Old 11-30-2008, 05:27 PM   #1 (permalink)
Member Number: 68733
Default AGP S3 Delta 40lb kit install question
I was a S2 w/ toys and am putting on the kit mentioned in title. I have a couple of questions that aren't mentioned in the installation instructions. Since I have a boost controller with my turbo toys kit, do I install the manual boost controller that came with the kit? If so, do I have to undo all the wires that were put in for the turbo toys fm the S2 toys kit? All I have left to do is all the vacuum lines, blow off valve, fuel pump and flash, then I should be read to start the car. Thanks for your help.
srtbum is offline   Reply With Quote
Old 12-01-2008, 10:30 AM   #2 (permalink)
fullofrage4u's Avatar
Member Number: 28533
Trader Rating: (18)
i already had an electronic BC (Greddy) on the car when we installed my AGP kit. I left it in there obviously but I did have to switch up the lines on the solenoid (switch to external wastegate). I don't see why you would have a problem running the BC you have now, but I'm not for sure.
BRAVOPL POST ON HOW TO TEST FOR BOOST LEAKS:
"I'm sorry for an idiotic question. once i have this leak tester hooked up i start the car and then what? Do i just stand there and wait for some sort of whissle sound?"
SOLD
fullofrage4u is offline   Reply With Quote
Old 12-01-2008, 11:02 AM   #3 (permalink)
Novak94's Avatar
Member Number: 45523
I'm not sure if the DAB with work on that setup, ive heard of people useing the S2/S3 with that turbo and keeping the DAB. I would do a bit more serching or try the MBC and then switch to the DAB and see which one works better for your needs.
Old 12-01-2008, 01:57 PM   #4 (permalink)
Jon@AGP's Avatar
Member Number: 26404
Trader Rating: (90)
You can use it, but ultimately an external boost controller will work better.
Jon@AGP is offline   Reply With Quote
Page generated in 0.13066 seconds with 13 queries
