| Sponsored Links | |||
Advertisement | |||
#35 (permalink) |
![]() Join Date: Apr 2008
Member Number: 63272
2004 Black SRT-4-
Mopar Stage 3 with the works 2003 Silver SRT-4- BW s200sx-rs-56 .63ar ![]() 1997 Black 1G, 2.4 built and turboed-project ![]() Any1 local in need of PCM flash...hit me up |
#36 (permalink) |
![]() Join Date: Dec 2008
Member Number: 69549
That is what I am thinking. Not sure if the front seal is a dry install or needs lube. I know that the rear main is dry and goes flush with the block. I may check the good book and see what it calls for.
Wouldn't surprise me if it wasn't installed correctly... I know that the cam seals can throw people off if they aren't familiar with the specific platform. Last edited by atroph; 02-25-2013 at 10:37 PM. |
#37 (permalink) |
2004 Black SRT-4-
#38 (permalink) |
![]() Join Date: Jun 2009
Member Number: 73293
I had my engine rebuilt due to rod knock. The shop (which I've used many times before), found a good but used crank. They measured it's play within spec (.007something). It still pushed the main crank seal out. My ACT xtreme 6 puck clutch may or may not have played a role. But who knows. I ran the clutch for 15,000+ on the previous crank with zero issues.
Basically, even if the crank falls within spec, if it has measurement numbers on the high end, it may still walk with the right clutch, IMO. |
#39 (permalink) |
![]() Join Date: Sep 2003
Member Number: 3797
Wow. Never thought of the heavy clutch as a crankwalk causer, but I guess it makes sense. I think this is my first SRT-4 crankwalk thread that I have seen though.
2003 SRT-4 Silver, AGP GT3076R on E85 DD!
Was 478hp/508tq ----> Now ??? 2002 Camaro SS M6, going N/A... |
#40 (permalink) |
Member Number: 92234
my buddies 6 bolt dsm did this but i thought when you made this thread it was a joke, iv never heard of anything like this iv got a buddy that works at our local dodge dealership (mechanic) and he said he has never heard of an srt4 doing this either
04 Eblue SRT-4: full bolt on's, dsp tuned, ported stocker
#42 (permalink) |
![]() Join Date: Jan 2004
Member Number: 7373
Ditto here. Keep us posted OP; sorry to hear your pain and struggles. There will be a light at the end of this tunnel; it's just to early to tell what it will be.
![]() "This car is 100% sh*ts and giggles." "Speed has never killed anyone. Suddenly becoming stationary... that's what gets you." Jeremy Clarkson SRT-4 to SRT8, SRT-4 Production Epitaph, Canadian SRT-4 Registry |
#44 (permalink) |
![]() Join Date: Dec 2006
Member Number: 48761
I had a motor built that walked with 1000 miles on it. Im not sure of the differences but I know there are 2 diff thrust bearings for this motor. one is supposed to be slightly different and thats important for the machine shop to know when doing a rebuild. Idk what the shop did with my engine but the entire rta and bearing set was new.
#45 (permalink) |
![]() Join Date: Feb 2012
Member Number: 88194
i picked my car up from the dealership and took it to slowmotion motorsports because ive had it there before when i first got it last year and had them just do a general look, comp. test, and what not and everything came out okay. i havent had a chance to talk with drew yet but he left me a voicemail while i was at work and said i have a 35% leakdown in cylinder 1 and that my rings are fried but like i said i havent got the chance to find out how he did the test and if he checked compression first. i still have the paper from the last time they checked it and it was 150 149 150 150. and my car does blow a little smoke but its black and only when i shift, but my car does run on the rich side. ill have more information tomorrow after work. he quoted me like somethin stupid 6 or 7 k on a built bottom end which is dumb he metioned doing the clutch and flywheel and timing kit which ive already done but i guess i didnt make that clear to him. either way if i have to rebuild the bottom end im going to go with the mpx rebuild kit and take it to fowler engine to have them machine and assemble it and ill just take the block in and out myself...
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
