#16 (permalink) |
Fresh Meat Moderator
![]() Join Date: Dec 2009
Member Number: 76568
You would think a BW stage 3 on near 30 PSI and E85 would have made more.
Still nice numbers.
![]() Diablo CMR tuner ~Dan~ 2004 Black Neon SRT4: E85 stock turbo SOLD ![]() 310HP 436TQ 2004 Eblue Neon SRT4: E85 5558 ![]() XXXHP XXXTQ |
| Sponsored Links | |||
Advertisement | |||
#17 (permalink) |
![]() Join Date: Aug 2010
Member Number: 80981
About 2-3 months. Dialed in about 3 weeks. You would think a BW stage 3 on near 30 PSI and E85 would have made more.
Still nice numbers. I agree there is something holding it back on tq it should have been close to 500. I am going to data log a pull and send it off to duster and see what would be holding me back. Maybe my motor is just tired it does have 117k miles on it once I get forged internals in I'll get it back on the dyno and see also going to do a 60mm throttle body and see if it let's in a little more air I talk to mole he also said tq was low but still solid for a set up like this
05 flame red
bw Stage 3 47lb 20g By Mole' daily driven E85 ![]() |
#19 (permalink) |
Congrats on the numbers. Sounds like a lot of fun!
MB855 using AutoGuide.C![]() It is but for me it is a chore to drive I have to tell my self no to race the little d16 revving at me or the v6 stang lunging at the stop light
05 flame red
#22 (permalink) |
400TQ at 2900 RPM. YAYYYYYYYY
Seriously, though. Stock up on input shafts, S3 hits with retard strength, even in big wheel form. yea crazy power I started 3000 on the dyno just to be safe. Not sure mole' would have to answer that. I just know it is a 47lbs 20g and yes I do I ran all new lines for the fuel system just so I didn't have to mess with it later down the road.
05 flame red
#23 (permalink) |
![]() Join Date: Jul 2005
Member Number: 31038
Nice numbers!
04 Neon SRT-4
Mopar S3, DSP, 888cc injectors, Dusters tune, Walbro 255 w/ S3 fuel system. NO rewire. e70 397whp/398tq 128k miles 99 Neon Sport Coupe MPG Daily 2.0 DOHC, 5spd |
#24 (permalink) |
![]() Join Date: Apr 2004
Member Number: 10522
Gotta love BWS3. I, too, would have expected more. Considering i put down 450 on 27psi (dropping to 25), with almost an identical turbo. My rod was bent too :O
Dont worry about turning the boost down. Just get better tires >:]
![]() 11.21@127.88 |
#25 (permalink) |
![]() Join Date: Nov 2009
Member Number: 76443
I've seen some measurements in dsm forums of some of the billet 20g compressors and they have a significantly longer blade length or height over traditional cast mhi compressors. This may potentially result in compressor flow possibe in the 48-50lb/min+ range.
But the limiting factor to this would be the stock tdo5hr turbine which is typically choked out around 45lb/min |
#26 (permalink) |
I do think there is something wrong with my car. But haven't nailed it down. My numbers on a stock s3 on pump were low but I belive that to be the fins that were chipped. I'm leaning towards compression or possible head problems
05 flame red
#28 (permalink) |
![]() Join Date: Oct 2011
Member Number: 86743
Nice! It woulda been nice for you too swap out to a larger turbine like i said when you posted about your turbine wheel being chipped. Then, retune on the 4bars and youd have more leg room too let the turbo shine some more. I too run a 20g wheel along with a td06sl2r turbine like those found in the ef2/hta fpgreens and damn did changing from the stock td05hr clipped turbine too this larger turbine really make a difference. The 20g wheel i run is like that of what toofast82 is talking about with a smaller hub area, meaning more blade area between the circumfrence on the compressor wheel, and having extended tips. Its a kinugawa/kamak compressor wheel along with their "green" turbine wheel. I made 534/510@36-37psi. I have had my 40psi boost gauge pegged before but was lean but im sure the power was maybe 550. Great turbos. I substituted the mopar s3 for an evo9 turbo. But, nonetheless, despit my turbo having a larger comp cover, you should be able too make bigger numbers. Keep on the lookout for my build. Got something coming together in a couple months with a bigger turbo. Gotta love the different variances between the mopar s3/evo8&9 turbochargers.
E85 is one hell of a drug.
[IMG] [/IMG] |
#29 (permalink) |
![]() Join Date: Mar 2007
Member Number: 52541
Dont wory about dyno numbers, enjoy it and take it to the track if you want to see how fast it really is.
2004 Black Srt4 -
12.6 @ 123mph - 2.1 60' |
#30 (permalink) |
SRT of the Month ![]() Join Date: Aug 2005
Member Number: 32888
I counldnt agree more. But 99% peeps get wrapped around. "Gotta make 400hp"
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
