Old 11-12-2008, 05:07 PM   #1 (permalink)
radicalmark29's Avatar
Member Number: 55274
Trader Rating: (20)
Default Big turbo o2 housing
Will a kinetics o2 housing fit on an AGP manifold? No problems? Legit?
WTB: CF rear diffuser
radicalmark29 is offline   Reply With Quote
Old 11-12-2008, 05:50 PM   #2 (permalink)
1B4dSRT's Avatar
Member Number: 43757
Trader Rating: (10)
also interested to know this. and where do u buy a kinetic o2 housing?
1B4dSRT is offline   Reply With Quote
Old 11-12-2008, 06:01 PM   #3 (permalink)
Trader Rating: (20)
After a bit of research, yes it will fit, but kinetic is stainless steel, they're known to crack at the welds, and thy're 2.5 all the way down as opposed to 2.5 opening to 3.0 like the AGP.
Old 11-12-2008, 06:11 PM   #4 (permalink)
Lay
Lay's Avatar
Member Number: 41690
Trader Rating: (41)
I have an agp with kinetic o2 housing. I had to mod the o2 housing tho.
Lay is online now   Reply With Quote
Old 11-12-2008, 06:27 PM   #5 (permalink)
phubarr's Avatar
Member Number: 36947
Trader Rating: (56)
I've never heard of a cracked Kinetic O2 housing... you might be hearing of their cast manifolds. I'm a machinist and I've paid close attention for the last 3 years and I've heard of only 2 cracking, so its not like an epidemic. I've also seen 2 cracked AGP manifolds too, so it seems par for the course. The only bad O2 housing I've seen was an AGP unit that wasn't fully welded around where it expands from 2.5" to 3", AGP left a hole in the weld the size of a pencil tip that created an exhaust leak, and AGP took it back and fixed it.
I've held both a Kinetic and AGP O2 housing together (and the manifolds too), and both have virtually identical flange angles... so close that I feel confident saying yes, they're interchangeable.
The only functional difference between the Kinetic and AGP setup is the Kinetic is set up for a recirculated wastegate discharge, where the AGP is set up for an atmospheric wastegate dump. For O2 housings, Kinetic has always used stainless steel and appears to be laser welded, where as AGP welds them by hand and recently changed from some cheaper metal that seems to rust (mild steel?) to a higher quality stainless steel as well.
2005 Black Dodge SRT-4 ACR - SCT PRP (S2 base), ND Performance TCS, Mopar Stage 3 Coilovers, Falken RT-615's, AFE Stage 2 CAI, Ported 52mm TB, MaxxFab 3" DP (catless), Innovate LC-1 wideband, Aeroforce Scan Gauge, and a Hurst Shifter.
1989 Black Dodge Daytona Shelby Turbo II
1972 Plum Crazy/Black Plymouth Roadrunner
phubarr is offline   Reply With Quote
Old 11-12-2008, 08:05 PM   #6 (permalink)
1B4dSRT's Avatar
Trader Rating: (10)
no one has told me where to buy a kinetic o2 yet.....
Old 11-12-2008, 09:14 PM   #7 (permalink)
phubarr's Avatar
Trader Rating: (56)
It looks like they have them on their website here:
Kinetic Motorsport: KINETIC MOTORSPORT SRT-4 SS 02 HOUSING
Old 11-12-2008, 09:19 PM   #8 (permalink)
1B4dSRT's Avatar
Trader Rating: (10)
thanks....wow gay they are more expensive than agps...
Old 11-13-2008, 11:12 AM   #9 (permalink)
Trader Rating: (20)
the one i was looking at was "used"
he bought it, decided against it, and was selling it for 150 shipped so i was like hmmm.
but apparently it'd be a waste of 150 cause their shit.
Old 11-13-2008, 11:30 AM   #10 (permalink)
Jon@AGP's Avatar
Member Number: 26404
Trader Rating: (90)
Actually, our O2 housings are made out of stainless steel as well. We have been doing it this way for a little while now.
Jon@AGP is offline   Reply With Quote
Old 11-13-2008, 11:43 AM   #11 (permalink)
AEMpimp's Avatar
Member Number: 46379
Trader Rating: (36)
Mark dude you fail at life.... your gonna rock everything else AGP? and buy a different o2? LMAO!!!!
AEMpimp is offline   Reply With Quote
Old 11-13-2008, 11:45 AM   #12 (permalink)
AEMpimp's Avatar
Trader Rating: (36)
on a side note mark mine is still in the box when I bought it from AGP on group buy I havent really played with it that much but I think mine might be stainless too? lol Just buy the AGP one for the love of buttsex.
Old 11-13-2008, 11:46 AM   #13 (permalink)
Trader Rating: (20)
WAS going to.
Old 11-13-2008, 12:21 PM   #14 (permalink)
phubarr's Avatar
Trader Rating: (56)
(Cross posted to Stainless Steel O2 Housings and Dump Tubes!)
Hi Jon, thanks for correcting me, I just edited my post to reflect the changes.
When did this changeover happen? I actually have one of your O2 housings and dump tubes, and they're both becoming significantly rusted to the point where I'm becoming very concerned about them.
Since it's only been a little while since it went to stainless, do you have an exchange/upgrade program like you did (do?) for the welded log manifold owners when you guys released the cast manifolds? I'd seriously be interested! Probably others, too...
Thanks!
Old 11-13-2008, 12:29 PM   #15 (permalink)
Jon@AGP's Avatar
Trader Rating: (90)
PM sent.
Page generated in 0.19454 seconds with 13 queries
