agp solid mounts, agp race fmic, ultimate racing uhp, 2.5" cti charge pipe, Hks ssqv, aem wideband, aeroforce scangauge. defi egt gauge, 180 deg thermostat, fan mod, Hotchkis springs, Koni yellow's, Prothane Lca's.
#42 (permalink) |
I think the safest way to go would be just to get the 750's. You can max out the turbo with 750's right?
I have been planning on getting rid of my SAFC for a while now. I think the dsp or sct would be alot better, and easier. I wouldn't even have the safc if it wasn't just given to me. I understand I will need it though until I get something else, cause I do want to run about 22psi. With a meth kit, what is the max psi this turbo with supporting mods can push out? I'm just curious. My goal is between 350-400 whp. I think 375 is a good number. I don't really want to get over 400, cause I don't want to worry a whole lot about engine internals. I live in Globe. You know where that is? |
#43 (permalink) |
Globe is north right?
You can max the 44 with 750's. probably wont make 400 without race gas. I would say 350- 370 with a good tune. If you can, dump the safc and get a dsp, or the sct with one of agp's tunes.
#45 (permalink) |
![]() Join Date: Nov 2008
Member Number: 68733
I just had my Delta 40 on the Dyno for the second time today. At 20 lbs of boost I got 325 HP and 339 tq. At 18 lbs I got 3o5 HP. It feel really strong!
| Thread Tools | |
| Display Modes | |
