car sputters when accelerating to high speeds - Dodge SRT Forum
post #1 of 11 (permalink) Old 05-09-2009, 09:01 PM Thread Starter
jessebeachusmc's Avatar
Quoted: 0 Post(s)
my car is sputtering and shaking a little when im in 4th and 5th at wot. it also stops accelerating when the tach gets above 6,000 rpms. Im thinking that my injectors arent delivering enough fuel and the a/f ratio is fucked up but i just want some more input before messing with anything.
mods-
borla exhaust
625cc high flow fuel injectors
k&n cia
8.5mm spark plug wires
dsp tuned to 93 perf oct. tune
AGP borg warner s256 powered
jessebeachusmc is offline
post #2 of 11 (permalink) Old 05-09-2009, 09:04 PM
2011 Calendar Car
CONROY's Avatar
Quoted: 0 Post(s)
why the fuck do you find it necessary to even be going at the top of 4th/5th on the street
CONROY is offline
post #3 of 11 (permalink) Old 05-09-2009, 09:04 PM
2011 Calendar Car
CONROY's Avatar
Quoted: 0 Post(s)
and as for not getting enough fuel, 625's are too big for your mods.
CONROY is offline
post #4 of 11 (permalink) Old 05-09-2009, 09:29 PM Thread Starter
Quoted: 0 Post(s)
yes i know there to big for my setup and im not going into the 6,000 rpm range on streets in 4th or 5th it happens in 2nd and 3rd.
post #5 of 11 (permalink) Old 05-09-2009, 09:34 PM
hercfe's Avatar
Quoted: 0 Post(s)
change plugs/wires. gap to .035. it sounds like spark blowout. and unless your on the autobahn, theres on need for WOT in 5th.
how do you know your afr? a dsp perfect 93 octane tune isnt really a great tune as proven over and over again here, and its surely no substitute for a wideband, which it doesnt look like you have. are you sure your fuel pump is up to par? regulator good? whats your fuel pressure? and BTW, if your in cali, how are you using a 93 octane tune?
hercfe is offline
post #6 of 11 (permalink) Old 05-11-2009, 06:44 PM
Quoted: 0 Post(s)
cali sells 93 instead of 92 like most areas..
Sounds like you don't have an wideband, so i would consider looking into a PLX or an innovate or something that allows to read your AFRs during WOT pulls.
then i would recommend to take a look at our Fuel pump rewire Kit to keep fuel pump voltage at 12.0 in higher rpms.
srt_noob is offline
post #7 of 11 (permalink) Old 05-11-2009, 06:47 PM
Adionik's Avatar
Quoted: 0 Post(s)
If your DSP isn't rescaled for those injectors, the 93 tune isn't going to do ANYTHING fuel wise and you're choking the shit out of your pistons with fuel
My car was doing the exact same thing in 4th and 4th only...AFR's were below 10.0's
Adionik is offline
post #8 of 11 (permalink) Old 05-11-2009, 08:01 PM
Blue_Streek's Avatar
Quoted: 0 Post(s)
WRONG...cali only gets piss 91.
a rewire will not fix this either.
lower your gap to something around .030.
if probelm still persists. change out the injectors or lower your boost.
how much boost yuo running?
and does this happen when you give the car WOT below 3k rpms?
ALUMNI CSR905:::2002
Blue_Streek is offline
post #9 of 11 (permalink) Old 05-12-2009, 05:44 PM
Srtbullet05's Avatar
Quoted: 0 Post(s)
Check to see if your cylinders are working properly.
Srtbullet05 is offline
post #10 of 11 (permalink) Old 05-14-2009, 08:38 PM Thread Starter
Quoted: 0 Post(s)
im spiking around 18 and holding 15.It seems like its doing it in all the gears like it just kinda cuts out i guess you could say for a split second, and its laggy at wot.
post #11 of 11 (permalink) Old 05-20-2009, 04:59 PM
Quoted: 0 Post(s)
check the cylinders. i ahd the same problem
User Tag List
Linear Mode Linear Mode
