bolt in roll cage? - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 11-28-2012, 08:17 PM   #1 (permalink)
Member Number: 91443
Default bolt in roll cage?
does anyone make a bolt in roll cage for an 03 srt4 that doesnt completely eliminate use of the backseat?
Farley74 is offline   Reply With Quote
Old 11-28-2012, 09:41 PM   #2 (permalink)
Member Number: 90281
I've seen custom ones that were ridiculously uncomfortable but the back seat was use able.
Lots of pads though, maybe check the fab section.
Bloo magoo is offline   Reply With Quote
Old 11-28-2012, 09:51 PM   #3 (permalink)
96civicturbo's Avatar
Member Number: 82290
x2 lmk if you find a nice cage
12.3 @116 last srt stock longbock . . . new srt now
built longrod destroked 2.3 on a 6765 , custom 3 speed
auto. #s coming very very soon. built engine by
malovent motorsports.
96civicturbo is offline   Reply With Quote
Old 11-29-2012, 12:22 AM   #4 (permalink)
blackbird_R/T's Avatar
Member Number: 5369
If you install a cage in the rear half of the car you'll never be able to safely carry passengers back there again. The seatbelts are designed to stretch in a controller manner in a collision and all the foam padding in the world won't help if someone's head made contact with a bar. Even if it is only in the rear half of the car it's likely to also be dangerous to the front seat passengers too if you try to use the stock three-point seatbelts which can't prevent your upper body from sliding out to the side.
If you're looking at a cage for use at the track be very careful to read the rules and regulations as bolt-in cages aren't legal for many sanctioned racing series. To provide strength needed to make the cage useful it generally needs to be welded to plates attached to the unibody. Also don't try to cheap out or buy kits from non-reputable builders.
Eric H. ---->- ----- '04 Neon SRT-4 (eBlue/S2)
'92 Dodge Daytona IROC R/T --- -- '91 Dodge Spirit R/T
plus a couple other turbo Dodges, a Cobalt, a few Focus, and some other stuff...
Old 11-29-2012, 12:51 AM   #5 (permalink)
Lav
Lav's Avatar
Member Number: 79804
Found these from the magical world of google :
Autopower Bolt In Roll Cage - Dodge Neon including SRT-4 - 83632
Lav is offline   Reply With Quote
Old 11-29-2012, 07:19 AM   #6 (permalink)
So with this cage your stating with confidence that the back seat is useable?
Old 11-29-2012, 07:24 AM   #7 (permalink)
SRT of the Month
underSRTarmor's Avatar
Member Number: 32888
if you did know, now you do, eric aka blackbird is in the top 5 SMARTEST most knowledgeable owners on this site..
99.999999% of the time take is advice........
Old 11-29-2012, 11:20 AM   #8 (permalink)
thanks for the advice everyone! i will probably end up taking the car to the track every once in ahwile so i think i will probably just spend the extra little money and get a welded in cage. thanks everyone!
