CRANKWALK! and the end of srt days for me - Page 2 - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 02-22-2013, 04:24 PM   #16 (permalink)
badboydneon's Avatar
Member Number: 63272
Default CRANKWALK! and the end of srt days for me
That's the link I posted in post 6. That was the star online case posted in the thread.
Sent from
2004 Black SRT-4-
Mopar Stage 3 with the works
2003 Silver SRT-4-
BW s200sx-rs-56 .63ar
1997 Black 1G, 2.4 built and turboed-project
Any1 local in need of PCM flash...hit me up
badboydneon is online now   Reply With Quote
Old 02-22-2013, 04:25 PM   #17 (permalink)
Member Number: 88194
Quote: Originally Posted by RedlineRacer4 View Post
this is correct, i work at a dealership and just looked at chrysler star cases and thats exactly it. more common on n/a car's. there hasn't been enough turbo cars with this issue to have a star case written about it.
well what dealership you work at bc the one by me told me to piss off and so did Chryslers SRT customer service dept.
SOMEONE THROW ME A FUCKIN BONE HERE IM DIEING WITHOUT MY CAR
william2005 is offline   Reply With Quote
Old 02-22-2013, 04:25 PM   #18 (permalink)
ToyoTech8811's Avatar
Member Number: 90013
I had this issue as well, i had a HUGE oil leak on the pass side. Looked like a river under there every couple hundred miles. When i was doing my T-Belt, pump cam and crank seals, the crank seal was at a 45 degree angle not sitting flush in the seat. But, before i press off the sprocket, i used a dial indicator on the sprocket, then depressed the clutch several times to see if there was alot of movement in the crank sprocket. It was in spec,i think .200 thousands of an inch just real small. But, if you have excessive crank walk, you need a set of thrust bearings i believe.
ToyoTech8811 is online now   Reply With Quote
Old 02-22-2013, 04:27 PM   #19 (permalink)
Fresh Meat Moderator
tunerlover3's Avatar
Member Number: 76568
Quote: Originally Posted by william2005 View Post
my only issue is i was told the srt tech pulled the head and then could tell i had too much play which i dont fully understand how that he could tell unless he unbolted the oil pan so he could see the crank. i feel like all he saw were my pistons in the cylinders and how he came to the conclusion that i needed a new short block still confuses me. and for some reason i wasnt able to talk to him over the phone just the lady at the service desk. she just kept telling me he was in the back working. i could of went and talked to him in person today but i got off work after they close and he wont be back till monday.
Tell them to pull the oil pan and ACTUAL check the play in the crankshaft.
Diablo CMR tuner ~Dan~
310HP 436TQ
2004 Eblue Neon SRT4: E85 5558 Built motor
XXXHP XXXTQ
Old 02-22-2013, 04:29 PM   #20 (permalink)
they said they wont fix it because of the camsafts and because im the 2nd owner and it could have been raced..lol
SRT= Street & Racing Technology no?
Old 02-22-2013, 04:34 PM   #21 (permalink)
Member Number: 82114
Quote: Originally Posted by badboydneon View Post
If your seal popped out, it'd be dripping oil onto the ground pretty quick. Are u having that issue?
Sent from
No, I just have some down the side, I assumed it was coming from the Valve Cover gasket. I have a new one waiting to go in. The car seems to be about a half to a full quart low at oil change though which I do every 3k miles with full synthetic.
n_charpy89 is online now   Reply With Quote
Old 02-22-2013, 04:36 PM   #22 (permalink)
Why the hell did he pull the head and not actually check end play down below. And it seems u didn't have this issue until it was worked on.
Sent from
2004 Black SRT-4-
2003 Silver SRT-4-
Old 02-22-2013, 04:37 PM   #23 (permalink)
_Nick_'s Avatar
Member Number: 8941
I say you fix it. Rebuild it and learn in the process. Might cost a grand or so.
20G Stage 3 on E85: New data:384 hp 411 tq
"Maybe I should just stick to bolt-ons." -Hitler
I don't really want to wrench anymore. I'd rather detail.
_Nick_ is offline   Reply With Quote
Old 02-22-2013, 04:38 PM   #24 (permalink)
So your mechanic can tell you have BC stage 2's but then he is also trying to measure crankshaft play with the oil pan still on?
