Old 01-23-2009, 02:41 AM   #1 (permalink)
Member Number: 43905
Default big turbo install ?s
Just bought my 50 trim kit and am in the process of installing it.
50 trim
d tec
fuel pressure reg/ return line kit
crushed 1g dsm bov
i did some research and cant seem to find any info on a vacuum line diagram that utilizes an aftermarket bov with an external wastegate and fuel pressure regulator. i found a few other ones but not quite the same setup as me. i am still currently using my stock vacuum selinoids. Im looking for some help or a diagram to either run my vacuum lines with the selinoids or without them. either way doesnt matter to me.
on a side note im also looking for some install instructions for my d tec/knock light as they were not supplied with it because i bought it used.
thanks guys
toomey200 is online now   Reply With Quote
Old 01-23-2009, 03:58 AM   #2 (permalink)
Member Number: 30696
50 trim
d tec
crushed 1g dsm bov
thanks guys
BOV goes to vacume after the TB
Waste gate... depends on boost control.
amdguy is offline   Reply With Quote
Old 01-23-2009, 04:15 PM   #3 (permalink)
bumpppp
Old 01-23-2009, 05:37 PM   #4 (permalink)
Member Number: 54437
Trader Rating: (13)
Err, AFTER the throttle body for a BoV? I dont think so, im pretty sure you need it before... might be wrong but im almost 90% sure thats how I have mine setup
For the boost controller, how I have mine setup is running it straight off the nipple thats on the turbo then to wastegate...
Turbo ==line== Boost Controller ==line== Wastegate
Lemme run outside and check
05 SRT. Garrett 60trim "Baby Kahuna", Tial 38mm, Wiseco pistons, Eagle rods, BC S2 cams, ARP headstuds, SPEC stage 3+, AEM EMS, RC750's, tokico illumina 5 way's, Eibach Sportline springs ,Cooling Mist water/meth injection, Mopar exhaust with electronic cutout. Plus much more.
Dasstrum is offline   Reply With Quote
Old 01-23-2009, 05:43 PM   #5 (permalink)
Trader Rating: (13)
Yep, thats how I have mine setup. The vac line from the BOV tee'd into a vac line right before the throttle body.
And the boost controller... from directly on the turbo to the BC then to the wastegate
Works 100%
Old 01-23-2009, 05:46 PM   #6 (permalink)
killa 05 srt4's Avatar
Member Number: 64572
Works 100%
yea thats completly right. not to be a dick but d tek sucks at least i thin. u might get a few different codes from it
05 comm edditon 107/200 RIPP 5/13/09. will be missed had alot of fun with her.
killa 05 srt4 is offline   Reply With Quote
Old 01-23-2009, 07:17 PM   #7 (permalink)
TURBOPIONEER's Avatar
Member Number: 42347
Trader Rating: (26)
This is how is suppost to be install:
Turbo --------> Boost Controller -------> External Wastegate
Trottle Body Spacer----------> BoV and Fuel Pressure regulator.
This way you will eliminate all the selenoids (As well as Boost Leaks).
PM me if you have aditional questions and I can help you out.
TURBOPIONEER is offline   Reply With Quote
Old 01-23-2009, 08:32 PM   #8 (permalink)
Trader Rating: (13)
so pretty much exacty what I said. thanks for the reinstatement just in case he didn't get it earlier
Old 01-23-2009, 09:11 PM   #9 (permalink)
NJ DSM's Avatar
Member Number: 46989
Trader Rating: (34)
yo nick hes right...i have the diagram in a PM how me and jack did mine to eliminate the solenoids.
and hurry up and get finished with the install so i can still walk the shit outta your old ass 4dr
351/390 on Mustang DynoSTOCK TURBO
RUN YOUR CAR NOT YOUR MOUTH
NJ DSM is offline   Reply With Quote
Old 01-23-2009, 11:11 PM   #10 (permalink)
im not concerned about the codes. i have no evap setup as it is....
Old 01-24-2009, 12:15 AM   #11 (permalink)
lphooper03's Avatar
Member Number: 37050
Do NOT plug your BOV into the throttle body spacer. It T's into the line that goes to your throttle body from the brake booster.
50 Trim + Diablosport =
Old 01-24-2009, 03:56 AM   #12 (permalink)
I really would like to see people refrain from posting half ass guesses to how stuff should be hooked up. If you don't know don't posts.
BOV should see vacume. so put it AFTER the TB... nuff said
Turbosmart says it should be AFTER the TB also...
Tial says AFTER the TB as well..
http://www.tialmedia.com/documents/w...bovinstall.pdf
show me ONE manufacture that says to put the BOV BEFORE the TB. there is no vacume before the TB...
before you correct some one, make sure you know what your talking about...
Old 01-24-2009, 04:08 AM   #13 (permalink)
Works 100%
show me ONE manufacture that says the BOV shouldn't see vacuum.. should be AFTER the TB, or between the engine... and TB plate.
Old 01-24-2009, 09:29 AM   #14 (permalink)
Trader Rating: (26)
Just a question. From where do you think that line runs from? Let me guess, from the trottle body?
Page generated in 0.22494 seconds with 13 queries
