Bosch Plug wires - Page 2 - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 06-28-2011, 07:29 PM   #16 (permalink)
kagekun's Avatar
Member Number: 57941
Just for the record, Both North and Blackbird told you not to do something.
Seriously, take it as law.
Meth addict and CM is my dealer
Stone White ACR 315HP 407TQ
- 13.9 @ 108mph - 2.4 60' - Ugh Traction
All Your Methanol Mixing Needs
kagekun is offline   Reply With Quote
Old 06-28-2011, 08:26 PM   #17 (permalink)
bzzt's Avatar
Member Number: 83768
The wires are all fitting fine now and they came with some dielectric grease on both ends. Plus as mentioned they come with the warranty in case anything ever happens to them
2004 Silver SRT-4
Stage I, AEM CAI, UDP, cut balance chain, muffler
bzzt is offline   Reply With Quote
Old 06-28-2011, 10:05 PM   #18 (permalink)
Merderates da formz
NorthNJSRT4's Avatar
Member Number: 57126
/Thread.
NorthNJSRT4 is offline   Reply With Quote
Old 06-29-2011, 06:25 AM   #19 (permalink)
duster360's Avatar
Member Number: 45182
Quote: Originally Posted by blackbird_R/T View Post
If you're having issues with the wires staying on the plugs also make sure you are putting a coat of dielectric grease in the boots. This will help keep moisture out and also eases with installation and allows the boots to slip over the plugs and towers on the coil easier.
I keep a large tube of dielectric grease(~$10) in my tool box and encourage everyone to have some in hand.
Add a dab whenever you remove either end of the plug wire.
1025cc Injectors+ E85/GAS Base tunes =$359
ADD Boost By Gear to ANY PCM boost control tune $75
E85+Gas Base tune Combo $150*[*Only available for 1025cc Siemens/FIC1100&2150/AGP1200/All ID]
PLEASE USE EMAIL!!dave at needlesstorque dot com
Old 01-29-2012, 10:24 PM   #20 (permalink)
Chief's Avatar
Member Number: 61336
just got some today, my msds went out, other than them not quit reaching the top of the plugs very good, im happy with them, im even gonna boil them or cut them down. I run a shorter spark plug, thats why :/ any who, anyone hear of boiling the boot so you can push the clip down closer the the plug?
'freedom's not free'
24-25psi 61mm
11.6@120
@3650ft
Chief is offline   Reply With Quote
Old 01-30-2012, 11:01 AM   #21 (permalink)
Hi N Mity's Avatar
Member Number: 33036
I tried to boil a set of MSD's, I couldnt get the clip to move. That is when I tossed them in the garage and bought the set of bosche, which if I remember right, carry a lifetime warranty.
If the clip doesnt reach the plug, cutting them down wont help. That only helps if the clip is too far down and causing the top cover on the wires not to seal around the plug tubes on the head cover
Old 01-30-2012, 12:18 PM   #22 (permalink)
Chief's Avatar
yea u would have to cut out the cover that meets with the VC
24-25psi 61mm
11.6@120
@3650ft
Old 01-30-2012, 12:29 PM   #23 (permalink)
KBzPTGT's Avatar
Member Number: 112
i swap my Bosch wires out every time i change the plugs.Whether they need it or not. It's free. What's not to like about a lifetime warranty?
KBzPTGT is offline   Reply With Quote
Old 01-30-2012, 12:34 PM   #24 (permalink)
Chief's Avatar
Noice
24-25psi 61mm
11.6@120
@3650ft
Old 01-30-2012, 01:44 PM   #25 (permalink)
Member Number: 19926
Have been running the BOSCH wires for almost a year and I am happy with them.
Can't prove if they improve or decrease performance as I would have to dyno with the BOSCH plugs and then another brand to see if there was any difference. Not something I am willing to do!
I used to run the MOPAR blue performance plug wires and they were great (At least they looked great!)
Came out last Spring after a few cold nights and car was only running on 3 cylinders.
Opened the hood and saw something had gnawed right through one of my wires!
MOPAR4ME is offline   Reply With Quote
Old 05-15-2013, 12:14 AM   #26 (permalink)
mole''s Avatar
Member Number: 17477
bumping for new guys
Bosch/Wireset (09477) | 2004 Dodge Neon 4 Cylinders S 2.4L SFI Turbo DOHC | AutoZone.com
33.99 with a lifetime warranty
i have these on both of my SRTs and my PtGT. best plug wires set IMO
DCR spiced and Tuned by the Mad Scientist team
Jay@N2MB and Nigel@BST (turbo666)
Mole' (STOCK TURBO) 16g BWS setup #s
380hp+ and 444tq+
11.7@122
1.71 60ft
PM/email me for all your 16g/18g/20g BWS setup and DCR needs...... Darrell Cox Racing on facebook, 1-517-369-9636 10am-5pm est webstore... DCRSRT.com. email me at mole79@aol.com .
Old 05-15-2013, 07:40 AM   #27 (permalink)
duster360's Avatar
Same here.
Just like the stock ignition coil and NGK4306 spark plugs, I see no reason to use anything else.
Old 05-15-2013, 11:44 AM   #28 (permalink)
sparky1_2007's Avatar
Member Number: 53397
i just went out and bought a set of these ~2-3 weeks ago along with some new ngk 4306's cant complain.
Quote: Originally Posted by pazsion View Post
lol not all srt-4's have turbos xD
2005 Dodge Neon SRT-4 - Flame Red
1025cc injectors
rescale tune from Duster360
3" Exhaust
sparky1_2007 is online now   Reply With Quote
Old 05-15-2013, 11:47 AM   #29 (permalink)
SRT of the Month
underSRTarmor's Avatar
Member Number: 32888
Ill pick up a set and test them vs granitelli vs magnacor
Sent from
Old 05-15-2013, 11:54 AM   #30 (permalink)
Racerxvsspeedracer's Avatar
Member Number: 32196
Quote: Originally Posted by NorthNJSRT4 View Post
I'd take that with a softball sized grain of salt though. They claim the Granatelli wires are "the highest quality wire we have ever carried, and the wire that we strongly recommend.", however, being solid core wires they aren't designed for use in a vehicle like the SRT-4 which has electronic ignition and an engine management system. They're for carbureted engines with distributors (mechanical cap and rotor ignition) and some magneto applications. Our cars are designed to use spiral-core wires.
Magnecor\Mopar Performance\MSD\Bosch Premium > Granatelli
Yup, lower resistance isn't a measure of how good a wire will perform in a car with electronic ignition. Voltage leaks occur from the ignition coil when there isn't enough resistance in place to hold back the energy that is building in the coil. When the coil voltage rapidly rises if there's nothing holding it back it'll lose some of the accuracy and lower the delivered voltage to the spark plugs.
Also of note, a thicker wire isn't a better wire. The advertised diameter is that of the insulation, not the conductor.
100% agree Granatelli wires are crap, I'll never use again.
Mopar performance have been good to me, I have new Magnecor wires..... going to try out with a new tune.
17x8 245/40/17 ST40 BBK Project TRAIN DONE!11/13/09
04 -E-85 Ported Stock Turbo,Stock cams&Head,Stock Motor,Safc Neo
329.69Hp, 395.77Tq STD 297Hp@6K 320.87Hp, 385.18Tq SAE
WTB Locked DSP,Built 5speed,SCT Prp
Racerxvsspeedracer is offline   Reply With Quote
