Big Turbo Upgrade (Guidance) - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 02-09-2013, 08:07 AM   #1 (permalink)
Member Number: 82114
Default Big Turbo Upgrade (Guidance)
Hey guys, I've have been off the Forum for quite a while, focusing on work and stuff, and havent had time to work on my car, but now it's time to get back into it. I have read through a lot of the forum and the upgrade paths, and just looking for guidance / suggestions on what I should do to complete my project. I want to go with a new turbo, something that will be reliable and offer good power and driveability (only going to drive on weekends). I would really like to limit my total expense to no more than $3000 but would be more comfortable in the 2K range.
2005 ACR w/ under 60,000 mi.
Here is my list of mods, not all installed obvoiusly, car is still on stock tune:
MPx 3" turboback exhaust w/ cat and resonator
AEM UEGO Wideband
Walbro 255
AEM 3" SR Intake
MPx Oil Catch Can
DiabloSport Trinity
AGP Solid Motor Mounts
Mopar Blue Blow Off Plate
BC Coilovers
AGP Fuel Return Kit (not installed)
MPx Big Front Mount Intercooler (not installed)
DeatschWorks 1000cc Injectors (not installed)
3 bar map / tip sensors (not installed)
TurboXS Manual boost controller (not installed)
Things that I still plan on doing are adding a check valve and fuel pump rewire.
I know I will also need an external BOV when I go big turbo.
Basically I am looking for some suggestions and guidance, and if I have missed anything.... I am not real comfortable with tuning stuff myself, I just don't have any experience with it, kind of just want to install everything and get it dyno tuned (kind of a waste of the DST, I know). Close to 400hp would be awesome, but I would like to see at least 350.
Let me know what you think, Thanks!
n_charpy89 is online now   Reply With Quote
Old 02-09-2013, 08:20 AM   #2 (permalink)
Srt-4 Lover Tim's Avatar
Member Number: 87765
I believe you also need a clutch when going big turbo. Which turbo are going to be getting man?
Srt-4 Lover Tim is offline   Reply With Quote
Old 02-09-2013, 08:24 AM   #3 (permalink)
Ridin59vette's Avatar
Member Number: 86347
Your going to need a Clutch too. Get a PTE 5431 Kit From AGP and a 6 Puck from ACT. Should get you where you want to be reliably.
04 SRT-4: Under Construction
99 9-3: Daily Driver
FS Thread:
http://www.srtforums.com/forums/f416...5/#post9777568
Ridin59vette is offline   Reply With Quote
Old 02-09-2013, 08:26 AM   #4 (permalink)
ggferris's Avatar
Member Number: 76676
Return line and bnf if you wanna make power
Sent from
ggferris is offline   Reply With Quote
Old 02-09-2013, 08:30 AM   #5 (permalink)
Sent from
He's got the return line already and for his 350-400Hp Goal there's no point in doing a BNF
FS Thread:
Old 02-09-2013, 08:50 AM   #6 (permalink)
Sorry guys, really new to different types of turbos and this is the part that I am most stumped on..... No idea what turbo I want, and what is a bnf (sorry if its a stupid question)?
@ Ridin59vette: is this the turbo you are referring to?
Precision 5431 MFS - AGP Turbochargers, Inc. Store
And would I want the .48 or the .63?
Does this bolt up to the stock manifold?
I figured I needed a clutch too, just wasn't positive if I need it right away, I've read a lot of people stick with the stock one up to like 350, but if I go 400 I know it won't handle it well.
Old 02-09-2013, 08:52 AM   #7 (permalink)
zman17's Avatar
Member Number: 87469
.48 will spool a bit faster but .63 if u wan a bit more power. I'd honestly not use the .48 ar housing. To small, but it all depends on your personal goals.
Sent from
MODS: garret 60-1 trim kit Tial wastegate ATP o2 and manifold ,boost box,return line, AEM CAI, wally 255, innovative motor sports wideband, dusters injectors, Godspeed BFMIC, tuned by duster360 for gas and e-85
zman17 is offline   Reply With Quote
Old 02-09-2013, 08:57 AM   #8 (permalink)
Sent from
That makes sense, and assuming you drive nicely you should get better fuel economy when out of boost. I think thats the route I would go, just don't want a lot of turbo lag.
Does that turbo bolt right up? And would I need a new Wastegate and BOV?
Again sorry for the dumb questions, this is the first turbo car I've owned, trying to do it right without blowing something up!
Old 02-09-2013, 09:07 AM   #9 (permalink)
You will also Need a New BOV And Uppipe to mount it on. Other then that you should be good. It looks like you've got all the other support mods
Yes, that is the turbo, I would Def Go with a .63 That way when you get tired of the lower HP you still have some room on the turbo. With a .48 You will more then likely get a good amout of surge, also you would need a full kit. Like this SRT-4 Turbocharger Upgrade Kit - AGP Turbochargers, Inc. Store Then a quality Clutch. A bnf Is a Bottle neck fix. The stock fuel feed is very small so when you get to the higher HP Numbers it will hinder performance significantly.
FS Thread:
Old 02-09-2013, 09:11 AM   #10 (permalink)
zman17's Avatar
The 5431 kit from agp comes with everything you will need. Manifold o2 housing. Wastegate and the oil lines and coolant plugs. All the goodies. You will need an external bov and a boost controller. Like the boost box. Hands down best boost controller. Do you have a diablo product? My turbo is .63 ar housing. Mines a bit bigger than the 5431 so I have some lag down low but up top it pulls like a freight train. My car has way more street manners now. Seems to me the drive ability is a lot better. Mileage on a big turbo sucks if you don't stay out if boost. I get like 165-180 miles depending if I boost a lot or not. You will also need a tune. From duster360 or turbo666 mindmelt or link low. Who ever you choose. I personally use duster and he knows his stuff.
Sent from
Old 02-09-2013, 09:39 AM   #11 (permalink)
Member Number: 3797
He can control boost with stock solenoids and a tune I believe, so a boost controller is not needed. He has a trinity, so the tune is just an email away.
2003 SRT-4 Silver, AGP GT3076R on E85 DD!
Was 478hp/508tq ----> Now ???
2002 Camaro SS M6, going N/A...
enginjoe is offline   Reply With Quote
Old 02-09-2013, 09:45 AM   #12 (permalink)
Or just run it on Spring pressure
FS Thread:
Old 02-09-2013, 09:47 AM   #13 (permalink)
zman17's Avatar
Right. I was just saying that its something to look into for him.
Sent from
Old 02-09-2013, 09:55 AM   #14 (permalink)
So I would be looking at this kit:
With the Precision 5431 .63 selection, and that would bring the total to $1775
Then a few hundered for the BOV setup, and an email tune, and I would be all done for less than $2500 or so?
That sounds like a pretty good option to me. I was just planning on doing the dyno tune because I am not real confident in my tuning skills, lol.
Old 02-09-2013, 09:57 AM   #15 (permalink)
Pretty much man. Your going to want to look into a clutch aswell though. More then likely the stocker wont hold with the power that turbo will make
FS Thread:
