Old 07-06-2009, 01:17 AM   #16 (permalink)
3chord's Avatar
Member Number: 70323
Trader Rating: (12)
You didn't mention the downpipe used. If it has a cat on it, check to make sure it's not clogged. Sounds like a partially clogged cat to me if it has one.
3chord is offline   Reply With Quote
Old 07-06-2009, 01:19 AM   #17 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
?. this car runs no cat
JnR:
blue209 12.23@118 w/1.8 60ft 321hp and 390tq
tkilla 12.28@117.8 w/1.8 60ft new e85#'s coming soon
jrsrt 12.29@116.9 w/1.87 60ft
blackpearl 12.35@114 w/1.960ft 307hp and 363tq
Winecountry 12.32@112 w/1.7 60ft 315hp and 330tq
yellowsrt-4 12.5@112 w/2.0 60ft 307hp,355tq
jlozacr 12.7@110 w/2.0 60ft 301hp and 345tq
bayscksrt 12.9@110 w2.0 60ft 21psi, E85
srt princess 12.9@109 w/1.9 60ft
Kaz109 50 trim 458hp/460tq 11.54@121.78 W/1.79 60ft
reed32 is offline   Reply With Quote
Old 07-06-2009, 01:22 AM   #18 (permalink)
Member Number: 70605
Im not an expert but for 24psi isnt your injectors too small for e85?
MikeRT4 is offline   Reply With Quote
Old 07-06-2009, 01:24 AM   #19 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
its not on e85 right now. its on 91 piss gas. Also we have twin pump set up waiting to go on but i dont want to do it if we cant find out whats wrong with it now.
Old 07-06-2009, 01:33 AM   #20 (permalink)
Member Number: 41077
is this a s3 car i did see it has a 3bar map sensor that is why I ask. If it is not s3 and has 3bar map sensor that would be your problem.
dsmlights@rage-tek is offline   Reply With Quote
Old 07-06-2009, 01:35 AM   #21 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
its stage 3 car with a 50trim on it. i have the stock pcm and sensors coming in the mail this week to put on.
Old 07-06-2009, 02:03 AM   #22 (permalink)
ohh ok. if the car works fine till 5600 then it could prob be a problem with the pcm shutting down maybe sees too much knock. Check ur Map sensor that it is soldered correctly maybe it is coming undone. Turn the boost down to spring boost and does it happen again ??
Old 07-06-2009, 02:05 AM   #23 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
the carhas no kr at all. i turned the boost down to spring pressure only and it still does it. we changed out map sensors and tip sensors with another car and no luck. i think its fuel related. tomorrow i will post a video after i do the fuel pump rewire mod.
Old 07-06-2009, 02:23 AM   #24 (permalink)
if it was fuel related then it would not do it at 12 psi spring pressure so the rewire mod will not do much for it. Unless the fuel pump took a complete dump. Also check out for floating valve, that could be an issue. Check the injector duty cycle what does it say when the car goes lean ????
Old 07-06-2009, 02:37 AM   #25 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
i'll check tomorrow on the idc when it goes lean. how can i check for a floating valve?
Old 07-14-2009, 01:08 AM   #26 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
well i'm pretty sure we found the problem today. tomorrow the car gets put back together and taken out for a test spin.
Old 07-14-2009, 01:28 AM   #27 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
reed32 , chuck's_srt-4 , rollwitstyle
hi chuck
Old 07-14-2009, 01:29 AM   #28 (permalink)
chuck's_srt-4's Avatar
Member Number: 12569
What did you find that is the suspect?
MY FAVORITE EQUATIONS:
Fuel Volume = (HP * BSFC) / (# of injectors * IDC)
CFM = C.I.D. * RPM * V.E. *.5 / 1728
P.R. = (PSI Boost + 14.7) / 14.7
HP = TQ * RPM / 5252
Old 07-14-2009, 01:31 AM   #29 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
today jesus and i finished up checking the timing. The timing was a tooth and a half off . it took us awhile to get the timing right on but it got done. i also notice the hex key bolts on the tial ext. wga were not sealed all the way so i have to tighten those down tomorrow. Hopefully with our findings kaz car will be in the running top of the line again.
Old 07-14-2009, 01:33 AM   #30 (permalink)
That'll definitely do it!
Page generated in 0.21615 seconds with 13 queries
