Just having fun with my new IC.
AGP DFMIC log link: Deposit Files
Stock FMIC log: Deposit Files
Since the ambient temp is different, we will have to concentrate on the rise from ambient.
Another member is going to help me make some graphs. Feel free to download the logs, as depositfiles will not host them for long.
I did a 0-140 pull I think for the stock IC, and a 1-150 or so pull on the AGP IC. I was trying to get the biggest results, with the most abuse I could put the car through. Its freaking hot outside today :readclose
I boost leak tested the car after install, i didn't notice any boost leaks other than a very tiny one. I seemed to have trouble holding as much boost on the second test. I am using a boost box, so I may need to reset the PCM to adjust the WGDC. Both tests were on E85.
At 20psi in 5th gear, by the time I reached 144mph my charge temp was 160*, ambient showing 102* at that time. This was on the stock intercooler. Actual temperature outside was 86*.
At 18psi in 5th gear, by the time I reached 144mph my charge temp was 149* with an ambient temp of 104*, actual outside temp was 102* according to the log. At then end of a pull to 155mph my ACT was 154*.
Timing was 39* starting from 1st gear, and around 3rd gear it began to drop. Finally ending at 28.5 in 5th gear. I believe this was the PCM controlling it, as I haven't added timing since flashing, and I haven't seen any KR. Just been letting the PCM do its thing.
