Big Turbo Upgrade (Guidance) - Page 3 - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 02-12-2013, 10:33 PM   #31 (permalink)
Member Number: 82114
Quote: Originally Posted by enginjoe View Post
You can do well over 500whp with the stock rail. The '03 rail is the best though.
Is that just because it is easier / better for hooking up the Return Line kit?
If needed I will spend the extra $150 to get the boomba ruel rail.
n_charpy89 is online now   Reply With Quote
Old 02-13-2013, 06:34 AM   #32 (permalink)
Member Number: 3797
Well, it has the shrader valve at the end, which is nice for hooking up pressure gauges or fuel returns. Personally, my return is hooked up before the rail, which many think is the dumb way to do it, but it works at least to my power level very well and is clean and simple.
2003 SRT-4 Silver, AGP GT3076R on E85 DD!
Was 478hp/508tq ----> Now ???
2002 Camaro SS M6, going N/A...
enginjoe is offline   Reply With Quote
Old 02-13-2013, 10:05 AM   #33 (permalink)
Ok, that is the way I would have to hook it up too. I'm waiting to hear back from MAP on an official quote for all the parts. Then I'll decide if I want to spend the extra money on the fuel rail. (I know they are cheap, and I will get one eventually)
Old 02-13-2013, 11:18 AM   #34 (permalink)
Member Number: 92096
i thought the agp comes with a 38mm agp wastegate?
jimbean5006 is offline   Reply With Quote
Old 02-13-2013, 11:19 AM   #35 (permalink)
808ACRSRT4's Avatar
Member Number: 90635
Default Re: Big Turbo Upgrade (Guidance)
It's a turbonetics...
PG86100 using AutoGuide.C
808ACRSRT4 is online now   Reply With Quote
Old 02-13-2013, 11:21 AM   #36 (permalink)
Quote: Originally Posted by zman17 View Post
The 5431 kit from agp comes with everything you will need. Manifold o2 housing. Wastegate and the oil lines and coolant plugs. All the goodies. You will need an external bov and a boost controller. Like the boost box. Hands down best boost controller. Do you have a diablo product? My turbo is .63 ar housing. Mines a bit bigger than the 5431 so I have some lag down low but up top it pulls like a freight train. My car has way more street manners now. Seems to me the drive ability is a lot better. Mileage on a big turbo sucks if you don't stay out if boost. I get like 165-180 miles depending if I boost a lot or not. You will also need a tune. From duster360 or turbo666 mindmelt or link low. Who ever you choose. I personally use duster and he knows his stuff.
Sent from
i was looking at the fine print and saw agp 38mm wg. just making sure lol. all this money talk is making me wanna cheap out on a bws and tune hahahaha
Old 02-13-2013, 11:41 AM   #37 (permalink)
Member Number: 51111
nah they don't sell it with the turbonetics gate anymore. They send you their gate which looks ebayish (tial knockoffish) but I haven't seen anyone have problems with it really
go ahead...change yours too now; again
lVlemphizStylez is offline   Reply With Quote
Old 02-13-2013, 11:46 AM   #38 (permalink)
sounds good. although i have a shop less than 20 min from me that builds turbos, thats all they do. im tempted to drop my manifold and turbo off for a custom bws and purchase injectors/tune from duster. im not cheap im just cost effective.
Old 02-13-2013, 12:35 PM   #39 (permalink)
808ACRSRT4's Avatar
O that doesn't sound too good...
Old 02-13-2013, 12:38 PM   #40 (permalink)
808ACRSRT4's Avatar
Depends how much...and is your ride a dd???
Old 02-13-2013, 12:38 PM   #41 (permalink)
hey, if it works
it works
Old 02-13-2013, 12:49 PM   #42 (permalink)
he just built my friends sr20det turbo. ported, machined, billet wheels, coated, for around 600. so if i can keep the manifold im running and lines, etc etc etc.thats fine with me and they have warranty. yes my car is a dd
Old 02-14-2013, 11:15 AM   #43 (permalink)
Member Number: 90853
Thumbs up
Check this place out, I think you can save some money buying this and still getting your power needs in
Hahn Racecraft - Automotive Turbosystems
Also, you don't need that six puck if you're going to be limited by the engine itself. Our engines can only handle around 425 whp max. Some people go over, but without a rebuild, it's a gamble.
I would recommend these clutches, they are not any stiffer than stock, but they have incredible hold and have intermediate torque levels.
For example, the spec clutch stage 2+ holds 450 lb ft of torque and is sub $500s. It is a crazy deal. Also it comes with a flywheel since it is a modular clutch. Also no chatter like with the ACTs.
03-05 SRT-4 SPEC Staged Clutch & Flywheel Kits: JSC Speed
But what are your goals? Just fast drag car or autocross or just an awesome car?
So if I was to place this order I should be all set, then PM Duster or MindMelt and they would be able to set me up on a good tune?
daredevil5692 is offline   Reply With Quote
Old 02-14-2013, 11:50 AM   #44 (permalink)
Ridin59vette's Avatar
Member Number: 86347
Skip the SPEC Clutch. They are known to fail on our platform. You should probably do some research yourself before giving anyone advise
04 SRT-4: Under Construction
99 9-3: Daily Driver
FS Thread:
http://www.srtforums.com/forums/f416...5/#post9777568
Ridin59vette is offline   Reply With Quote
Old 02-14-2013, 12:05 PM   #45 (permalink)
My goals for the car is to have a reliable, and all around fun car that I can use as a daily driver and take to the track a couple times a year.
