ok. this issues has started over a year ago on this car. i don't always have the car because the owner works a lot so when i do get the car its for 1-2 weeks at a time and more upgrades are getting done. well basically when the car goes WOT at 5.5-6k its hitting a wall, were i can no longer accelerate anymore. Im a little puzzeled.
items changed:
coil
new 50trim turbo (other turbo broke)
new clutch (other clutch was slipping)
new wires
lowered the fuel pressure from 45psi to 40psi (runs e85 most of the time)
spark plugs to .28
removed white vaccum line to the tip sensor
cam position sensor
changed s3 map and tip sensors
i'm thinking its the dtec or fuel pump now. the car has no hanging rpms, no idle issues. im thinking of making a youtube video so you guys can see what it is. so strange.
oh yeah its Kaz109 car:
stage 3 pcm
stage 3 map/tip
50trim
pro series head with solid lifters
act extreme clutch (btw bad ass clutch)
crane 16's set @ (0,0)
returnline w/bottelneck fix
255 pump
ed super beast fmic
950cc injectors (it did it with the 750's as well)
mpx 62mm tb
rage tek ported manifold dtec (think this things messing up too)
w/i dual nozzle set up
scan guages
aem wideband
i would say take out the dtec.. make sure you re connect the map signal wire at the pcm.. or it will go down hill
but there was an issue a week ago when a kid couldnt go past 5K it was due to no fuel.. whats your AFR
thinking about taking the dtec wiring apart since i didn't do the wiring. ...last time i looked, af's were 10.3-10.5 off meth. Now i cant tell what the af's are because the wideband harness got wrapped around the steering wheel and ripped the wires. I have a spare harness that will go in tomorrow.
setting in the dtec are right but i notice the fcd @5000 <---is this suppose to be that high?
All intercooler pipes are upgraded? Everytime I have seen this problem (2 times) it ended up being a collapsed coupler of either the intake or IC piping. If it goes dead that means you are not getting air, how are the afr's when it happens?
yeah all ic pipes are fine. cti piping and jmb coldside. at 5600 the car doesnt go anywhere and the car goes lean (seems like fuel stops going to the car).
