Hi everyone, ive been over this forum looking at all the different posts trying to gather research to help me build my srt4 to around 400hp without blowing my car up. I would like some opinions to help guide me and point me in the right direction. Tell me if i am missing stuff or on point. Here is my list of Current mods, i bought the car with few mods so i am not sure exactly what they are. Also listed is mods for my build i would like.
Mods
Cca bfmic
Mopar s2 pcm
Mopar s2 injectors
short ram intake - previous owner installed
Agp wastegate stock 8lb spring
3 bar map and tip sensors
93 octane tune on the DSP
1 step colder ngk spark plugs
Oil catch can - previous owner installed
Exhaust with modded tips from previous owner.
Has a down pipe from previous owner, he welded the cutout shut.
Agp dog bone motor and tranny mounts
Booger bushings
Maddog sts 58 % reduction 1 inch lower
Autozone axles
New build --- need input!!!
Act xt street disc SS 480hp holding cap 540 ft lbs torque. Comes with lightened steel flywheel, throw out bearing and alignment tool.
Mopar oem clutch pivot ball
Agp forged clutch fork
Mopar clutch pivot fork boot and clip
Arp flexplate bolts - ??? Not sure if i need them.
Mopar oem clutch slave cylinder
Mpx dual exit exhaust w/ downpipe 3" with o2 sensor bung
Digital aem afr gauge
Digital aem oil pressure gauge
Aeroforce interceptor gauge
3" injen short ram intake
Wilwood 4 piston complete big brake kit.
Wilwood brake line kit
Dss level 3 axles
N2mb WOT box launch control - will it destroy my CAT?
Mopar timing belt / tensioner / bearing / water pump kit.
Remove balance shaft assembly
Arp connecting rod bolts
Mpx 62mm throttle body
Mishimoto aluminum radiator
Mishimoto fan shroud assembly
Mishimoto silicone rad hoses
Mpx bfmic
Agp lower hard pipe
Agp upper hard pipe with hks ssqv bov package.
Mpx oil catch can
Mpx check valve
Walbro 255 LPH high flow fuel pump
Fuel pump rewire mod
Bottleneck fix
Ported intake and exhaust manifolds
Agp 4-3 inch reducer
Boomba fuel rail
S256-rs 550whp max on 30psi full boost 3600 rpm .63 A/R housing
1000cc deatschwerks injectors comes with the turbo package.
Agp fuel return line
I know i shouldnt exceed 430whp on stock internals. i wanted the bigger turbo for later mods if i do choose to do so.
Also just another question. Is the widest wheel i can get 9 inches? or is it 8.5?
Thank you all for looking this over for me. The help is much appreciated.
Mods
Cca bfmic
Mopar s2 pcm
Mopar s2 injectors
Booger bushings
Autozone axles
Dss level 3 axles
Mpx bfmic
Agp lower hard pipe
Mpx oil catch can
Mpx check valve
Bottleneck fix
Boomba fuel rail
