75mm throttle body - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 11-25-2012, 10:26 PM   #1 (permalink)
crazzinezz's Avatar
Member Number: 90830
Default 75mm throttle body
I installed a custom built intake with a 75mm ford tb. The tb has a 3 wire ford tps and a 2 wire ford iac. after wireup everything works like its suppose to, however, when i'm looking at the tps sweep on scantool its going from 0.8v closed throttle to 4.5v wot. I know that 0.8v closed is normal but 4.5v wot??
old tps only went as far as 3.8v
crazzinezz is offline   Reply With Quote
Old 11-26-2012, 03:07 AM   #2 (permalink)
Member Number: 35677
Default pictures would be useful
could you post up some photos of the set up?
ValleyRacer is offline   Reply With Quote
Old 11-26-2012, 03:15 AM   #3 (permalink)
LinkLow's Avatar
Member Number: 75469
So you ARE still using the Ford TPS and IAC? Or no?
LinkLow is offline   Reply With Quote
Old 11-26-2012, 04:09 AM   #4 (permalink)
Fresh Meat Moderator
tunerlover3's Avatar
Member Number: 76568
Why use a ford TB when there are plenty of aftermarket TB's made for our car?
Diablo CMR tuner ~Dan~
310HP 436TQ
XXXHP XXXTQ
Old 11-26-2012, 04:29 AM   #5 (permalink)
SRT4V8stomper's Avatar
Member Number: 26563
Size and price.
PG86100 using AutoGuide App
PTE BB 6766 HP Vband .82ar on a Tuner Geeks sidewinder
SRT4V8stomper is offline   Reply With Quote
Old 11-26-2012, 08:57 PM   #6 (permalink)
crazzinezz's Avatar
LinkLow : yep using the ford IAC and TPS
the TB is 75mm BBK. intake is custom built
Tunerlover3 : Price!! Price!!
Paid $200.00 CDN
Images below
Old 11-26-2012, 09:19 PM   #7 (permalink)
LinkLow's Avatar
It shouldn't make much difference as far as function goes. Sure is a big throttle body for a mild sized turbo.
If it still has a smooth transitions between open and closed loop fueling and the car performs how it should, I don't see a problem with it.
The factory PCM only requires 2.3 volts from the TPS to enable WOT power enrichment, so as long as you are over that then you shouldn't have problems at WOT.
Send me a log
Old 11-26-2012, 09:58 PM   #8 (permalink)
crazzinezz's Avatar
Send me a log
Throttle response in unreal, I see a big difference in how the car is performing.
Also With the new tital WG I installed, I'm still playing with the MBC trying to find a happy medium 3rd gear 4500 rpm spiking 22psi afr 11.2 and clutch is starting to slip lol what's next. I'll send you a log in a couple of days.. You think we might have to do any re-scailing with this intake? Stage 2+ clutch on order
T3/T04E 50 Trim - Siemens 888cc/1025cc Injectors - HKS SSQV - Tial 38mm WG - 75mm TB - Custom Intake Manifold - Walbro 255lph - n2mb wot - 3" side exit - CAI - ACT Stage 3 clutch
Tuned by LinkLow
Old 11-26-2012, 10:12 PM   #9 (permalink)
triangles's Avatar
Member Number: 80981
What is done to the manifold? Pnp On the runners and just regular aluminum sheet for the tube ?
05 flame red
bw Stage 3 47lb 20g By Mole'
daily driven
E85
triangles is offline   Reply With Quote
Old 11-26-2012, 10:14 PM   #10 (permalink)
LinkLow's Avatar
All depends on how the log looks.
Also, if you haven't already paid for the clutch, you might look into something a little tougher than a stg. 2
Old 11-27-2012, 12:46 AM   #11 (permalink)
edub20's Avatar
Member Number: 65499
DCR builds some intake manifolds for 89-93 mustang TB to save $$
Evan
2004 dodge srt-4 (stockish)
1997 dodge neon (srt swap)
edub20 is offline   Reply With Quote
Old 11-27-2012, 06:48 AM   #12 (permalink)
^ please never change your sig <3
310HP 436TQ
XXXHP XXXTQ
Old 11-27-2012, 06:55 AM   #13 (permalink)
edub20's Avatar
as long as all the mods dont mind
Evan
Old 11-27-2012, 09:44 AM   #14 (permalink)
crazzinezz's Avatar
Tube is either 1/4" or 1/8" thick haven't measured it but looks thick. pnp on runners.
Tuned by LinkLow
Old 11-27-2012, 09:48 AM   #15 (permalink)
crazzinezz's Avatar
Was looking to get this
Centerforce DF037672 - Centerforce Dual Friction Clutches - Mobile SummitRacing.com
I can get it through my local supplier for about $560.00 cdn
Tuned by LinkLow
