AGP stage 4 turbo kit - Page 2 - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 01-18-2012, 06:12 PM   #16 (permalink)
4bangermistress's Avatar
Member Number: 86144
there is some really good info on removing the balance shaft chain in the HOW TO section.
Built Integrated Automotive long block.
Built Fuel system thanks too P. O'shea
agp kit with 6262
100% stock tranny, with issues
lots of random parts from lots of vendors: dcr, map, modern, pwerks, coolingmist, ptp, autozone!
CMR tuned on 91 oct. fuel by Integrated Automotive.
4bangermistress is online now   Reply With Quote
Old 01-18-2012, 06:18 PM   #17 (permalink)
Member Number: 51111
don't buy an agp branded turbo without doing some research first...
go ahead...change yours too now; again
lVlemphizStylez is offline   Reply With Quote
Old 01-18-2012, 06:19 PM   #18 (permalink)
Dodge put them there to absorb some of the motor vibrations. but if your making lots of power then you put extra stress on the chain and also the plastic gears that the chain runs on. last thing you want is for something as stupid as a broken unnessiary plastic gear to destroy your whole motor right?
agp kit with 6262
Old 01-18-2012, 06:21 PM   #19 (permalink)
They say that the chains breaks...I went 150k with mine still in...big turbo since forever. I'm not alone...some of the fastest stock bottom end guys share the same story. I had to part with it due to a built motor but it never broke or showed any signs of breaking
Old 01-18-2012, 06:48 PM   #20 (permalink)
yeah same here mine looked fine when i built my motor. but i've heard of people breaking them with only 350HP not sure on Tq. not sure if it was true or not just something i've heard
agp kit with 6262
Old 01-18-2012, 07:00 PM   #21 (permalink)
chokliosis's Avatar
Member Number: 71734
ok cool thanks for the input and advice everyone.
chokliosis is offline   Reply With Quote
Old 01-19-2012, 10:03 PM   #22 (permalink)
chokliosis's Avatar
Does anyone know or heard anything about the set 2.8
Old 01-20-2012, 11:55 AM   #23 (permalink)
Romerosrt's Avatar
Member Number: 86719
Quote: Originally Posted by whiteSRT69 View Post
do a compression test and go from there
if your compression is still good.. than go for it..
people say our motors are fully broken in at 100K
+1 do a compressionn test and the right tune
Romerosrt is offline   Reply With Quote
Old 01-21-2012, 10:21 AM   #24 (permalink)
you mean Zeta 2.8 right? it's supposed to be a pretty good little turbo. but i have no personal experiance with it. do a search
agp kit with 6262
Old 01-21-2012, 04:33 PM   #25 (permalink)
chokliosis's Avatar
Yeah the zeta 2.8(damn auto correct) I have searched there isn't much info on it I just want number guys are making
Old 01-21-2012, 05:31 PM   #26 (permalink)
AGP says 500 is POSSIBLE in the high ar., well to me that says if you MAx this turbo you can get 500 HP. I would never want to max a turbo out, that means that i should have gone bigger, having said that if you would be happy with low to mid 400s then go for it.
agp kit with 6262
Old 11-20-2012, 08:34 PM   #27 (permalink)
Dagambit's Avatar
Member Number: 71976
I have the zeta 2.8 it is pretty much a better 50trim. I am pulling a little over 320hp on the dyno. This is a loaded dyno and not a free spinning dyno, on a free spin I am pulling 410hp. I have the full AGP stage 4 kit plus return fuel kit. For some reason the way AGP wanted the regulator didn't work out properly in my car causing me to get a fuel rail to work properly. Dynos are just tuning tools anyway. You can ask a body builder how much he benches, but it doesn't matter if he can still kick your ass.
Dagambit is offline   Reply With Quote
Old 11-21-2012, 09:28 AM   #28 (permalink)
Member Number: 90281
dont go over 400 hp.
Bloo magoo is offline   Reply With Quote
Old 11-21-2012, 10:18 AM   #29 (permalink)
Boostinfamily's Avatar
Member Number: 77511
Eff the compression check, do a CYLINDER LEAK DOWN TEST, and uncap the coolant when you do it to see if there are any sealing issues.
Boostinfamily is offline   Reply With Quote
Old 11-22-2012, 06:07 AM   #30 (permalink)
Member Number: 54437
Quote: Originally Posted by chokliosis View Post
here is a link to the kit and everything that comes with it.
SRT-4 AGP Stage 4 Package - AGP Turbochargers, Inc. Store
Take that same $4,500 and piece together a kit with the same stuff listed on that page. You will find that you will have an extra $1000+ leftover!
I don't like buying these "kits" simple because what if I wanted a PTE6262 ball bearing turbo instead of the Delta 38 ... its not offered :\ or what if you dont need the injectors or the Walbro because you already have it.
Just piece together your own kit with the parts that you want and save the $$ for when you blow your car up.
Dasstrum is offline   Reply With Quote