Sounds like they are just blowing smoke up your ass.
310HP 436TQ
XXXHP XXXTQ
Old 02-22-2013, 04:40 PM   #25 (permalink)
Member Number: 89777
op that same thing happened to mine. i got mine with like 35-40k on it and around 55k i had noticed i was using oil like crazy. i went ahead and had a rebuild kit put in simply because i had enough money to do so at the time. well it kept happening. took it to a dodge dealership and had them put a rebuild kit in because the only thing that they could come up with is that the shop that put the first rebuild kit in did it wrong. well about 400 miles later i had a knocking. spun a bearing. i ended up buying a wrecked srt for the motor and having it put in. the ppl at the dodge dealership said they had complaints about the 2.4 having problems but not enough to have a recall or anything where you would get reimbursed.
blacksrt2010 is offline   Reply With Quote
Old 02-22-2013, 06:36 PM   #26 (permalink)
Sota's Avatar
Member Number: 31159
my bullshit-o-meter pegged from reading this thread.
LIFETIME NRA MEMBER
SUPPORT THE SECOND AMMENDMENT IN ITS FULLEST
I'll be out most of the year it looks like. call it a "building" year. those who need me know where and how to find me.
Sota is offline   Reply With Quote
Old 02-22-2013, 07:01 PM   #27 (permalink)
IEATVTEC's Avatar
Member Number: 1713
Noob alert...
So is the seal visible as the car sits? And if one wanted to drop the oil pan to look at the bottom end, is it really that easy? Drain oil and remove pan?
IEATVTEC is offline   Reply With Quote
Old 02-22-2013, 07:16 PM   #28 (permalink)
Quote: Originally Posted by IEATVTEC View Post
Noob alert...
Nah man, the front crank seal is behind the timing cover, and behind the crank sprocket. Only way to look at it is to remove the motor mount bracket, all engine mounts and remove upper and lower timing covers. Then, press the crank sprocket off with the miller special tools. Oil pan? It really isnt that bad to do, remove the hot side charge pipe, then the oil cooler. All the bolts are accessible when those parts are removed.
Old 02-22-2013, 08:01 PM   #29 (permalink)
blackbird_R/T's Avatar
Member Number: 5369
The problem addressed in the technical service bulletin (TSB) wasn't very common and most of the engines affected made it into the PT Cruiser. I've heard of a few SRT-4 owners over the years having a problem with the thrust bearing but it is unlikely related to the bearing issue the TSB covers. So what happened to your car? It's hard to tell without disassembly.
If you're not the original owner, do you have oil change records proving it was maintained according to service specs? Do you always sit with the clutch depressed to the floor at all stoplights instead of putting it in neutral? What oil are you using? Are there any oiling issues? Was a bearing defective? Have you been running an aftermarket clutch with a higher clamping force pressure plate?
Since the 7/70 powertrain warranty was dropped for model year 2005 I'm guessing you have some type of service contract. You'll need to read the fine print and if that dealer is giving you a difficult time you might have to try another. And if they get into the engine and find something isn't covered there's the risk you will be on the hook to pay disassembly and diagnostic fees. Sucks but that's how they work and a dealer tech isn't going to do work and possibly not get paid, which may be why they are saying what they are and don't want to go into the engine.
You're really going to have to go into the pan and do some disassembly to find out what went wrong and if the bed plate (girdle) is pulled you're already well into the engine. If you're curious how to test for play it should be covered in the factory service manual you can download from the sticky thread at the top of the "how to" section here on the forums. If for some reason the bearing is shot and other internals are damaged you have a lot of choices but the dealership will likely be the most expensive. If you can't do the work yourself and independent shop may be much more reasonable and you have a number of chocies ranging from a new factory shortblock from Mopar for ~$1800 (with a decent discount), rebuilding your current engine, or finding a lower mileage engine from something like a turbo PT Cruiser.
Eric H. ---->- ----- '04 Neon SRT-4 (eBlue/S2)
'92 Dodge Daytona IROC R/T --- -- '91 Dodge Spirit R/T
plus a couple other turbo Dodges, a Cobalt, a few Focus, and some other stuff...
Old 02-23-2013, 07:52 PM   #30 (permalink)
thanks all i wont know anything till tomorrow after work ill keep you posted
