Old 05-13-2008, 10:31 PM   #1 (permalink)
Member Number: 13606
Default Act clutch not grabbing the same
Ok so I have the ACT upgraded clutch (the one that is rated at 500 foot pounds). It use to grab right off the floor, and now it grabs like a stock clutch. I have only done a bad slip twice and it wasn't bad, and it still is as stiff as before. It has 40k on it. Any ideas why it would be doing this. Is it shot? Should have I adjusted the pedal when I installed it. My bud with an EVO had to adjust his pedal right after putting his in.
Thanks
Injen 3" CAI, Weapon R Pressure Pipe W/Turbo XS RFL BOV, hard pipes, Needswing DP with powerplate, 60mm true TB with spacer, AGP Wastegate, Plugs and Wires, EBC, Fuel return line, DC Sports Front Strut Tower Bar, 27mm front sway bar, 22mm rear sway, barWerks 3 point rear strut tower bar, Motor mount inserts.
Soon to be FMIC and Stage ??
jackbandit is offline   Reply With Quote
Old 05-13-2008, 10:43 PM   #2 (permalink)
lilmike0450's Avatar
Member Number: 56278
Clutch pivot bushing is prob shot...and you prob need to adjust a little.
05 White ACR
lilmike0450 is offline   Reply With Quote
Old 05-13-2008, 10:50 PM   #3 (permalink)
Where is this pivot bushing at?
Old 05-13-2008, 10:53 PM   #4 (permalink)
Im trying to find a pic to better describe it for you....
Old 05-13-2008, 10:55 PM   #5 (permalink)
Old 05-13-2008, 10:56 PM   #6 (permalink)
Is it that peice with the tabs, I noticed that felt a little loose. Should it have no play in it?
Old 05-13-2008, 10:57 PM   #7 (permalink)
NEW Rage Product!!! Clutch Pedal Pivot Upgrade
here is the fix if that is your issue.
Old 05-13-2008, 10:58 PM   #8 (permalink)
Not really...if you see that bolt on the top...that is where you adjust your pedal...
Old 05-13-2008, 11:10 PM   #9 (permalink)
excellent thanks a lot
Old 05-13-2008, 11:15 PM   #10 (permalink)
yup...
Old 05-17-2008, 06:52 PM   #11 (permalink)
ok I ordered the part, anyone else have any ideas till then
Page generated in 0.24128 seconds with 11 queries
