Old 11-02-2009, 07:12 PM   #1 (permalink)
Member Number: 73914
Default Agp Wastegate or Stage 2 Wastegate!
I have the mopar stage 2 wastegate on my car and I was wondering if the agp wastegate just that much better? Also is it possible to hold 19 or 20lbs of boost to redline with the agp wastegate?
Srt-4_Deon is offline   Reply With Quote
Old 11-02-2009, 07:20 PM   #2 (permalink)
Member Number: 36825
I have the stg2 also. Some folks say go agp or forward motion.
SRT Jeff is online now   Reply With Quote
Old 11-02-2009, 07:37 PM   #3 (permalink)
HWY*'s Avatar
Member Number: 65076
It depends on what you mean by better. The s2 will have no ptb issues. The AGP will. The AGP will be capable of holding 19-20 off of PCM control. (the way they intended it to be used) The s2 will not. In fact, off PCM control, the s2 will only make 8-9psi.
Also the AGP is much easier to adjust than the s2.
HWY* is offline   Reply With Quote
Old 11-02-2009, 08:30 PM   #4 (permalink)
16Boosted's Avatar
Member Number: 65234
I have ptb issues on S2+ mbc.
16Boosted is offline   Reply With Quote
Old 11-02-2009, 08:41 PM   #5 (permalink)
TurboMoparGod's Avatar
Member Number: 33697
Trader Rating: (58)
PTP vs. AGP vs. Stage2 vs. Kenetic vs. Forward Motion WGA's
Forward Motion 302-658-2829
http://www.forwardmotioninc.com/html...og/page18.html
Sales@ForwardMotioninc.com
Stock turbo 12.82@107mph DR's
E1 Turbo 12.48@115mph DR's slipping stock clutch
E3 47lb Turbo 1/8 7.923@93.67 1.95 60' 235/60/15 DR's
TurboMoparGod is offline   Reply With Quote
Old 11-02-2009, 08:50 PM   #6 (permalink)
Orange Crush SRT's Avatar
Member Number: 73615
i have a kinetic wg and it works great ..specially now with my mbc!! =)
Orange Crush SRT is offline   Reply With Quote
Old 11-02-2009, 09:05 PM   #7 (permalink)
Drago's Avatar
Member Number: 65338
What's PTB, and i know what it stands for,(Part Throttle boost)? but what does it means, how does it feel or sound or taste like?
Drago is offline   Reply With Quote
Old 11-02-2009, 09:21 PM   #8 (permalink)
HWY*'s Avatar
PTB or part throttle over boost is like when the turbo tries to make full boost with the throttle plate only partially open. AKA compressor surge. BAD. It kinda sounds like sug sug sug. It should taste like puke because you're destroying your turbo by making it try to spin backward.
At least that's my understanding.
Old 11-02-2009, 10:06 PM   #9 (permalink)
16Boosted's Avatar
This..
Old 11-02-2009, 10:14 PM   #10 (permalink)
duster360's Avatar
Member Number: 45182
Holding 19-20psi to redline is impossible with a stock turbo. 14-16psi is about you'll ever see above 6k rpm regardless of the WGA used.
Now a 19-21psi spike works well with the stock turbo. For that, a well controlled Stock WGA is all you really need. A DSP controls the stock wga very well.
So save $$ on a wga and just buy a DSP
Old 11-03-2009, 06:56 AM   #11 (permalink)
So are you saying that with a dsp I can hold higher boost?
Old 11-03-2009, 07:29 AM   #12 (permalink)
Rugger's Avatar
Member Number: 18657
Get yourself a Forward Motion, best there is, period!!!
Pretty much no part throttle OVER boost with FM.. and yes I have tried them all.
My second choice would be the AGP, but it has noticeable more PTOB.
Rugger is offline   Reply With Quote
Old 11-03-2009, 07:47 AM   #13 (permalink)
duster360's Avatar
Yes with a stock wga I'm usually about 14.5-15psi at 6000rpm.
Its very rare that I've seen a $150+ aftermarket wga(AGP, FM, Kinetic, PTP,,blah,blah, blah) hold more than 15.5psi past 6000rpm.
Old 11-03-2009, 10:50 AM   #14 (permalink)
So what you are saying keep the stage 2 and be happy with 16psi or go big turbo
Old 11-03-2009, 11:06 AM   #15 (permalink)
atenzany62's Avatar
Member Number: 70786
get an e1 turbo i heard they hold 19psi at redline no problems. im planning to go that route when i have the money.
05 SRT-4
Mopar stage 1 with bolt ons.
Journal for my car
http://www.srtforums.com/forums/f41/...silver-540760/
FS: Turbonetics upper hardpipe, SCT Flash tuner. PM ME
atenzany62 is offline   Reply With Quote
Page generated in 0.15892 seconds with 13 queries
