Old 02-01-2007, 06:07 PM   #1 (permalink)
1badsrt-4's Avatar
Member Number: 21276
Trader Rating: (53)
Default 5,300-5,500 stumble
Well this problem with my car has been bugging me for quite sometime. It started out of no where. The problem is at about 5,300-5,500 my car misfires. It sounds like the car is on the Rev limiter. Now here is the odd part. It only does this in first and second gear. If I click third and run the car to redline it pulls like a train. Im getting a misfire code for cylinder #4 and a multi-cylinder misfire. I have changed the coil, wires, and plugs. Im now running a stock coil, ngk 4306 plugs and msd wires. The only thing I havent done is move injectors around. It doesnt matter what psi I run and the car is running about 11.4 a/f. The only other things I can think of are intake leak or injector clog. Any ideas would be great. And I will list my mods
57 trim turbo, SAFC, CTI tb exhuast and fmic, hardpipes bov, rc 750's, kenetic tb. I have others but those are the basics.
11.34 @ 128.33 mph. Stock motor, head, cams and ecu
1badsrt-4 is offline   Reply With Quote
Old 02-01-2007, 06:36 PM   #2 (permalink)
Masssilversrt4's Avatar
Member Number: 3905
For some reason my car does the same thing in lower gears.. But i'm not throwing any codes.. Almost like it lights off too quick.
Hell bent on building fast cars!!!
Masssilversrt4 is offline   Reply With Quote
Old 02-01-2007, 06:37 PM   #3 (permalink)
1badsrt-4's Avatar
Trader Rating: (53)
Hmmm, this is odd Dave
Old 02-01-2007, 07:04 PM   #4 (permalink)
Member Number: 37868
stupid question, have you checked your plugs?
Usedcarfinders is offline   Reply With Quote
Old 02-01-2007, 07:04 PM   #5 (permalink)
1badsrt-4's Avatar
Trader Rating: (53)
Changed them twice.
Old 02-01-2007, 07:09 PM   #6 (permalink)
I had that problem too when I bought my SRT, they replaced the plugs and wires, problem fixed, maybe your wires? Try the stock ones if you still have em
Old 02-01-2007, 07:11 PM   #7 (permalink)
Member Number: 37525
Trader Rating: (12)
make sure you check the gap in ur plugs and that the wires rfom the ignition coil are in the correct firing order
dgillie is offline   Reply With Quote
Old 02-01-2007, 07:17 PM   #8 (permalink)
1badsrt-4's Avatar
Trader Rating: (53)
They are all gapped correctly and I have tried 3 sets of plugs and wires and 2coils. Same problem stll occurs.
Old 02-01-2007, 07:18 PM   #9 (permalink)
I got the impresion this problem came out of nowhere, so im thinking one of his wires are trashed
Old 02-01-2007, 07:19 PM   #10 (permalink)
4DRVIPER's Avatar
Member Number: 6612
Trader Rating: (118)
2 Mods huh? lol, I x2 this guy's recommendation. I had the exact same problem when I installed Stage 2. Changed evrything out, coils, plugs, gaps on plugs changed, nothing, car would get to about 5800, and it would happen! Iridiums suck! lol ONLY reason why I say this is because THIS WAS my problem. Installed silver plugs, and now I run all the way up to 6500rpms, no issues. Same gap, only changed the plugs. Hope this helps, for all you iridium users. J/K
4DRVIPER is offline   Reply With Quote
Old 02-01-2007, 07:21 PM   #11 (permalink)
1badsrt-4's Avatar
Trader Rating: (53)
Trust me when I say this, Im no rookie to this car or automotive. This is what I do for a living, im just stumped at the moment. I have checked the gap and changed my plugs more then 3 times.
Old 02-01-2007, 07:28 PM   #12 (permalink)
4DRVIPER's Avatar
Member Number: 6612
Whoa Kahuna, calm down, I am sure you are very knowledgeable. I was simply poking fun at 2 Mods talking among themselves about this problem they share. Nothing more!
Old 02-01-2007, 07:32 PM   #13 (permalink)
1badsrt-4's Avatar
Trader Rating: (53)
Dave and I know each other well. I wasnt fliping out I was just stating that I have a clue.......well sometimes
Old 02-01-2007, 08:04 PM   #14 (permalink)
BTR
BTR's Avatar
Member Number: 11347
Trader Rating: (42)
what happens to the AFR when the stumble occurs?
BTR is offline   Reply With Quote
Old 02-01-2007, 08:07 PM   #15 (permalink)
1badsrt-4's Avatar
Trader Rating: (53)
Rich im not 100% sure but I think it stays the same or very close. Its not really a stumble per say, it sounds/feels more like the car is hitting the rev limiter
Page generated in 0.24984 seconds with 13 queries
