Old 11-21-2008, 04:56 PM   #1 (permalink)
Member Number: 42356
Default Bar Map Sensor
Hey guys I was wondering if I am pushing above stock boost should I upgrade my bar map sensor. My mods are in my sig. Recent mods that I put on would be the diablopredator 93OCT PERF tune. Waiting on my custom tunes.
Mods: Maddog STS w/bushings, Solid MM, PTP WGA (20PSI) , CAI, 3" Downpipe, 3" Custom Side Exit Exhaust, Stage1, AGP Fuel Return Kit, BFMIC, Hot and Coldside piping, Turbonetics BOV, Perrin BOP, Rage-Tek Custom Tune.
13.3 1/4 on street tires
jthomas123 is offline   Reply With Quote
Old 11-21-2008, 05:01 PM   #2 (permalink)
NoisufnoC's Avatar
Member Number: 136
only if your tuner writes the map to work with an upgraded map sensor. otherwise it'll mess everything up.
if you're tuner is writing a map for more than 18.5 psi you should go to a 3 bar setup.
Keeping the tire companies in business...
...one WOT shift at a time™
|| Mod List Coming Soon ||
***Forum Rules***
NoisufnoC is online now   Reply With Quote
Old 11-21-2008, 05:35 PM   #3 (permalink)
turbo666's Avatar
Member Number: 25206
Trader Rating: (31)
You'll need a 3 bar map and tip sensor and to have the Diablo CMR map settings adjusted so the CPU can read any boost above 18psi.
Nigel
04 Srt-4-AGP Borg Warner S360-RS, E85, and MUCH MORE coming soon...
7.493@99.56<-- granny shifting on 30r with 93/meth <--OLD SETUP!
FIRST TO MAKE BIG TURBO PCM BOOST CONTROL WORK ON DIABLO!
For custom tuning, installs, and transmission rebuilds PM me!
www.trudynosports.com
Old 11-21-2008, 07:32 PM   #4 (permalink)
Default thanx
alright guys thanx
Old 11-21-2008, 07:42 PM   #5 (permalink)
Default hmmm
I have already submitted my stock tune to get my 2 custom tunes. Now I told them I am running 20PSI and falling to 17PSI so with the custom tunes would I be good to go ahead and put the 3 bar maps sensor and tip sensor on or do I need to let them know that I plan on putting them on so that they can tune it with the device.
Old 11-21-2008, 07:47 PM   #6 (permalink)
turbo666's Avatar
Trader Rating: (31)
I would def. let them know.
Old 11-21-2008, 09:20 PM   #7 (permalink)
ill just turn the boost down to 18 for now.
Old 11-22-2008, 01:05 PM   #8 (permalink)
Blue_Streek's Avatar
Member Number: 47162
Trader Rating: (15)
you still have stock turbo? run no higher than 18.5 psi. the stock turbo tapps out at 19. anything higher and the efficiency of the turbo goes south. too much heat for the system
Blue_Streek is offline   Reply With Quote
Old 11-22-2008, 06:15 PM   #9 (permalink)
Default alrighty
alrighty appreciate the advice.
Page generated in 0.17498 seconds with 13 queries
