After using E85 for 2 1/2 years.... - Dodge SRT Forum
 5Likes
post #1 of 47 (permalink) Old 03-29-2016, 10:32 AM Thread Starter
Quoted: 12 Post(s)
0 zilch no issues whatsoever from the use of E85 on my car...If your on the fence I hope this helps with your decision
dj4monie and OffTheWall like this.
viper gts is offline
post #2 of 47 (permalink) Old 03-29-2016, 10:50 AM
ziggo0's Avatar
Quoted: 151 Post(s)
Issues I've had personally: black gunk/goo in injector tips, fuel filter corrosion/blockage (Fuelab 6 micron) and causing rubber lines to harden (perhaps regular 93oct would do the same?). Other than that it's been great.
Stone White 05 - Built Bottom End - Built Head - Arias - Eagle - BC - Crane - MPX - DCR - Borg Warner s257sx-e .82 AR T3 - e85 - tons of supporting mods
ziggo0 is offline
post #3 of 47 (permalink) Old 03-29-2016, 10:59 AM
comatoast's Avatar
Quoted: 94 Post(s)
Garage
I have all ptfe lines and the tank was spotless when I made the switch to e. I've only got about 1000miles or so on everything since the swap, but the only thing I am considering is swapping the fuelab 6 micron fiberglass filter for the fore innovations 10 micron SS.
Turbo / TB - AGP Zeta 3.0 / 28 psi , AGP bfmic, Boomba 70mm tb Engine - Wiseco 8.8:1 pistons .020 over , eagle h-beam rods , king main and rod bearings , DCR crank strap kit, Head - FnF race ported exh ports , +2mm rev exh valves , BC springs and Ti retianers , BC stage 4 cams (280*s) , Boomba cam gears,
Fuel - , 900cc fic inj , -6an feed and return lines , fuel pump rewire , bottle neck fix , Bosch 044 intank , aeromotive rrfpr , E85..
comatoast is offline
post #4 of 47 (permalink) Old 03-29-2016, 11:46 AM
Quoted: 33 Post(s)
I've ruined four fuel gauge senders, a 2004, a 2003, and two DCR E85 senders.
Those DCR senders are $99.95 and don't hold up!
Jondahl is offline
post #5 of 47 (permalink) Old 03-29-2016, 12:04 PM
comatoast's Avatar
Quoted: 94 Post(s)
Garage
There are quite a few people thatsell the e85 sending units for less than dcr.. Quite a few members on here also just buy the application and put it on themselves.
post #6 of 47 (permalink) Old 03-29-2016, 01:59 PM
DickSRT's Avatar
Quoted: 251 Post(s)
Yeah but if you don't do it right apparently it doesn't work...
She's wide.
DickSRT is offline
post #7 of 47 (permalink) Old 03-29-2016, 02:38 PM
Quoted: 33 Post(s)
I PM'd a guy on Facebook who makes these, but he never got back to me. What is this compound you speak of?
Jondahl is offline
post #8 of 47 (permalink) Old 03-29-2016, 05:10 PM
comatoast's Avatar
Quoted: 94 Post(s)
Garage
Funny guy...
Just a heads up ... Use this goop onbthe sending unit before it goes bad...
Mine was gone a few days after it was coated, so mine was already shot
post #9 of 47 (permalink) Old 03-29-2016, 07:25 PM
Quoted: 358 Post(s)
Been using it since 2008 or so. No issues except lower gas mileage.
2005 SRT-4, BW Stage 3, Tuning...
2002 Camaro SS M6, Turbo kit in, working on things!
2003 SRT-4 Sold!
enginjoe is online now
post #10 of 47 (permalink) Old 03-30-2016, 10:41 AM
comatoast's Avatar
Quoted: 94 Post(s)
Garage
What pump are you using
post #11 of 47 (permalink) Old 03-30-2016, 11:18 AM
Quoted: 358 Post(s)
I used a 255, Bosch 044 on the old car and Waldron 450 on this one.
2003 SRT-4 Sold!
post #12 of 47 (permalink) Old 03-30-2016, 11:26 AM
comatoast's Avatar
Quoted: 94 Post(s)
Garage
Exact same 3 for myself, in that order too. Any pickup issues? Can you post a pic of your canister setup?
post #13 of 47 (permalink) Old 03-30-2016, 11:37 AM
Quoted: 358 Post(s)
I have pictures i can post when i get home. I have 1/8 tank and below issues around curves and hard acceleration. Zenkat has a 450 setup that fixes that. I'm going to mod mine like his and use hydramat. There should be no issues after that.
I just remembered that pics of mine and zenkat's are in the fuel section big Walbro 450 thread
Walbro High-Pressure 400lph In-tank Fuel Pump
Page 10 is my setup. I can't find Zenkat's...
2003 SRT-4 Sold!
post #14 of 47 (permalink) Old 03-30-2016, 03:23 PM
Quoted: 22 Post(s)
What application are we talking about. I searched and did not find anything short of caravan/flex fuel senders.
s14kev is offline
post #15 of 47 (permalink) Old 03-30-2016, 04:28 PM
comatoast's Avatar
Quoted: 94 Post(s)
Garage
It's the actual coating they use on the sending units
User Tag List
Linear Mode Linear Mode
