Clogged catalytic converter? - Dodge SRT Forum
 2Likes
  • 1 Post By fixit
  • 1 Post By blackbird_R/T
post #1 of 4 (permalink) Old 12-25-2016, 08:37 PM Thread Starter
ralf's Avatar
Quoted: 5 Post(s)
Garage
Today I removed my downpipe because Iīm experiencing a lack of acceleration, overboost problems and strange behavior in my car (see here), it has a Thermal R&D 3 inch exhaust with cat and 3 inch o2 housing.
I just noticed the stainless steel around the catalytic converter turned to color blue and reddish. To me it looks like this area is overheating but I want your opinions.
Shoud I gut this downpipe? I still need to pass the visual inspection.
Ralf
Dodge SRT-4 2004 Stage 3R Electric Blue
BMW 330i 2002
ralf is offline
post #2 of 4 (permalink) Old 12-26-2016, 04:42 AM
Quoted: 152 Post(s)
looks like a normal cat to me, they get hot..
post pictures looking at the ceramic internals..it should look clean with "white powder" not clumpy like lava
HybridKid likes this.
405hp, 450tq
http://www.srtforums.com/forums/f451...w-123k-612933/
PCM=S0, DSP rescaled, 3bar map/tip
injectors= Siemens 80# (ebay $200)
built motor, 8.8:1 weisco, eagle-h, strap & windage
S3R DCR manifold ($500) w/evo8 turbo (ebay $150) - 20G/47# ebay ($200)
Evo 8 WGA
24x12x4 w/cast ends - CXRacing (ebay $200)
DataLogger DataQA, $25
Wideband UEGO (ebay $150)
vette rims 275/40/17
needswing v5
SouthBend S3
fixit is offline
post #3 of 4 (permalink) Old 01-02-2017, 01:34 PM Thread Starter
ralf's Avatar
Quoted: 5 Post(s)
Garage
It was white and didnīt looked clogged but I didnīt like the color and I gutted it anyways.
My studdering problem is solved and the cat was not the cause of the problem (sparkplugs and wires) but at least I have better acceleration now
Ralf
BMW 330i 2002
ralf is offline
post #4 of 4 (permalink) Old 01-02-2017, 08:26 PM
blackbird_R/T's Avatar
Quoted: 88 Post(s)
For future references if someone is looking, that bluing is normal for the stainless material. The SRT-4 runs pretty high exhaust temps (up to 1720°F pre-turbine) and run rich at wide-open throttle to aid exhaust cooling but that can temporarily increase catalyst temps. The common three-way catalytic converters on gasoline powered vehicles require around an 800°F internal operating temp.
Had you wanted to test it, you would have needed to do a pressure check with it on the car. Testing can be done by temporarily removing the upstream and downstream O2 sensors, install an adapter fitting and length of copper tubing (to provide cooling) and an accurate low-pressure range gauge on the end of the copper tubing. If you have a DRB-III or newer scan tool Chrysler's official test involves installing a pressure sensor in place of the upstream (pre cat) O2 sensor and idling the car at 2k rpms. The back pressure should be no more than 3.45 Kpa (0.5 psi).
Eric H. - '04 Neon SRT-4 (eBlue/S2) - '04 SRT-4 (blk/stock & now sold)
'92 Dodge Daytona IROC R/T --- -- '91 Dodge Spirit R/T
plus a couple other turbo Dodges, a Cobalt, a couple Focus, big S/C wagon, and some other stuff...
blackbird_R/T is offline
User Tag List
Linear Mode Linear Mode
