Old 07-03-2009, 06:59 PM   #1 (permalink)
Untrustworthy Seller
Member Number: 73368
Default Agp Wga
I'm thinking about ordering a AGP WGA. I have a Mopar BOV. Can I leave that there if I get a new WGA?
coltf1991 is offline   Reply With Quote
Old 07-03-2009, 07:04 PM   #2 (permalink)
Member Number: 36825
You can but if you plan on turning up the boost the stock bov really sucks it leaks.So I would get the wga start saving for hks bov and hard piping youll be much happier.
SRT Jeff is offline   Reply With Quote
Old 07-03-2009, 07:21 PM   #3 (permalink)
Stock? It didn't come stock. It was installed. But I see where you are coming from. Just shit gets expensive real fast in the world these days.
Old 07-03-2009, 08:06 PM   #4 (permalink)
True!!
Old 07-03-2009, 09:17 PM   #5 (permalink)
rrmike1's Avatar
Member Number: 55729
Dont waste your money on hardpipes and a bov. The mopar bov is just fine for whatever boost you want to run. If you have any questions about leakage on the bov, just put some sealer on it. There's a bunch of threads about how well the mopar holds up under boost. Most of the bad info is just recycled from the same people...
Mopar S2 no toys, FBM pnp'd turbo/mani., Rage 55mm T/B, AGP WGA, AGP CAI, MPx 3" O2, Maxxfab 3" DP, Mopar Exhaust, AEM UEGO, SprayItRacing BOV, Crane 8.5mm wires, Champion RE10pmc5's, Stant 180 thermo, Prothane race MM inserts, Autometer 30/30, Tein H's, Proparts dual-gauge pillar, Fuel pump re-wire, NOS Sniper kit
rrmike1 is offline   Reply With Quote
Old 07-03-2009, 10:44 PM   #6 (permalink)
kagekun's Avatar
Member Number: 57941
No, ignore him, hes wrong. Get your WGA install it and youll be fine. The Riceplate only leaks when its installed incorrectly.
NO you dont need to save for hardpipes, they will do nothing for you
Meth Addict & CM is my dealer
http://www.cardomain.com/ride/3219131
Four Door Mafia
kagekun is offline   Reply With Quote
Old 07-04-2009, 01:29 AM   #7 (permalink)
Sweet. I love the way it sounds. Also how hard is it to install the WGA?
Old 07-04-2009, 09:09 AM   #8 (permalink)
rrmike1's Avatar
The wga itself is easy to install. It's the upper heat shield that can be a pain.
Old 07-04-2009, 02:05 PM   #9 (permalink)
By top heatshield you mean the stock one that covers the turbo? Is there a How-To on how to do it.
Old 07-04-2009, 02:35 PM   #10 (permalink)
speed_box's Avatar
Member Number: 67594
the hardpart about it is getting the bolts loose some tend to not want to come out i broke my ratchet while trying to take out my buddys heat shield
speed_box is offline   Reply With Quote
Old 07-04-2009, 02:47 PM   #11 (permalink)
Will the WGA not fit with it there?
Old 07-04-2009, 02:54 PM   #12 (permalink)
srt4crazy05's Avatar
Member Number: 54763
u dont need a how to for unscrewing some 10mm bolts. all u need is a good socket set, a ratcheting 10mm wrench(for the top bolt) and pb blaster(for every bolt)
12mm socket will unbolt the wga. the more extensions to choose from the easier it is. the hardest part really is taking out the bolts. its easy. make sure u know how to adjust the wga(search on how to do it) and start low at like 14psi in 4th and adjust it accordingly till u get ur desired boost(no more than 17-18 hold) in 4th. then ur good to go.
13.463 @ 103.71mph 3 bolt ons n street tires. stock suspension. mm inserts. no tune www.myfloridasrt.com
srt4crazy05 is offline   Reply With Quote
Old 07-04-2009, 02:56 PM   #13 (permalink)
it will. there are absolutely no fitment issues. the wga is at the top of the turbo while the mopar rice plate is at the bottom
please search and read all stickies btw
Old 07-04-2009, 03:10 PM   #14 (permalink)
Supermario's Avatar
Member Number: 43853
I am unsure why people state the Mopar BOV plate is bad. I used hi-temp silicone, made sure it didnt get into the diaphram and tightened it down snug. I also had this on with an AGP Billet WGA at 17-18lbs hold 15 to redline, and it was perfectly fine.
You will have to remove or "convince" the upper heat shield to mount the arm onto the flapper. PB blaster is your friend for the heat shield bolts.
"When you can't make them see the light, make them feel the heat." ---Ronald Reagan
Supermario is offline   Reply With Quote
Old 07-04-2009, 03:18 PM   #15 (permalink)
I did not mean a how-to for the heat sheild i mean for the WGA.
