Old 01-21-2009, 11:01 PM   #1 (permalink)
Creamer03's Avatar
Member Number: 62203
Default AGP wga set up?
Ok so I've got an agp wga and I'm wondering what the best way to run it would bewith what my mods already are. The car is an 03. Mods are 3" TBE, AEM cold air, hot and cold side hard pipes, BFMIC and that's it. Want the wastegate to work good but without codes. I've seen where you can eliminate the stock cyl. And all that but just want it to be safe and run good! So some input please!
03 srt4 it just looks stock...
Creamer03 is offline   Reply With Quote
Old 01-22-2009, 12:41 PM   #2 (permalink)
ovrboostSRT4's Avatar
Member Number: 63872
I dont know how much the 03 fuel system can take but I think stage one can do around 18psi of boost, so I would say dont run it that high I guess around 15/16 psi (I dont really know so dont take my word) and get a wideband so you know how much boost you can do with a safe a/f ratio.
I hope this helps you alittle bit.
ovrboostSRT4 is offline   Reply With Quote
Old 01-22-2009, 02:47 PM   #3 (permalink)
my_little_srt's Avatar
Member Number: 41179
Trader Rating: (24)
I was running a 18 spike and 15 hold on my S1 with an AGP W/G. Just be prepared to throw CEL's like a MOFO on a stock PCM.............
my_little_srt is offline   Reply With Quote
Old 01-22-2009, 04:45 PM   #4 (permalink)
Creamer03's Avatar
yea it's still got a stock PCM. Is the pcm out of an 04-05 the same as a stage 1? And if so could I just get a used one and reflash it to work?
Old 01-23-2009, 05:57 AM   #5 (permalink)
Trader Rating: (24)
No it's no. All cars that came from the factory are stock PCM's....But 04-05 came with S1 injectors................
Yes and yes you can. All staged PCM's will work in all years unless it's not specifically made for an 05. If it's not made for an 05 it will work, but your battery light will be on all the time..............
Old 01-23-2009, 12:47 PM   #6 (permalink)
Creamer03's Avatar
So best thing to do is get the stage injectors and then find a staged pcm?
Old 01-23-2009, 02:55 PM   #7 (permalink)
Trader Rating: (24)
It depends on what you want to do. Only reason I purchased a S1 PCM was to get rid of the overboost CEL I was throwing after I installed my AGP W/G. I would personally look into a DSP................
Old 01-23-2009, 07:48 PM   #8 (permalink)
TURBOPIONEER's Avatar
Member Number: 42347
Trader Rating: (26)
hey in case u need a set of stg 1 injectors i have one almost new (Less than 1000 miles) for $65 shipped. LMK, Thanks
TURBOPIONEER is offline   Reply With Quote
Old 01-23-2009, 10:31 PM   #9 (permalink)
Creamer03's Avatar
K I'll see what I can do. How well would they work with my stock pcm?
Old 01-24-2009, 03:31 AM   #10 (permalink)
Trader Rating: (24)
Some people run S1 injectors on astock PCM, but turn up the boost in order to compensate for the extra fuel....................
Old 01-24-2009, 09:26 AM   #11 (permalink)
Trader Rating: (26)
You should turn up the boost to compensate the extra fuel, just as he said!! I think 3-4 PSI will be ok. LMK
Page generated in 0.15048 seconds with 13 queries
